Question about Sony Bravia KDL-40V4100 40 in. LCD HDTV
Looking at a negative screen - Sony Bravia KDL-40V4100 40 in. LCD HDTV
    Habit-Forming:
  • 17 Answers
Sony Bravia KDL-40V4100 models have a problem with the screen going blank, faded or washed out ( negative ghosting) . It is caused by a bad chip on the T-con board. A replacement chip is available from shopjimmy.com (Sony 55.40T02.C08 T-Con Board Component Repair Kit) for $14.95- If your not an excellent solderer, send your board to them for a repair $69.95.
Posted on Dec 17, 2014
SOURCE:
My tablet Fell on the bathroom floor and the screen is now going haywire.
most likely damaged the panel. Recommend replace unit as panel if available may not be cost effective.
May 16, 2015 | Televison & Video
Pictures all switched to negative lastnight
If the whole screen is looking like a negative mode: go into setting/general/accessibility and turn off Invert Colors
May 05, 2013 | Apple iPhone 4S
The calculator is only graphing a half circle when it should be a full circle, specifically not in the negative y-values of the plane.
A circle is not a function and cannot be graphed in the regular y=screen. You can graph a circle in parametric mode.
To graph a circle in the regular y= screen, you have to graph it in 2 lines on the y= screen. I assume you've solved for y and gotten a square root equation. Remember a square root can be positive or negative. In line 1 of y= screen graph what you've been graphing and then graph the same equation in line 2 but with a negative in front of the equation. You'll get something that looks like an oval since the calculator screen is rectanglular. To make it look more circular (both parts aren't going to connect), press zoom and then select #5 (square).
Aug 01, 2009 | Texas Instruments TI-83 Plus Calculator
Screen looks like a picture negative problem
Picture tube is weak. You can add a booster the Picture tube. I would replace the set.
May 28, 2009 | Sylvania 6620LFP 20 in. EDTV-Ready LCD...
Sony pfm 42b1 negative picture
I have a Sony PFM-42v1 and it does the same thing, look in your tv menu for picture inversion, usually under screen saver. What it actually does is reduce the chance of screen burnin. By reversing the image it sort of resets the hot areas, brightest colours and the cooler areas being dark colours, switches them around ( negative ). This cools the hot spots and heats up the cold spots.
There should be a option to turn it off, mine and I guess yours as a default is ON, mine has the ON, timer and OFF options.
Hope this helps, please let me know if you need more info.
russell
Mar 08, 2009 | Sony PFM-42V1 42 in. HD-Ready Plasma...
Screen pic looks like negative
well, in this situation, you can go to the EONON customer service, try to figure out, and they have a 2 year guarantee.
Jan 03, 2009 | Audiovox VOD102 Car DVD Player
Negative effect screen
If you cannot find a solution to your problem you may want to email fixityourself@gmail.com. He has good advice and good used parts at a fair price.
Apr 05, 2008 | Nikon COOLPIX L4 Digital Camera
View is Black & White "Negative"
There is a Black Dail by the Eyepiece, try unjusting that, and should do you.
Happy Holidays
Bobby
Dec 08, 2007 | Konica Minolta DiMAGE Z10 Digital Camera
Screen in negative
This looks like a problem the hinge cable that drives the video LCD display, or a at worse the LCD driver IC on the motherboard. but these units are fairly stable please elaborate
cliff
Aug 02, 2007 | Durabrand PDV-709
Open Questions:
See all Sony Bravia KDL-40V4100 40 in. LCD HDTV Questions
Sony Bravia KDL-40V4100 40 in. LCD HDTV Logo
223 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
