Question about Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
My Bravia Model KDL 46Z4500 (4 months old) turns itself off & red standby light flashes 7 times. Only way to turn the TV back on is unplug and reconnect (only temporary fix as TV will turn itself off again in a short time).
    New Friend:
Seven time blinking sony led lcd tv
Posted on Feb 09, 2019
    Champion:
  • Sony Expert
  • 212 Answers
Its temperature error temperate rise internally in system ic so that's why its goes to 7x blink if your tv is in warranty please replace the main board in warranty other wise you can purchase new main board for your tv
Posted on May 08, 2016
Replaced circuit board under warranty.
Posted on May 05, 2009
6ya staff
SOURCE:
I have a Sony Bravia LCD TV Model: #KDL-46W5100 SN:8020524. When I turn on the TV all it has a great picture & sound. After apx. one minute it will lose the sound and then it will turn itself off. Then...
G'day Lee, sounds like you may have a 'dry joint' meaning the solder has come adrift, to open the back up will need special tools to fix it. Hope you can get it fixed. Cheers Greg.
Mar 04, 2015 | Sony BRAVIA KDL-46W5100 46" 1080p LCD TV -...
Sony Bravia 46" The standby light flashes four
If tv model number is KDL-46S2000 then 4 times blinking standby light indicates back light failure problem in your tv.
Check/ replace back light inverter boards to solve its problem.
Thanks.
Dec 29, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
My Sony Bravia will play for less than a minute and then reverts to standy. Any suggestions?
Please unplug tv from wall socket for minute or so,, replug back in and turn it On.
If tv still goes to standby itself than its standby light would blink to show an error in somewhere inside tv circuits.
Let me know how many times standby red light blinking? There would be 3 seconds long pause in blinking so count pause to pause to determine problem section.
Thanks.
Jun 13, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
40'' Sony Bravia goes into standby with the light blinking 9 times
I finally managed to solve this problem by unplugging everything - scarts - HDD cables - power etc and left it for an hour. When I turned it back on again the problem had sorted itself out.
Sep 30, 2009 | Sony Televison & Video
Sony Bravia standby light flashing 6 times
there is a bad ground may on the cable check the voltage on the cable & set if on cable call the cable company. if tv call sony they may help with cost may be still under warranty
Jun 27, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
KDL-40XBR3 turns itself off; STANDBY light flashes 9 times
sony 52 inch tv in stand by mode comes on and off on its own
Jun 01, 2009 | Sony BRAVIA KDL-40XBR3 40 in. LCD HDTV
Flashing red standby light
Take it down from its mount and try to restart it if this resolves the issue your mount is too tight on the back of the lcd monitor.. This happend to me as well good luck with your BRAVIA
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 22, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony bravia-flashing red light
I would guess your power supply board is slowly disintegrating. It is hard to tell what it is, until it finishes frying itself out. Plan on replacing the power board soon, 1-3 months maybe.
Nov 14, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Four blinking red lights.
Either on of the backlight inverter boards is bad or a backlight has failed inside the panel.
Oct 11, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony bravia
what model of Sony is it? On many of the Sony projectors, a 3 flash error code indicates the lamp is not properly seated/installed or the lamp door is not closed properly
May 15, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony BRAVIA KDL-40S2000 40 in. LCD HDTV Logo
1,546 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
