Question about Westinghouse TX-42F430S Television
Unable to get signal input when i connect my pc
Unable to get signal input when i connect my pc to 42 inch westinghouse hdtv using hdmi ports
  • Anonymous Mar 30, 2014
    Westinghouse tv 42 inches changes input and also it goes to set up page were it asks you to choose were to connected to ( satellite,cable box ect)
  • 3 Answers
There are several fixes for this problem.
1) You can unplug the TV for a few minutes and try again.
2) You can turn off the TV then hold the Power button down for at least 10 seconds (resets the processor)
3) Go to the settings menu, select factory reset.
Good luck
Posted on Jun 11, 2009
6ya staff
SOURCE:
Suddenly, all three HDMI Ports won't receive a signal. Help!
Hi James,
The main board of your TV is not accepting HDMI input. You can use another AV input to watch the TV or you have to change the main board.
Aug 04, 2015 | LG 42LG30 42 in. LCD HDTV
When I switch from one HDMI input to another I get a no signal & spinning LG box. after several minutes it gets a signal
Try a different HDMI cable, then try the other HDMI inputs on the TV, then try to connect another HDMI device to the TV. If all are still bad main board needs replaced
Oct 19, 2014 | LG 55LK530 55 inch 1080p LCD HDTV, with...
Sound but the screen on my westinghouse 32 inch flat screen is solid lime green
By "sound but the screen on my westinghouse 32 inch flat screen is solid lime green" Do you mean that you have sound but the screen is green? If yes it means that an analog signal is being fed to a digital input. Did you recently change the input cables at the back from one port to another? If not then please describe what are colors of the cabels you are using(Yellow, Red, White or Red Blue Gren etc.,) and what port they are connected to so that I can tell you whether its a problem with the connections or the tv itself.
Jun 15, 2011 | Westinghouse 32" Flat Panel LCD HDTV
I'm staying at a Hotel in Atlanta that has 42 inch LG LCD TV's and I'm trying to connect a DVD Blue Ray directly to the TV with HDMI Cable and set the TV to HDMI input setting and Nothing happens except...
I would call the front desk. They usually have a maintenance person who can help you with the connection. If the TV HDMI port is not functioning, they may be able to swap tv's or move you to another room! Good luck!
Oct 09, 2010 | LG 42LC2D 42 in. LCD HDTV
I have a sony wega KDF42WE655 TV(42 inch). It has a HDMI port I recently bought a PS3 and hooked it up to the TV. With the HDMI port connected I do not get any picture or sound. Attempts of rebooting...
There is a separate IC on the main board that does nothing but process the HDMI signal, basically if your using the cable, AVI or any other input other than HDMI and chances are that is bad, it can be replaced if you have a lot of electronic experience, its a $3 chip but its not easy to replace..I would replace the main board if you can find one, sometimes main boards are hard to find..below is a link to the service manual.
Sony KDF 42WE655 Service Manual
Nov 23, 2017 | Sony Grand WEGA KDF-42WE655 42" Rear...
How can I use my lg lcd tv model m1994a for my ps3 there's no video signal,I try it all inputs to my lcdtv from av cable.component video,and hdmi cable still there's no video signal,but if I'll connect to...
I solve it already my problem by connecting my ps3 to an 32 inches lcdtv and I change the videosetting to my ps3 to default setting because before when I had my sony bravia 32 inches I changed it to 1080p via HDMI cable signal...After I changed to default settings I connected it again to my own LG lcdtv 19 inches but it sadly 1080p is not so very much supported but anyway I can play now ps3 games...
Nov 21, 2009 | LG 42LC2D 42 in. LCD HDTV
My HDMI ports won't work on my Westinghouse tx-42f430s TV. I have things plugged into 3 ports and they all quit working. I had to connect the composite cales to get my TV to work.???
FOUND A SOLUTION! (at least in my case) thanks to some creative Google searching...
Apparently the HDMI ports can get into a state where they are unable to negotiate the input signal properly. The way to "clear" the ports and allow the HDMI signal to be detected is to perform a "reset" on the unit.
Just turn the set off using the power button on the right side of the unit. Then, press and HOLD the power button for at least 10 seconds, then release.
The set should turn on and essentially do a "reboot" where it displays the Westinghouse logo. After that your HDMI ports should be functional again.
It worked for me :-) Best of luck..
Nov 06, 2007 | Westinghouse TX-42F430S Television
Westinghouse ltv 32w4 hdc 32.02 in. hdtv lcd tv / dvd combo
My 42" Westinghouse HDMI inputs just stopped working. I thought it was the TW Explorer 4250HDC issue so I got a new one from TW. Still said no signal from HDMI. So, I shut the TV down and pulled the power cord out of the back. I waited a few seconds and reconnected the pwr cord. The TV "re-booted" so to say and now the HDMI inputs work. I think TVTEK has the right idea that it is firmware/software related. In the mean time, you might want to give that a try.
May 25, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Televison & Video Logo
475 people viewed this question
Top Westinghouse Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
