Question about LG 42PX4DR 42 in. Plasma TV
Mitsubishi dlp won't show pictures, only sound
I have a mitsubishi 73 wd-73642 it had sound and I have picture but its dark and when I turn it off it just blinks yellow off and on what could be wrong
The dim picture is an indication that the Xenon lamp is at the end of life. Check the menu and settings to determine if the lamp needs replacing. Generally, they work well for 4000 hours then begin to get dimmer, slowly with time. Replacing the lamp is simple. You tube has videos that will show you how. The lamp should be less than $100 and can be ordered on line. I recommend you clean the DLP heat sink and the fans while you're at it to prevent overheating and eventual failure of the DLP chip. I had to replace the one in my WD-65835 Mitsubishi. Good luck.
Aug 26, 2016 | Mitsubishi Televison & Video
What is wrong with my Mitsubishi Tv model WD-65638
Youre lamp has failed. you need a new lamp.http://projectorlamps.com/mitsubishi-dlp-tv-bulbs-915b441001-pvip.html 915B441001 PVIP Mitsubishi DLP TV Bulbs
Feb 25, 2015 | Mitsubishi WD Televison & Video
Replaced lamp in my mitsubishi wd 60638 dlp but now I have a flickering picture
Sounds like a new lamp that is generic (not Mitsubishi) as the set does not know which lamp is in the set--works with one and not the other you have found your problem.
May 23, 2012 | Mitsubishi WD-60638 DLP TV
My 60" dlp mitsubishi tv
Sound /No picture- Have you replaced the Lamp?
If Not, First make sure fans are running when Tv is Turned on .Then if fans are OK ,Most common reason is the Lamp.
What is the Model # that is printed on back of TV?
Feb 20, 2011 | Mitsubishi Televison & Video
Mitsubishi TV DLP 73736. No picture but has sound
Replace Lamp Mats has them for $99.00
1-800-628-1118
Mar 24, 2010 | Televison & Video
Mitsubishi 65" DLP HDTV, Status light is red, no picture
Check your lamp; it may have blown. Sound, no picture and a red light are classis signs a lamp has failed.
Feb 02, 2009 | Mitsubishi WD-62528 62 in. LCD Television
LG 42PX4DR 42 in. Plasma TV Logo
12 people viewed this question
Ekse
