Question about Mitsubishi WD-60735 Projection Television
Mitsubishi WD-60735 lamp stays on after I turn unit off until overheat.
When I turn unit off, lamp stays on until over heat. Lamp indicator flashes green. When indicator stops flashing, lamp stay off until I turn on again.
    New Friend:
Welcome is on and wont throught to see tv since green flasher is..
Posted on Mar 15, 2014
SOURCE:
  • 58 Answers
SOURCE: Mitsubishi WD-52525 52-inch DLP HDTV ywllow warning lamp light
that means your lamp it is getting to the end of its life.
sometimes even if the lamp still good the TV will send you that message because that timer is closed to 5000 hours
What you can do is open the lamp door, closed again and the tv will ask you if you replaced it the lamp, and just say yes and that sign will go away
or just simple replace the lamp. 915P020010
Posted on Apr 18, 2009
saidneurot
  • 128 Answers
SOURCE: Mitsubishi WD-73733 73 in. HDTV
Could be the ballast of your tv please check our web page so you can find it http://www.discount-merchant.com/
Said
Posted on Dec 18, 2009
SOURCE: WD-62327 Lamp
OSRAM VS. PHILLIPS
This is about buying replacement bulbs for the WD62327 TVs.I dont know about the other models but I purchased a PHILLIPS replacement bulb and it worked for about a week and then those dumb flashing lights and no TV. I did some research and others were saying that you had to replace some condensers. Shop would do it for 600 dollars..Well i sent the bulb back and bought an OSRAM replaement bulb. The TV is now working perfect.
Posted on Jul 14, 2010
salt56
  • 373 Answers
SOURCE: I replaced lamp on mitisubishi
Are you sure you installed the lamp properly and put the door back so the interlock switch is functioning. Sometimes installing the lamp will get slightly displaced and is not plugged up properly and will indicate a lamp blinking light.
Posted on May 20, 2011
  • 26 Answers
SOURCE: Mitsubishi wd-60735 no picture and red lamp light
you have a digitdl light processing (dlp) television, which uses a high-pressure mercury-vapor lamp. depending on the hours of usage,the lamp will last about 1-2 years. the red lamp most likely indicates the end of lamp life. the lamp will need to be replaced. the owners manual will have instructions on how to replace the lamp. you can order a lamp on line. i perfer a brand name lamp. follow the instruction carefullt. i found that the television needs to be unpluged for an extended amuont of time to completely reset the timers, at least an hour. i have an older model wd62525.
Posted on Oct 07, 2011
How do i reset the lamp timer on my mitsubishi model wd-60735
Not going to fix that if the set even has that (which I doubt). Was the lamp a Mitsubishi or a generic cheap replacement?
when set goes off look to see if lamp is off or on, If you have to turn set back on or when its off, do the sets self check--press and hold both the menu and device buttons at same time for 5 second and release both---power light should blink a digit error code like 1,2, blinks pause and repeat that (1,2 is no error found and 3,7 is lamp issue.
Dec 23, 2012 | Mitsubishi WD-60735 Projection Television
Mitsubishi wd-60735 no picture and red lamp light stays on
Oct 07, 2011 | Mitsubishi WD-60735 Projection Television
-- "wd-60735 lamp was replaced have sound but no
check your Lamp Fan if it stops running when Lamp trys to light ,then it is defective ,but if it is ok Ballast Board could be the problem, it is what Powers the Lamp ON.
Aug 23, 2011 | Mitsubishi WD-60735 Projection Television
No picture.... makes a buzzing / small bell sound on and off...it has sound but after a minute it turns itself off.
This is a projection tv correct?Yes?The old projection lamp has not been replaced like 1 1/2 or 2 years?Tv in used daily like 4 or 5 hours everydays?Yes?Tv make buzzing sound and bell sound on and off.The tv on the frame the word "LAMP" the LED light indication it is flashing or stay on lit?Yes?Then the tv projection lamp life have ended,tv require a new projection lamp.
Aug 10, 2011 | Mitsubishi WD-60735 Projection Television
I replaced lamp on mitisubishi WD-60735. The Lamp light is still blinking yellow, the timer light lit up green, but lamp still blinking yellow
May 18, 2011 | Mitsubishi WD-60735 Projection Television
Just replaced the bulb in a wd-60735 and there is no picture and no sound the tv turns on and 20 seconds cuts out the status indicator stays red
hello make sure you've fitted lamp securely and the lamp cover as well this will be down to the safety switches hope it helps
regards
shaun
Dec 06, 2010 | Mitsubishi WD-60735 Projection Television
I have a mitsubishi wd-60735 tv when i turn the tv on nothing comes on only hear the volume and screen just pitch black?
Did you recently replace the lamp? If you did then it might be the new lamp. I mistakenly bought an aftermarket lamp to replace mine and it would not work consistently. Apparently if it is not an Mitsubishi original lamp it has issues, because after I replaced it with a Mitsubishi lamp it worked perfectly fine.
Aug 14, 2010 | Mitsubishi WD-60735 Projection Television
Mitsubishi WD-60735 Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
