Question about Sony BRAVIA KDL-52XBR6 LCD TV
How do i get the picture and picture to work? I have a FiOS cable that runs from the wall to a splitter. One cable then runs to the DVR Set Top Box, and the other cable runs to the Cable/Antenna plug on the back of the TV. I press Input on the remote and select P&P, and the Left Side shows what's on the Set Top Box. But the ride side allows me only to change the "channel" from 2 to 6, and none of the channels displays any content.
5 Suggested Answers
SOURCE:
SOURCE: 'No Signal' on Sony XBR
on the tv remote: press menu, external entry is highlight (yellow) right press on the outer circle then scroll down to video 4 (satellite entry) (it could be on video 3 depending of the satellite assignment entry) when video 4 is highlight (yellow) right press on the outer circle on the screen you will see 1080i if settle on an HD channel hope it will fix your Sony Bravia..
Posted on May 30, 2007
  • 84 Answers
SOURCE: On Timer - channel selection
The on timer will only work for a channel on this model not for any other inputs
Posted on Mar 23, 2008
  • 320 Answers
SOURCE: KDL-32XBR6
Try resetting the TV by holding down the "up" button on the remote (with the TV powered on) and then, while you hold down the up button on the remote, hit the power button on the TV. This should do a "factory reset" which will wipe all settings in the TV. There is no reason why the TV should not "remember the last input it was on when it was ;last turned off. Also be sure that the TV is not plugged into a switched AC outlet, like the outlet on the back of the cable bix. The TV should be plugged into an output that receives power at all times.
Posted on Oct 19, 2008
  • 7 Answers
SOURCE: Cant get TV to go off of channel 2?
try menu, then set up, make sure tuning band is set to cable if u have cable or air if your using antenna, then go to auto serch for channels
Posted on Jan 05, 2009
Wont connect to verizon dvr box, its connected to the video out cable and the fios tv cable.
Make sure that the dvr is not outputting a HD signal to your set - if it is, your set will not work unless you change the signal to 480 from the HD setting.
Dec 11, 2015 | Televison & Video
Verizon fios set top box
well basicly you have to make sure all the right cords are hooked up right if not do so if it still doesnt work GET AN NEW ONE!
Oct 16, 2013 | Sony BRAVIA Televison & Video
I have a Motorola QIP6200/64xx DVR set-top box thru Verizon
The best code I could find was "007"
"210" kind of works, but can't compete with Mr. Bond.
After programming "007", if there are any features of you FiOS remote that do not work on the HK AVR 354 remote, simply follow the HK AVR 354 manual instructions to "learn" additional commands. See the last paragraph on page 31 through letter "e" on page 32.
Cheers,
Jeremiah Pattison
Keywords: Harman Kardon AVR 354 remote code to control FiOS DVR PVR STB cable box QIP 6416
Oct 28, 2009 | Motorola Televison & Video
HDTV goes blank when connected to Fios HD-DVR or Fios DTV recvr.
If you can first connect the Fios box via component and that will rectify the issue and still allow HD. HDMI is funny, if there is anykind of communication issues between the TV or the Fios box you see what happens. You might also call Samsung to see if there is ANY firmware/software updated for your TV specifically to fix such an issue with the Fios/Mortorola connection. If there isn't then the issue is the cable box since the TV works ok on HDMI with other devices.
Jul 23, 2009 | Televison & Video
How do i hook up my 16-454 to my verizon fios cable?
I am not sure what a FIOS use, but I was able to split my cable connection and was connect my regular TV AND portable tv with the cable.
IN YOUR CASE:
Look at your fios set up box, behind the box, there should be something that would say "TO TV" or "VIDEO OUT" or "TO TV/VCR"
Usually, the cable coming out from there goes to your regular TV. So instead of your regular TV, you can connect that with your portable TV.
AS FOR MY CASE (Having 2 tv's),
1. I removed the cable that is connected to the wall (RF IN or From WALL or CABLE IN).
2. I hooked that end to the "IN" part of a 3 way splitter
3. I bought a short cable and connected one end to the Cable Box and the other end to the OUT of the splitter
4. I bought a longer cable and connected one end to the portable TV and the other end to the OUT of the splitter.
5. Then I turned on the TV and pressed MENU
6. I clicked the right arrow until I see ANTENNA. I pressed the down button to choose CATV instead of AIR.
7, I did auto scanning.
My portable TV now has the basic channel while the big TV (since it is connected to the cable box) has the added digital channels. Nevertheless, it is great to have both so when I want to sleep, my hubby can just use the small tv
Jul 02, 2009 | Accurian 16-454 Television
Philips TV HDMI CEC EasyLink tries to control Cable set top box
I finally found a fix to this! YAY. I thought I might have to return the TV. I have the Phillips 42PFL5603D, but should work for other models.
On the TV press menu picture settings---picture---dynamic contrast (turn off) AND active control, turn off
If you have Comcast Moto box: on the Cable box go menu--->setup--->cablebox set up---RF BYbass set to ON
If you have a non-Comcast Moto Box, I'm sure there is an RF bypass setting in the menu. You'll just have to look for it. Another fix was close saying to only turn of the active control, but it took all 3 of these for it to work consistently. The latter let it work for all of 30 seconds.
Dec 29, 2008 | Philips 42PFL7403D/27 42 in. LCD TV
Motorola cable box remote codes
Its not going to work unless it is authorized by the cable company, and has the correct software.
Oct 17, 2008 | Motorola Televison & Video
VCR to TV
Your FIOS box is typically a Motorola Digital Cable Tuner. In order to record from the VCR your FISO will have control of the tuner, not the vcr. If your FIOS has two video outputs on it for video (av connections), one should be plugged into you tv set and the other should be plugged into the VCR input. Your cable tuner will have to be set for the channel you wish to record ahead of time while the VCR tuner has to be set to record the line input at whatever time you wish to record. If your FISO has one video output line (av connections), your VCR has to be set to channel 3 when you record (provided that is the channel your FISO box is set for when viewing TV over the coax cable) and you will have to attach the coaxial output from the FISO into the coax input of your VCR.
The only way around this is to get a splitter and split the coax line so that the FIOS is connected to the coax as it is now and the VCR is connected to a seperate line using the coax input, however using this configuration will prevent you from recording digital channels. If you have a cable ready VCR, it will probably only recognize channels up to 150.
If you really want to get it to record digital channels without the hassles find out if Verizon has a FISO box with DVR to it or connect a Tivo to your FISO. Tivo will tune the FSIO when it records and it's very user friendly to use.
Jul 28, 2008 | Sanyo DVW-5000 DVD Player/VCR
Can you help me?
go to verizon.com and look up fios tv and then from there go to installation and then troubleshooting
Apr 09, 2008 | RCA F27625 27" TV
Open Questions:
See all Sony BRAVIA KDL-52XBR6 LCD TV Questions
Sony BRAVIA KDL-52XBR6 LCD TV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
