Bravia problems sony tv
I have a Bravia KDL-52wl135 I went to turn it on and weird purple and green color. The picture is clear and not distorted. Fix or start over with a new TV.
    Top Expert:
  • Televison & ... Master
  • 76,143 Answers
Just visit the site given below. It has screen shots to defective Sony Bravia. Compare it to that of your TVs' and make sure about the fault. In most cases, the fault you described here sill be repairable.
Posted on Nov 20, 2013
  • The Knight
    The Knight Nov 20, 2013
    google.com/+GopakumarGopalan
6ya staff
SOURCE:
Anonymous
SOURCE: Sony BRAVIA KDL-40W4000
I've been looking into this myself as I've also recently purchased the KDL-40W4000. I was watching a murky old film and was getting a bit of sludgy ghosting but found that by reducing the contrast to 25, setting the backlight on low, colour on neutral and the brightness about 40-60 (and taking ALL advanced noise functions off), this reduced the ghosting considerably.
BUT, this is quite a cool and dark image. If you watch standard TV and films mainly, a variation of the Cinema setting is probably the best overall setting i.e.
backlight: min
contrast: 79
brightness: 50
colour: 53
colour temp: Warm 2 (although Warm 1 is less yellow and still fine)
sharpness: min
noise reduction: off
mpeg nr: off
contrast enhancer: off
colour space: standard
Ben, UK
Posted on Nov 23, 2008
Anonymous
  • 67 Answers
SOURCE: tv bravia kdl 40v3000 problem turning on
Unfortunately, this is a failure of the balancer board for the backlight. The unfortunate part is that the balancer is not available by itself anymore, and the whole panel must be replaced, as Sony only has the balancers attached to new panels. You can contact Sony directly to ask for assistance, and it usually helps.
Hope this helps you...
Posted on Jan 05, 2009
vinnyq
vinnyq
  • 157 Answers
SOURCE: sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
Posted on Oct 07, 2009
tvtek
Don
  • 1284 Answers
SOURCE: sony bravia kdl 32l4000 - color bars running vertically on screen
In most cases is the screen is covered with vertical lines all the way accross the screen then the T-Con module is at fault. The t-con board is replaceable without having to replace the entire LCD panel which would usually make it cheaper than replacing the TV. The part number I come up with is 1-857-213-11. Please take a moment to rate my answer. Thanks...
Posted on Dec 02, 2009
tvhelp-Dave
Shukai Fung
  • 178 Answers
SOURCE: Bravia KDL-46VL130 TV: Our Sony KDL-46VL130 picture is streaking and some...
That symptom may cause by the main board or t-con board, I suggest you do software up grade first.
Posted on May 07, 2010
Sony Bravia model KDL 55EX723 color not good
Replace either t-con board or lcd panel.
Apr 25, 2016 | Sony Televison & Video
My Sony Bravia picture turns green.
check cable, if its using an HDMI, replace it: if component RGB cable, reseat or replace.
Oct 03, 2015 | Sony Bravia KDL-46Z4100 46 in. LCD HDTV
Distorted Colors on Sony Bravia KDL-40Z4100
T'Con board fault. For most Sony sets; T'Con is an integral part of the panel. It will be best to contact the authorized service center for Sony in this case. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 08, 2015 | Sony Bravia KDL-40Z4100 40 in. LCD TV
Bravia KDL-52WL135 color snow mixed into picture
Can you post a picture that shows what snow issue is that youre experiencing that would help with diagnosis
Aug 07, 2012 | Sony BRAVIA KDL-52XBR6 LCD TV
Too much purple in sony bravia
Try to examine the screen with the color turned off---is it a uniform color other than gray or black and white?
A photo posted somewhere with a link showing what it looks like might be helpful.
May 15, 2012 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
My Sony Bravia KDL-52W3000 when turned on after being off for a while has a weird double/distorted picture for about 15min. then it clears up and has a perfect picture for the rest of the time you watch...
CHANGED Z SUSTAIN BOARD.PICTURE PERFECT.APART FROM WHITE DOTS..THINK IT COULD BE DUST OR FINGER PRINTS ON RIBBON JOINTS,,WILL RE CHECK AND WIPE F/PRINTS TO SEE IF ANY CHANGE
Take care.....
Aug 04, 2011 | Sony BRAVIA KDL-46V3000 Television
My sony bravia screen turned green I do I fix it?
When the color of the screen is complete green, you should not worry. That is the normal color that should be on the screen when no program is coming in because the cable box is off. So simply press OK on the remote of your digital box and your will see picture on your TV. If none appeared, then there is problem on your cable box. Call then your service provider.
Nov 29, 2010 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
SONY BRAVIA KDL-40S2010 40"
Mine isnt even 1 year old and same problem. was fine last night, woke this morning, turned it on and there they are green and purple
Apr 08, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Televison & Video Logo
408 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
