Question about Ricoh Aficio Sg 3110Dn - Printer - Color - Ink-Jet
My printer has a red light on and on the screen it says SC(28212) and it doesn't want to print
How do i use the boxed options on certain keys?
Prt SC (Print Screen) does NOT send the screen to the printer!!
If your windows desktop is showing, Print Screen will capture the ENTIRE screen to the clipboard - Open Paint and Ctrl-V to paste the captured image into paint (or other graphics program).
If you want to capture only the active screen, use Alt-Prt Sc and do the same with it.
Take screen capture print your screen Windows Help
Print screen Wikipedia the free encyclopedia
Feb 20, 2015 | Acer Computers & Internet
I have LANIER LD115 Copier/ printer can not copy and print ,red light showen on copy button,Erro shown " SC: 544" AND " CALL SERIVCES" , GREEN Light on copy indicator, red on printer light, shown up
The copier error code SC544 / 544 is a fusing lamp overheat error code. (This is a hardware problem)
This error can mean the:
PSU board is bad
IOB board is bad
BICU board is bad
Defective thermistor in the fuser
Defective power supply
You need to contact a local service technician to take a look at your copier.
Nov 08, 2014 | Office Equipment & Supplies
Ricoh SG-3110DN 28212
use a web browser and type in IP address at top and problem will be displayed
Nov 18, 2013 | Ricoh Office Equipment & Supplies
Whats error code sc 28212
Turn off printer remove carts wait 2 minutes but back in and turn on!
Oct 30, 2012 | Ricoh Aficio Sg 3110Dn - Printer - Color -...
My brandnew Ricoh is saying Error SC 28212 ~ What does this mean??
Call sawgrass tech support for the reset.... it is straight forward and easy to follow. As per customer support, you will need better than 20% full cartridges, they recommend new ones, which they will provide overnight free if still warranted.(ERR28212) As discussed, here are the reset instructions.
1. Turn the printer off.
2. Open the cartridge door and leave it open until step 15.
3. Turn the printer back on.
[img id="Picture_x0020_1" alt="3110 Panel" src="file:///C:/Documents%20and%20Settings/Nancy%20Smith/Local%20Settings/Application%20Data/IM/Runtime/Message/%7B944CD05A-8C76-404B-84B9-E5D3FB8CED31%7D/Show/image0011.jpg" width="500" height="143"> (was a photo of machine front, the down button is also "menu")
4. Hold down both the Up & Down arrows together for 3 to 5 seconds (nothing on the LCD display will indicate the appropriate amount of time has passed)
5. Release the arrow buttons and press #Enter (if nothing happens, try again)
6. When successful the LCD will display SYSTEMver with 3 optional menu selections starting with Service Menu
7. Press the down arrow once to Engine Maint. and press #Enter
8. The LCD will display SP No. with the default 1000000 underneath
9. Using the Up & Down arrows, and pressing #Enter after each number, enter 3009002. Press #Enter when complete.
10. CARRIAGE CHANGE 3009002 will display on the LCD. Press #Enter.
11. CARRIAGE CHANGE EXEC will display on LCD. Press #Enter.
12. OK? will display on the LCD Press #Enter.
13. Then Running will flash on the LCD panel before going back to CARRIAGE CHANGE EXEC. Continue to next step.
14. Exit the SP mode by pressing the Escape button repeatedly until you are back at the Engine Maint. screen. Press the down arrow once to End. Press #Enter one more time to completely exit.
15. Turn the printer off.
16. Replace the four ink cartridges with new ones.
17. After the new cartridges have been installed, close the right front cover.
18. Turn the printer on.
19. Wait for the machine to fill go through an initialization procedure which may take about 7 minutes.
This 100% worked for me.... be certain that the screen displays EXACTLY what the directions tell you!! -NSmith
Aug 07, 2012 | Office Equipment & Supplies
My Officejet 6000 E609n printer doesn't print the correct colors. The red is printing yellow and the blue and green are a lighter version of what is on the screen. I have cleaned the printer head
This is not a cartridge issue. IT is Printhead issue. Since you have done the manual cleaning, it is now time to replace the Printhead.
Regards,
Suhail
May 14, 2012 | HP Officejet 6000 All-In-One InkJet...
No display on lcd screen, only solid red light, no
Does the printer print? if yes and the printer is still under warranty, send the printer in for warranty repairs. The interface card may be faulty or the interface robin cable if the printer is printing.
Jul 03, 2010 | Xerox Phaser 6300DN Laser Printer
Printer not printing a red light comes on.
first u check the feed roll component.. and remove than refix a connections.. then may be its working.
Aug 05, 2008 | HP LaserJet 2100 Printer
Ricoh Aficio Sg 3110Dn - Printer - Color - Ink-Jet Logo
60 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
