Question about Sewing Machines
Bobbin problems my needle keeps hitting the bobbin case. the bobbin case will not stay in place it keeps jumping around. This started happening after i changed the feed dog. when i put the case back in place the machine runs perfect but from time to time the bobbin case shifts on me. does anyone have any idea what the problem could be? i have a singer creative touch fashion mate 1036 which is similar to the 1030.
    New Friend:
  • 14 Answers
I can only think of one problem and that is that you have not fitted it properly. Open the bottom section, remove the bobbin case with the cotton reel and with your fingers press against the parts left behind. You may find something is loose, therefor not fitted correctly. You can also run the machine whilst the bobbin is out and listen if there is any noise or anything shaking. Refit everything taking care that the parts fit tightly.
Posted on Jan 15, 2014
SOURCE:
  • 255 Answers
SOURCE: Feed Dogs, Thread Tangle
Hi Jeanette! You have a Singer Featherweight--the best sewing machine ever made! (Mine dates from 1950/51 and I wouldn't trade it for the world.) These beautiful, sturdy machines were designed to be easily repairable at home, but you'll need a copy of the Service Manual (get the Instruction manual too, if you don't have one.) Go to www.singer-featherweight.com and check out what they have available.
I had a similar problem (needle thread not catching the bobbin thread) and the problem was that I hadn't put the needle in correctly (flat side to the left). Also, I will occasionally get thread wrapped around the bobbin housing--sewing along just great and then everything comes to a screeching halt. I'm not sure why that happens, but I'm getting pretty good at taking the bobbin housing apart. The manual is pretty clear on how to do it. You can contact me direct at robbie1949@comcast.net for more information.
Thanks!
Robbie
Posted on Jan 10, 2008
  • 323 Answers
SOURCE: Singer-Inspiration 4220/4228
Send this machine back where it came from! machine. You have described a timing problem which you can not and should not need to do.
Change the needle first and test it to be sure the needle still hits on the hook. If it does,follow the above instructions. If it no longer hits then it's possible it is not as serious as I first thought.I'm not sure if the bobbin keeps coming out or the bobbin case(the plastic part the bobbin sits in) comes out.If it is just the bobbin, insert the bobbin in the case and pull on the thread. The bobbin should turn COUNTERCLOCKWISE. If it turns the other way, turn it upside down and try it again.
If it is the bobbincase,then Remove the needle plate and take the bobbin case completely out. On this machine there is a small lever which holds the bobbin case in position. Looking down on the bobbin case the lever is located at about 11 o'clock and has a small slot in it. It is also probably spring loaded which means it is not easy to turn without a small screwdriver. Insert the screwdriver in the slot and turn it to the left. Lift out the bobbin case and Carefully examine it for any nicks, scratches or rough spots. If you find any, they will need to be removed with an emery stick and or a sharpening stone. Buff with a very fine steel wool for total smoothness.
To replace the bobbin case use the screwdriver to open and hold the lever open while you insert the case back in. The straight part of the case will be on the right and you need to place the case so that the circular part rides on the slight grove in the hook.(The metal thing it sits on). Once you have it in place you can release the lever you've been holding open . It should fit over the edge of the bobbin case and not allow it to come out. Rethread the machine and turn it by hand a few times to see that it is working properly. Good luck!!!
sewman7
Posted on Jul 01, 2008
  • 23 Answers
SOURCE: Needle hitting metal casing .. Singer Futura CE 200
It happend to me aswell , not getting the source of the problem!
Then I noticed that the bobbin casing was out of the original position, take the whole casing out and make sure that when you put it back that the small metal tension loop at the front side on the right is correct, this image you can see in your handbook, (placement of the bobbin casing)
Posted on Feb 27, 2009
  • 87 Answers
SOURCE: bobbin case retainer popping out on Singer Touch & Sew 625
Take the bobbin case out. Then when you go to put it in, realize there are 2 ways to get it. You have found one way. The other way is first look in the the slot with a flashlight before you insert it. There is a flat piece of metal the bracket needs to be slid under as it is inserted. This acts like a spring making it tight
Posted on Mar 18, 2009
SOURCE: singer quantum cxl sewing machine needle hitting metal
Your needle is probably to long or you need to open it more
Posted on Apr 08, 2009
My Janome 8050 bobbin case is jumping out of place. The thread is wrapping around the bobbin case and getting stuck, bunching up, and shutting down my sewing progress. It ties the needle up.
check for the retainer action of the bobbin case to see in there is a part broken off that holds the bobbin in the case or carrier
from what you describe , with the thread bunching up etc, I suspect that the needle thread tension is too loose and causing the problems
if so then the bunching and problems can be from the bunched thread pushing the bobbin out of position
take it in for a service and if necessary , repair
Dec 20, 2016 | Janome Sewing Machines
The bobbin case catches the needle and the thread wraps around the bobbin case
If you are saying the needle is hitting the bobbin case when it goes down then it could be one of two things:
1. Bobbin case not all the way in. This can be caused by debris in the rotary hook or the bobbin case has been hit by the needle and has cracked/and or bent it. Make sure it is snapping into place correctly.
2. The rotary hook is out of time. Reset the rotary hook point behind the needle and about the middle of the scarf of the needle. Make sure you run the needle all the way down and as it starts back up this is where you set the hook.
Oct 01, 2014 | Consew 255RB-3 Mechanical Sewing Machine
Stitch tension problem - bobbin thread lies flat or bunches. If you increase the needle thread tension there is no improvement - even at the highest needle thread tension the bobbin thread is a mess. Any...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 16, 2011 | Consew 7360R-1 Mechanical Sewing Machine
Needle keeps jamming, won't thread
Good day!
Good day!
Jun 07, 2011 | Janome D'cor Excel Pro 5124 Mechanical...
Keeps skipping stitches and knots thread
Good day!
Good day!
Jun 06, 2011 | White Sewing 2037 Mechanical Sewing...
Cannot get the tension right and the thread keeps braking
Good day!
Good day!
Jun 05, 2011 | Singer Inspiration 4206
Re-curring loose bobbin case
According to the manual, this is a drop-in bobbin.
If the bobbin case came loose, the needle would probably hit it and brake.
Take the bobbin out.
Turn of the power and remove the needle plate (under the presser foot).
Raise the needle to it's highest position and lift out and reset the bobbin case into the shuttle. This should be in the maintenance section of the manual. The bobbin case should fit snug.
Make sure the thread is feeding from the bobbin, counter-clockwise and through the guides on the bobbin case.
For a rotary bobbin with a metal bobbin case.
Remove the bobbin case. Make sure the thread is feeding clock-wise and through the guide on the side of the bobbin case.
Raise the needle to it's highest position - this puts the hook at the lower left. Left the tab on the back of the bobbin case and slip the bobbin case back into the shuttle with the "arm" straight up. You may have to move the bobbin case a bit to the left or right for it to snap into place.
If the problem persits, take the machine back to the dealer - there should not be a charge for fixing this as it is brand new - keep your receipt and warranty information at hand.
Apr 24, 2010 | Singer 7442 Mechanical Sewing Machine
New Problem...I have a Singer CG-550. When I try and sew anything, the needle hits something inside where the bobbin is. The little black casing holing the bobbin keeps moving all over the place, I slip...
On the right of the black bobbin case there are two screws, you can slacken those screws off and move the bobbin case nearer to the guard leaving enough room for the thread to pass through, if the needle is hitting the bottom you may need to retime the machine.
Mar 06, 2010 | Singer Sewing Machines
sewman7
Jun 30, 2008 | Singer 7442 Mechanical Sewing Machine
Sewing Machines Logo
162 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
