Question about Sony KDL-32S3000 32 in. LCD Television
How to do a complete factory reset of a Sony Bravia KDL-32P3000
Does anyone no how to do this ?
I know how to get into the service menu, but it doesn't seem to have a factory reset ?
  • pkk367 Apr 27, 2013
    What is the factory reset for KDL-40EX520?
Just talked with Sony Support today.
It seems that Sony in Denmark had sent out new software updates (over DVB-T) but also some wrong TV's got updated as well. This caused my DVB-T tuner to not function anymore so I wanted to try a factory reset and it fixed my problem.
So I was instructed on how to do this. I have a Sony Bravia KDL-32P3000 (which should be similar to the U3000 and S3000 as well).
This is how to do a factory reset of your Sony Bravia KDL-32 P/U/S-3000 TV.
PLEASE BE VERY CAREFUL WITH THE SERVICE MENU, YOU CAN EASILY CAUSE YOUR TV TO MAL-FUNCTION!!!! IF YOU FOLLOW THIS GUIDE IT IS AT YOUR OWN RISK!!!
Set your TV in standy (use the green power butten on your remote), RED standby LED is ON on your TV.
Now press these buttons in this order on your remote (pointing to the TV).
i+
5
VOL UP (+)
GREEN POWER button
NOW BE CAREFUL! Dont press any keys just for the fun of it!!! IT MAY DESTROY YOUR TV.
You should now be in the service menu. It will show up as some green letter/numbers spread over the screen (mine are a bit hard to see/a bit faded). In the upper right corner you should have 2 letters TT (two t's).
Now carefully press key 0 and then key 8 on your remote (they should be shown on the screen after the two TT).
Now wait a little while (more than 10 seconds) and your TV should reset with factory settings, just as if you had just brought it home from the TV store.
Best wishes,
Mads
Posted on May 15, 2009
    New Friend:
Thanks Mads, been trying to solve this problem for a couple of months now !! Working on 32T3000 so will probably work on any KDL---3000 model :)
Posted on Apr 13, 2016
    New Friend:
I read your article about resotore factory conditions on sony bravia kdl-32p3000. If I'm working with a SONY BRAVIA KDL37S4000, should I input 0 and 8 after the double t's (TT) on the menu apperared, or is there another code for this model of tv? thankyou very much
Posted on Aug 11, 2014
SOURCE:
I have a sony bravia kdl-52xbr9 that flashes Bravia for 1-2 seconds and goes black with no sound. I am unable to get a menu or change inputs. I tested the screen with a flashlight at 45 degrees with no...
Do a hard reset to this set, and check. if it do not help you, its main board is faulty. There are two ways to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Mar 20, 2016 | Sony Bravia KDL-52XBR9
Resetting my sony KDL-52V4100
Your tv probably has a remote. One of the buttons says "menu" or "settings". In one of those menues will be a reset to factory or default.
Feb 26, 2015 | Sony Bravia V-Series KDL-52V4100 LCD TV
How to do a complete factory reset of a Sony Bravia KDL-32s5600 ?
  1. Turn on the TV.
  2. Wait approximately 40 seconds for the TV to completely start up.
  3. On the TV remote control, press and hold the UP ARROW button
Jul 07, 2014 | Sony KDL-32S3000 32 in. LCD Television
How do I reset a Sony bravia KDL-32v5500 back to factory default settings?
To reset it to factory settings, you have to enter its service mode option. If you wish to get more details, about how to enter, adjust and exit the service mode, check the site linked here. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 25, 2013 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
My sony bravia 40'' TV video in 1 and 2 is showing lock, how can i go about it.
try to reset tv from service menu sony service menu display 5 vol+ power from remote and see the reset menu and reset whole tv functions.
Dec 27, 2011 | Sony Bravia KDL-40S4100 40 in. LCD TV
Sony bravia model kdl-46z4100 has no sound. picture is ok.
Tries tv unplug,replug it back about an hour later for the tv for a resetting back to the factory setting.Go into the tv menu go to Audio Setting go down to do a resetting back to factory setting.These steps will help the tv to get the tv audio back.
Jun 11, 2011 | Sony Bravia KDL-46Z4100 46 in. LCD HDTV
Sony bravia v series 32"
hi,
IT normally happens after factory reset is done. You need to reprogram the channels. Try the auto program (AUTO TUNING) Process.
  1. On your remote commander " Press HOME or MENU button"
  2. Scroll down to " SETTINGS or SET-UP"
  3. Then to "CHANNEL SET-UP"
  4. Select " AUTO PROGRAM " To Auto program your LCD TV and it's done..
Jan 03, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Left half of my TV screen is completely white
That is only available to Sony authorized servicers. See esupport.sony.com
Jul 31, 2010 | Sony BRAVIA KDL-52S4100 52 in. HDTV LCD
When turning on TV, sound is often absent.
Unplug,replug the tv about an hour later,let the tv reset itself.Tries goto tv menu,go to AUDIO,go down to reset the audio setting,back to factory setting.Goto menu to PICTURE,go down to reset,to resetting the Tuner board back to factory setting.The sound,should be there,now all the time.Not,than the Tuner board have problems.That the board,where the broscasting signal cable plug into it.That the Tuner board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Jul 23, 2010 | Sony Bravia KDL-40V5100 40 in. LCD HDTV
Why dose my tv guide not work anymore?
This will probably be down to some software issue, try getting into the service menu and reset to factory, google for service menu
Mar 05, 2010 | Sony Bravia KDL-46Z4100 46 in. LCD HDTV
Sony KDL-32S3000 32 in. LCD Television Logo
36,359 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
