Panasonic LCD TV Modeel No: TX-26LXD8A has vertical coloured lines that change colour depending on the program/picture. It began with a vertical red line near the centre of the screen and now there is no picture, just the coloured lines. Sound works fine, have checked all connections and they are okay. Warranty has expired. Can you anything be done to fix this, or is it better to get a new TV? Are any brands less likely to have problems? Please help! Thank you....
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 50 Answers
Other than taking the television to a repair shop not much can be done. I recommend a new television. Excellent brands are Sony, and Samsung. Both brands are quality televisions. Best of all you can order them on Amazon.com for lower prices.
Posted on Jan 23, 2014
Testimonial: "Thanks... Have seen complaints and questions about similar problems with Sony and Samsung TVs as well.... I would need to replace a smaller size screen (due to small space) I live in Australia so no ordering from Amazon, lol."
6ya staff
SOURCE:
Anonymous
  • 50 Answers
SOURCE: thin red vertical line on sanyo lcd-37xr1
Sounds like your display panel is going out. Has the tv been droped, or hit by anything? You should call your customer service number to confirm.
Posted on Feb 27, 2008
David Low
  • 458 Answers
SOURCE: vertical red line about 3mm wide near centre of
Any fault of this description is normally a fault with the screen. The only way to remedy is to have the screen replaced.
Posted on Jun 30, 2009
roety
Eric Rotmil
  • 587 Answers
SOURCE: Red line on screen, Plasma TV help.
Hi my name is Eric,
I hope I can help you with your issue ,
If the lines are there on every input then you have a bad panel (screen). The panel is the front screen section, if you could get one a new panel would cost more than a new TV. If the line is only there with the cable box then its just a bad box (I've seen the pace box do this)
If I have helped you with your issue please click accept.
If you have more questions you can still respond
Thanks
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Posted on Sep 26, 2009
Anonymous
SOURCE: I have coloured vertical lines covering my Sony
I also have a 2 yr old Sony KDL32xbr4 that now has multi-colored vertical lines on the screen. I contacted Sony and they say they have "no known issue" of this sort for this model. I find this rather puzzling since I have found numerous postings on the web. They told me to try the factory reset. Whatever. Might as well have said "don't buy a Sony". 2 years! $1300 for a tv and it lasts 2 years! Makes me sick to my stomach.
Posted on Jan 29, 2010
Anonymous
  • 65 Answers
SOURCE: panasonic viera with vertical lines down the screen
Either the buffer board is bad or the plasma panel,sometimes it coult be bad connections on the interconnect ribbon cables from the plasma panel to the buffer boards.
Posted on Mar 19, 2010
Panasonic tx-32lx60a colour gone all red/dark
Ur Main Tuner signal board is dead.Replaced this board will fix this problems.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
Mar 13, 2010 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Hi I have a Panasonic LCD TX-32LXD there appears to be a line across the screen. It is about 1" 1/2 wide. but is completely see through and depending on what colours are on the screen depends how bad it...
Hi There,
Try restore the tv to factory state. It could be a burn in from a tv station you always watch eg. Some lcd will have a non burn in function, What that means simply is if you watch mtv all the time it will leave the mtv sign in the corner as its burned into the tv. Depends on how old the tv is restore and see what happens from there, other than that get an engineer or replace it if its still under warrenty....Hope this helps
Nov 17, 2009 | Panasonic TX-32LXD1 32 in. LCD Television
Laptop screen displays vertical lines of various colours
Have you tried to connect your laptop to external monitor?
If you get normal picture on external monitor, then you need to replace LCD screen, but if you get same picture on external screen, then unfortunately you will need new motherboard, because graphics card is integrated to motherboard.
Aug 13, 2009 | IBM ThinkPad R52 Notebook
Problem with panasonic tv
It is usually caused by problems from lead solder that sometimes does not connect, so there are some points of the components that are not connected with lead solder to the circuit. if it appears vertical line means from the IC (integrated circuit ) Vertical, you can solder all the points in the IC ( Integrated circuit ).
Sep 07, 2008 | Panasonic TX-32LX1F 32 in. LCD TV
Colours on TV Panasonic TX-32PL10 5/6 years old
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
Feb 11, 2008 | Televison & Video
NEC MT800 Projector with Vertical Lines in picture
The ghosting problem is a combination of both the lcds and driver boards in which case neither need to be truely replaced.. They use a specific voltage to transmit data to the lcds.. Each lcd is different and the driver board is programmed by the factory for the EE v.com setting. Unfortunatly with nec, they do not offer a service mode to go in and adjust the ee settings to correct the electrical convergance. So the only way to fix the problem is to replace the lcd with a newer one who wasnt worn out from long term heat.
Sep 22, 2007 | NEC MultiSync MT830 Multimedia Projector
Televison & Video Logo
97 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
