Question about Kyocera Mita Mita Copier Toner Cartridge for Mita KM-1525, 1530, 2030 - Black
I Keep getting a j10 display when I try to print on the display
I have switched off the copier switched it back on but the error is still there, that is i keep getting a j10 on the display
  • 46 Answers
A J10 shows up if there is no feed from the upper paper tray. Check the operation of the paper feed clutch for the upper drawer.
Good luck,
Peter
Posted on Dec 27, 2013
6ya staff
SOURCE:
Malfunction c3451 detected for bizhub 250 konica minolta
Try this It could do the trick for you.
The error code c3451 refers to a copier warm up error; the machine had not reached the correct temp within a specific time.
I bet it happened when you first switched on one morning.
Easy to reset and fault usually goes away.
To Reset switch machine off using the switch inside the front door, not the one on the control panel.
Whilst holding the UTILITY key down on the control panel switch the machine back on keeping the UTILITY key held down. Eventually a Trouble reset key will be displayed in the LCD screen, touch this, OK will be displayed then power the machine off and then back on.
This will reset the error code, if the code reoccurs then there will be a problem with the fuser unit in the machine, and this will require replacing.
Read More...
Error Message C3451 and Printer Support and Konica Printer Support
Jul 23, 2014 | Office Equipment & Supplies
What if the machine is showing c3451, what should we do?
Hi Stephen,
This error code c3451 refers to a copier warm up error; the machine had not reached the correct temp within a specific time.
Try resetting it by switching machine off using the switch inside the front door, not the one on the control panel.
This will hopefully reset the error code. However, if the code reoccurs then there will be a problem with the fuser unit in the machine, and this will require replacing
Apr 25, 2014 | Konica Minolta Office Equipment & Supplies
I have a fijifilm 8.2 J10 I don't know how to get date/time to print out of picture for verification
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
May 03, 2011 | Fuji FinePix J10 Digital Camera
Brother MFC 465CN won't print due to "Unable to
Hi Good day!! try this method
1.pull out the AC plug
2.put back the AC plug while holding down the "menu" button and keep holding it (15 sec)
3.now you are entering the MAINTENANCE mode and "error 46" pops up in the display
4.select 8 by using the arrow buttons ,push OK and select 0 and push OK
5.00:00 00:01 OK (the display is showing this message)
6.now push the MONO button 25 times until you see PURGE: xxxxx
7.Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
8.the purge counter indicates now: purge: 00000
9.switch off the printer ,switch it on
ready to print
Nov 19, 2010 | Brother Office Equipment & Supplies
Error code 928 service erase lamps
Erase Lamp Service Check (010/212/414/616)
Error code 928 may be displayed when the printer detects that the erase lamp assembly, cable or engine board is defective.
Note: If the erase lamp assembly is defective, both the erase lamp and lens are replaced as a kit. Models 41b/41e/41l and any model at service level B do not have erase lamps installed. Go to "Printer Serial Label" on page 7-2 to identify the printer service level. Make the following checks when a 928 service error displays.
1 Cable, Front Harness
Check the connection of the front harness to connector J10 on the engine board for correct installation. If incorrect, repair as necessary.Check the front harness to erase lamp assembly for correct
2 Engine Board Remove the controller board and toner cartridge from the machine. Ground pin J10-15. The erase lamps turn on. The lamps can be observed through the front of the machine with
the cover open and print cartridge removed. If the lamps do not turn on, measure the voltage on J10-14. The voltage reads approximately +24 V dc. If incorrect, replace the engine board. If correct, check the voltage at J10-15. The voltage reads between +15 V dc to +20 V dc. If incorrect, check the continuity of the erase lamp lines in the main harness. If incorrect, replace the cable harness. If correct, replace the erase lamp assembly.
Oct 19, 2010 | Lexmark Optra T612 Laser Printer
How do you make the dat/time stamp print with the fuji finepix j10
Aug 26, 2010 | Fuji FinePix J10 Digital Camera
Fuser error 924.01
924 .01
Open thermistor check
failure. Fuser page
count between 0 and
99,999.
• Noisy thermistor signal.
• Intermittent connection.
• Thermistor cable not connected or
thermistor actually open.
Go to “924.xx—Hot fuser
service check” on page 2-91.
Error Code 923.xx, 924.xx, and 925.xx may display for a hot fuser failure.
CAUTION: .The fuser may be hot, use caution before removing or servicing.
CAUTION: There is a danger from hazardous voltage in the area of the printer where you are
working. Unplug the printer before you begin, or use caution if the printer must receive power in
order to perform the task.
Service tip: Set the Fuser Temperature to NORMAL before starting this service check. In Diagnostics mode, In
Diagnostics mode, select EP SETUP, and Fuser Temp.
1 Fuser assembly
Fuser to system board
cable
Check the thermistor cable for correct installation to J5 on the fuser
card. If installed correctly, check for correct installation of J10 on the
system board. If all cables are installed correctly, go to step 2.
2 Fuser top cover assembly
(thermistor/thermistor cable
assembly)
Turn the printer off and disconnect the thermistor cable from J5 on
the fuser board. Measure the resistance between the two pins on the
thermistor cable, if the resistance measures infinity (open circuit),
replace the fuser top cover assembly.
3 Fuser to system board
cable.
System board
Fuser assembly
Reconnect the thermistor cable to J5 on the fuser board. Disconnect
the fuser to system board cable from J10 on the system board and
measure the resistance between J10-3 and J10-4 on the cable. If the
resistance measures infinity (open circuit) check the continuity of
pins 3 and 4 of the cable. If correct, replace the fuser assembly. See
“Fuser assembly removal” on page 4-26. If incorrect, replace the
fuser to system board cable.
Note: If the error code still displays, replace the system board. See
“System board and inner shield removal” on page 4-76.
Most likely just replace the fuser (part of usage kit)
Enter Diagnostic mode:
1. Press and hold (Down Arrow) and (Up Arrow).
2. Turn on the printer.
3. Release the buttons when Performing Self Test displays.
Mar 29, 2010 | IBM Infoprint 1572 Laser Printer
Konika minolta bizhub 350 Error c3451
Hi there.
e replacing.
Hope it did work for you.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 16, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Error Code C3451
Where exactly is the switch because if you open the front door there is only the door sensor actuater and I dont seen to see the switch. Is it under the covers
Feb 06, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Kyocera Mita Mita Copier Toner Cartridge for Mita KM-1525, 1530, 2030 - Black Logo
298 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Adorjani Laszlo
AAAA262430
Marvin
Marvin
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
