Question about Toshiba 36A50 36" TV
Codes to make my Time warner remote control the tv
Can I get a list of codes to enter in to my remote, so the Time Warner Cable remote will control the tv?
  • 7 more comments
  • Steph2003 Apr 12, 2008
    I had an old Time Warner remote that would run the cable box and the TV. It broke, went to Comcast office, luckily they had one just like it, so I exchanged. It runs the cable box, but not the TV. All the codes Comcast customer service gave me did not work. Are there any codes that I can use? It seems funny that Time Warner could fix the same problem.
    I have an older Sylvania TV (MTS/SAP) is what is on the front.
    Any assistance would be GREATLY appreciated!
    Thanks!
    Stephanie
  • Anonymous Jul 05, 2008
    I have two(2) idenical Time Warner remotes. One will control the volumn and the channel up and down only. The other remote does every thing but the volumn. New batterys in both. Some one told me that they need to be '"programed"
  • Anonymous Feb 05, 2009
    i need the codes to program my time warner remote to my tv
  • Anonymous Feb 13, 2009
    Time Warner just pushed a new website. Like most of what they do, it's terrible. They didn't post copy sections over from the old website so I guess someone just forgot to add the remote codes.
    The FAQ section has an 'answer' about remote codes and basically just tells you to go to their support section (where the hell is that?) and does not provide a link. I'm still looking. I'll a link if I find one.
  • CrownRock Feb 19, 2009
    My friend bought a new HDTV, and gave me his old SD (which is better than my old one). We have the same model remote, which he never had a problem with, but I've spent 15+ minutes straight scanning for a code with no positive results. After five minutes though, scanning will change the channel (instead of turning the device off, as it should).
  • Anonymous Mar 03, 2009
    i can't program anything
  • Anonymous Apr 14, 2009
    I have a ILO 42" plasma tv & need the code to set the Time Warner remote control. Any assistance would be appreciated.
  • misterfix500 May 11, 2010
    BEST SOLUTION is HERE!
    You can thank me later! :-)
  • remote_fixer May 11, 2010
    I was looking for it for quiet some time, until I found it for free here -
    universal-remote-controls.blogspot.com.
Here's the list from Time Warner
http://www.timewarnercable.com/Carolinas/site.faqs/Equipmenta/Remotes/Digital-Remote-TV-Codes
Posted on Mar 22, 2009
It's online, I just programmed mine in 3 minutes. I did a google search for "time warner cable remote UR5U 8700L." The UR5U 8700L is written at the bottom of my remote on the front, its likely that your remote will be a different model number.
The first hit that came up was the time warner cable Q&A. In the Answer section it says "click here to watch the tutorial." Press on the "click here" and it will bring up a very simple/slick/intuitive interactive tutorial that walks you through it.
This is how I did it. I would help you get your codes and give you the steps but I don't have your remote number or your tv model. Good luck.
Posted on Feb 17, 2009
Http://www.timewarnercable.com/Albany/learn/cable/remotes/default.html
I found this site. It worked for me.
Posted on Feb 19, 2009
  • 93 Answers
Wuts the model# of the remote
Posted on Oct 29, 2007
RC1475506/01B
Posted on Sep 21, 2008
Http://www.timewarnercable.com/centralny/customer/cable/remoteguide.html
Posted on Dec 14, 2007
SOURCE:
Time Warner codes for Mitsubishi tv
If Time Warner remote is universal, you probably can use its code search feature to find something that will control your Mitsubishi TV. Also, Time Warner might be able to tell you what code to use.
Jan 14, 2015 | TimeWarner Cable Time-warner cable...
Where is "set" button on the remote so I can set DVD code?
You need to be using the TV's remote, not the Time Warner remote.  You are reading the TV's manual to set it's remote, not the Time Warner remote.  If you want the Time Warner remote to operate the TV, you will need to find the instructions that the Time Warner box/receiver provides and enter the TV's code.
Mar 24, 2009 | Toshiba 36A50 36" TV
My tv remote quit working. I would like the code for Daewoo TV, model No. DTQ-13P2FC to enter in another remote.
For Time Warner Cable TV Remote Codes for DAEWOO-TV's - Go to Time Warner Cable web site to PROGRAM REMOTE -- Site URL is http://www.timewarnercable.com/en/residential-home/support/pyr.html Then select TW Cable remote model. Under Control a Device -- first select type of device (TV) Then select Brand Name (DAEWOO). TW Cable lists several codes to cover different models. Choose a code and input into remote to see which code works. Try all codes. There were several codes to choose from and to try inputting into my TW Cable remote. Finally, the next to last code worked on my TW Cable remote -The Atlas OCAP 5-Device Remote Control by Universal Electronics. The code for this remote for Daewoo TV Model DTQ-13P2FC is 1661. Hope this helps. Otherwise, try checking the site of your cable or satellite provider & you should be able to get their add device codes for free.
Jun 21, 2011 | Daewoo DTQ-13P2FC 13" TV
Need Time Warner Remote code for LG 42LB5D HDTV
For Time Warner Cable digital remote controls to work with your 42" LG HDTV, do the following:
1. Press "TV" and "OK" simultaneously for 3 seconds, until the button "tv" light on the remote is on.
2. Enter the TV code. In this case, it's "113". With the right code, your component will turn off. Quickly press the power button on your digital cable remote to turn it back on. Press the "TV" button again so that the remote saves that code.
3. You should be done.
Feb 08, 2010 | Directed 434MHZ Remote Control
How do i program this remote to my time warner cable box
Time Warner is most likely made by another company and they are not listed on the programming documentation. You can try looking online to see who makes your Time Warner box. You should be able to program the manufacture off of the program list. The universal code for this remote is 8107 and 8108 which may work as well. To program the remote press set and the light next to set will start flashing. Press the desired component button ex(TV , VCR, CBL, DVD). Next enter the code 8107 and press ENTER. The set light should no longer be flashing. If 8107 does not work try 8108 using the above info.
Feb 06, 2010 | Sony RMV210 Remote Control
Remote codes for dynex tv time warner remote
time warner has only one code and it is 400
Nov 26, 2009 | Televison & Video
Program Time Warner Remote RT-U62CP-1.17 to work ONKYO TX-SR575
i bot a new tv i don't have the book for the time warner remote so i don't know how to program it to work the tv it only works cable box
where can i find how to program remote that comes with time warner cable
Dec 26, 2008 | Onkyo TX-SR573 Receiver
Programming remote control to Cable TV Box
What you need to do is contact the manufacturer of either your remote control otherwise the manufacturer of the Time Warner [aka: cable providers some times also have the info on file for their customers] they store the code information within their internal systems for their customers such as yourself. Otherwise there is normally a paper insert with the remote control or the Time Warner that would list the info for select manufacturers on there. Toshiba has pretty universal IR signals/codes so you should be okay when trying to program in the codes. The manufacturers can also assist you through the steps--believe me it can get frustrating some times!
Jun 02, 2008 | Televison & Video
Toshiba 36A50 36" TV Logo
127,474 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
