Question about Sony Bravia KDL-40V4100 40 in. LCD HDTV
HOW TO GET MY KDL-40BX421 OUT OF HIBERNATION MODE
HIBERNATION
I have a Bravia KDL 40BX421 that suddenly has green vertical lines on the bottom 1/4 of the screen. These lines are in a background bar that is mostly a reddish shade.
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/.../1127410-thin-vertical-lines-cover-screen-samsun...
Mar 7, 2009 - 30 posts - ā€Ž25 authors
Hi guys, Ive had this TV for about a year now - all of a sudden thin vertical lines havecovered my screen (show in link below) No matter what ...Missing: 40bx421
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... hi i have a sony bravia mdel # KDL46EX523. i have horizontal multi colored lines ... My TV has the following symptoms: - Horizontal lines from top to bottom of .... thick(like 1-1/12 inch) and a couple of green vertical lines next to the black one.Missing: kdl ā€Ž40bx421
Flat Screen TV Has Lines Going Through Screen - Possible ...
Dec 16, 2015 | Televison & Video
WHAT IS THE KEY CODE FOR TV modelAEG 4812 ST/VT????
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
Jul 15, 2015 | Sony Remote Control Originally Supplied...
HpPavilion DV 1000 stuck in hibernation mode
It will eventually come out of hibernation mode, when that happens go into power setting and select hibernation, next uncheck box on the left and click apply, this will disable this feature and should have no futher trouble.
May 29, 2012 | HP Computers & Internet
Why does my Sony Bravia LCD KDL-40BX421 TV spontaneously reboots itself?
Great that its under warranty!
Without troubleshooting inside the TV guess is not easy, there are only two boards in this model PowerBoard and Main Board, if the screen is bad its a automatic replacement. If purchased locally stores usually have a customer satisfaction 30 day return policy, good luck
Iā€™m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
May 02, 2012 | Sony BRAVIA Televison & Video
How can a get the blank screen to go away when I try to wake up my laptop from hibernation mode?
you can try to disable hibernation mode by going to Control Panel>Power Options Properties>Hibernate
then un check the box for Enable Hibernation, then click apply and ok.
Sep 10, 2010 | Computers & Internet
My hibernation option is gone.....
Hibernation may be disabled by default in XP.
Go into Start > Settings > Control Panel > Power Options. Click on the Hibernate tab, then check the Enable Hibernation check box to enable it.
Otherwise:
You can start hibernation of your PC manually, if hibernation is enabled, by:
1. Selecting 'Turn Off The Computer'' from the Start menu.
2. Normally the left choice on the resulting pop-up window is ''Stand-By''. But, if you hold down the Shift key it becomes ''Hibernate''. So holding down the Shift-Key and clicking on the resulting ''Hibernate'' button (the left-most button) will cause your computer to start hibernation mode.
Note that many computers also have a button for starting hibernation mode also. Often pressing the Power button while the computer is on will cause it to go into Hibernation. (Sometimes desktop computers have this option disabled, but it can be enabled through some Setup menu item (unless a special key has been assigned to do it on the keyboard.)
Hope helpful.
Mar 18, 2010 | Compaq Computers & Internet
Question
Hibernation is a power management feature. When you hibernate a laptop, you're essentially turning it off. So, unlike Stand By (Sleep) mode, a hibernated laptop isn't using any battery power at all - that laptop is off!
The secret behind hibernation is that before you turn off the laptop, everything you're doing with the computer is saved. (The contents of memory are saved to the hard disk.) When the computer is turned on again, it recovers from hibernating by reloading all the saved information and restoring your laptop to exactly the same condition it was in before it was hibernated.
Briefly, hibernation works like this:
1. You activate the hibernation feature.
Hibernation is activated differently depending on how it's set up.
2. The laptop hums as everything in memory is saved to disk.
3. The laptop turns itself off.
It's really and truly off: The battery isn't being used, and it's safe to store the laptop or put it away until you need to use it again.
To recover from Hibernation mode, just turn the laptop on. In some cases, the laptop may recover from hibernation when you press a key or touch the mouse pad. hibernated state for as long as you want.
Hibernation mode requires hard drive space. So you should be aware that when hard drive space runs low, it's possible that Hibernation mode won't work.
In Windows XP, you have to activate Hibernation mode before you can use it. Follow these steps to activate Hibernation:
1. Click the Start button.
2. From the Start menu, choose Control Panel.
3. Open the Power Options icon in the Control Panel.
4. In the Power Options Properties dialog box, look for and click on the Hibernation tab.
If you don't see a Hibernation tab, there's your answer: The laptop isn't capable of hibernating. Oh, well.
You might want to check the laptop's Setup program to see whether you can activate Hibernation there.
5. Select the Enable Hibernation option by clicking the check box to place a check mark in the box.
6. Review other options, if they're available.
7. Click OK to confirm the changes and close the Power Options Properties dialog box.
Optionally, close the Control Panel window, as well.
Some laptops may require you to restart Windows for this change to take effect.
Sep 09, 2009 | Computers & Internet
Re move hibernation mode
press the power button for ten to twelve secons and it should reset
Mar 24, 2009 | HP Compaq Presario V2000 Notebook
I have an Acer 5633 that will not come out of hibernation. the on light comes on as does the led on the dvd drive and a fan runs for approx 5 seconds, then it just sits there like a plastic brick. I have...
Disable hibernation in the power settings. I've run across many computers that do not respond properly to hibernation mode, and that do the same thing. It's easier to simply disable hibernation mode and have it fall into sleep mode instead.
Apr 21, 2008 | Computers & Internet
Desk top won't display-hibernation mode
Based on your post of failure to boot due to hibernation, you can try removing the battery and AC adapter connection for an hour or so. Thereafter, insert battery back and charge but don't power up. Allow the laptop to charge for a couple of hours. Try powering up/booting. Press F8 to start in Safe Mode. Once in Safe Mode disable Hibernation.
If the laptop still fails to power up, then it may be entirely another problem.
Post back results. Good luck and kind regards.
Nov 04, 2007 | HP Pavilion dv4000 Notebook
Open Questions:
See all Sony Bravia KDL-40V4100 40 in. LCD HDTV Questions
Sony Bravia KDL-40V4100 40 in. LCD HDTV Logo
29 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
