Question about Sony Bravia KDL-40W4100 40 in. LCD HDTV
I cannot connect my picture in picture icon for my bravia
I bought a windows 8 envy computer with all the bells and whistles to replace my old hp pavilion. in I reconnected my Sony Bravia KDL-40W4100 from my old hp to the new one and what I loved about it is the picture in picture which won't connect to my new computer it stays grey in color and wont let me open it and I don't know what to do. the tv works fine as it did on my last computer but no pip please tell me who is smart enough to get it to work or can you help me
SOURCE:
  • 4234 Answers
SOURCE: Sony Bravia KDL-40W4500 turns off
This can indicate a problem with the high voltage circuits. Since this is a new set, it should still be under warranty. DO NOT open up the unit as that will void the warranty. Return the set or request warranty service. Note the 8 blinks when you request service as that should allow them to bring the correct replacement parts.
Keep us posted.
Dan
Posted on Jan 05, 2009
  • 718 Answers
SOURCE: i need a manual for sony bravia KDL 40W4100. Where
KDL 40W4100
Go to;
http://esupport.sony.com/US/perl/model-documents.pl?mdl=KDL40W4100&LOC=3
and click on the manual you need. Several are listed.
Posted on Apr 12, 2009
vinnyq
  • 157 Answers
SOURCE: sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
Posted on Oct 07, 2009
tvhelp-Dave
  • 178 Answers
SOURCE: Bravia KDL-46VL130 TV: Our Sony KDL-46VL130 picture is streaking and some...
That symptom may cause by the main board or t-con board, I suggest you do software up grade first.
Posted on May 07, 2010
SOURCE: I have a sony Bravia KDL-52W3000 LCD tv. Approx.
I have the same tv with the same problem. My tv is about 3 1/2 years old. I took it to the shop yesterday and today they told me that I had a bad lcd panel and a bad FL1 circuit board. They also told me it was going to be $3800.00 dollars to fix. I am now on my way to buy another tv, needless to say it will not be a Sony. Sony knows about this problem and refuse to do anything about it. Good luck.
Posted on Jul 28, 2011
How do I connect my laptop (wireless) to my HP printer envy 5660 (wireless)?
Connect your 123.hp.com/envy5660 printer after the printer hardware setup before you print or scan from a computer through a wireless network. Install the HP printer software from a wireless network from a computer with Windows 7 or later.
STEP 1 : BEFORE INSTALLATION
  • If you want to connect the printer 123 HP Envy 5660 Setup to your wireless network, make sure you know the network name and password.
  • Connect your Windows computer to the wireless network and make sure the HP printer is compatible with the wireless
  • Obtain the network name (SSID) and network passphrase (WEP key or WPA). A broadband internet access is must be used. Make sure you have the USB cable provided along with the printer package.
  • Turn on your printer, router, and computer and make sure the computer is connected to the same wireless network you want the printer to connect to.
  • If you have connected any USB cable to the printer, disconnect it before you proceed with the software installation.
  • Follow the instructions to remove the USB installation if it was previously setup on your computer before you continue:
  • Search for the HP folder in the list of installed software programs, click the HP printer folder, and then click 123.hp.com/envy5660
  • Once the HP Printer Assistant software opens, click Utilities -> 123.hp.com/setup 5660 & Software Selection.
  • Continue to follow the prompts and click Convert a USB connected printer to wireless or Connect a new printer.
  • To complete the software installation, follow the on-screen instructions.
  • You can also run HP Print and Scan Doctor, an automated tool to connect the printer to your wireless network.
STEP 2 : CONNECT TO THE WIRELESS NETWORK
Connect your 123.hp.com/envy5660 printer to the wireless network using the built-in Wireless Setup Wizard to identify network name and entering the network password.
  • If the printer is not turned on, press the Power button to turn it on.
  • On printer's control panel, touch the Wireless icon to preview the Wireless Summary screen.
  • On the Wireless Summary screen, touch the Settings icon and then touch Wireless Settings.
  • Under the Wireless Settings menu from 123.hp.com/setup 5660, select Wireless Setup Wizard and follow the on-screen instructions to complete the setup.
STEP 3: DOWNLOAD AND INSTALL HP PRINTER SOFTWARE
Download the supportive 123.hp.com/envy5660 printer software from our website once the printer is connected to your wireless network.
  • Turn on your HP printer and eject any USB cable if connected to the printer.
  • Go to our website and navigate to the download page where you have to download the printer software manually.
  • Select your printer model when prompted and then, follow the on-screen instructions to reach the download page.
  • Next, to the full feature, click Download or click Basic Drivers.
How to solve HP Printer issues 5X Faster Answer is inside
Jul 26, 2018 | HP Office Equipment & Supplies
HP Envy 4502 here at the house. Wireless icon is on, I go to printable......it tries to connect a connection error, stating it can't connect to the server
(answer 1)you suck.! your ignorance, does.!!!richie46
HP has great help forum. (ask, fixya is the suck form)
ask for where HP is, its not here, but vast resources do exist.
learn to use them..
not blame them for not answering 1,000,000 calls a day. (vast installed base if you learn that, you'd go OMG really)
OP
i guess this is a printer only problem.?
right?
and no service tags posted on both PC and printer
No PC stated
the
HP Envy 4502(all in one)printer I have the J4580 , use it only for scans, i hate injets. laser are my bag,
the first step is install the driver
DRIVERS
http://support.hp.com/us-en/drivers/selfservice/HP-ENVY-4500-e-All-in-One-Printer-series/5304875/model/5368521
real forum
here it is , see it? ask there,
even read 10000 of others with same problems
most are simple. but
no PC stated, nor what Opereating system it runs.,
pc example what is YOURS.
use the USB cable to print
if you dont you get to learn now to get the printer
to connect to your unstated wireless router, that I refuse to teach here, ever.(set it to a static IP for the printer , lean how)
Mar 21, 2017 | HP Computers & Internet
I have just bought a hp envy 23-k210na23 touch screen.how do I get started?
The power button is on the top right of the screen. Once it is powered up you will need to setup Windows 8 by following the onscreen instructions. From there you can find a guide on how to use the machine by swiping from the right of screen across the display. This will bring up a "Charms" panel with a spyglass (search) symbol. Tap that and then search for anything you wish to learn about. It will start giving you suggestions when you start typing. Also, go here:
HP Support
Mar 06, 2015 | HP Computers & Internet
Why hp envy won't let me partion on their 1tb hd
I would use windows to partition the drive. Type computer management into the start search box, select disk management and change the hdd size by reducing it and then format the new drive.
Dec 09, 2014 | HP Computers & Internet
When I try to open any photos on my hp envy laptop i get error message "this app can't open"
See if you can open pictures on your machine by this method
locate your pictures - usually on my pictures
right click in one of them - select "Open With" and choose Windows Photo Viewer
check if your picture opens up.
Oct 18, 2014 | HP Computers & Internet
My printer will not print
Use the troubleshooting guide that should be in your printer's manual. There are many things that could go wrong including how software is working in your computer. There should be a troubleshooting guide in the manual, HP makes many different kinds and models of printers there is not one solution for all. Also check at the HP Support website for further information or assistance.
Oct 21, 2013 | HP Office Equipment & Supplies
Sony Bravia KDL-40W4100 40 in. LCD HDTV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
