Question about Sony Bravia KDL-40V4100 40 in. LCD HDTV
Sony bravia blink red lamp 5 time - Sony Bravia KDL-40V4100 40 in. LCD HDTV
    Top Expert:
  • Sony Master
  • 76,099 Answers
These blinks [flashes] are fault indication (Error Codes).From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it.This will make repair easy.These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times.Count it carefully.If you wish to get some details, check the site linked here.It has details about blinking codes, and fault locating, to many popular brand TVs and other devices.Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
Gopakumar Gopalan Google
Posted on Feb 24, 2014
SOURCE:
eoddeputy1
  • 4 Answers
SOURCE: sony KDFE60A20 TV turns off and on with Red light blinking 5 times
Same problem here. 5 blinks is video related. I've been told to clean the screen by the lamp, as they could be clogged and causing it to over heat. Going to give thet a try first. I'll post what happens...
Posted on Oct 13, 2008
  • 1039 Answers
SOURCE: 13 red standby flashing lights -- turns on, then turns off
Are you sure about the 13 flashes. Error code only goes to 8 flashes.
Posted on Apr 26, 2009
rustym62
  • 201 Answers
SOURCE: standby light blinks 13 times
13 blinks is backlight error.. can be 1 of 2 things, 1st bad inverter board (on left side panel looking from back) it has several plug ins to the panel as it supplies voltage to the backlights.2nd could be panel itself as backlights are built into it they can't be replaced. Inverter is probably around $200 +labor, panel= buy new tv... they are outrageously expensive. Good luck!
Posted on Apr 29, 2009
dsacco86
  • 1077 Answers
SOURCE: my sony bravia tv is flashing red stand by light
Try leaving the TV unpugged for 30 minutes so the TV can reset itself.
If that doesn't work, most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you flashing red light codes, circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Posted on Jun 29, 2009
  • 194 Answers
SOURCE: My Sony Bravia Kdl40v300 will not turn on When I
sorry. Hope you still have a waranty. This is not an uncommon problem with the sony's. 99% chance that the panel went out. Could also be a balance board issue, but usually not. Call Sony for an authorized repair center
Posted on Dec 24, 2009
Red light blinking five times after an unsuccessful start-up on my Sony Bravia KDL40EX600.
Hi
if red light blink 5 times then panel is defective so please replace the panel in this case
Jun 30, 2015 | Sony Bravia Kdl40ex600 40-inch 1080p Led...
Power light blinks red 5 time, Lamp driver Faulty. I replace the ballast no change. Can you help?
If the screen is not starting It may be your main power board, not lamp driver, you would need to check the volts on the board.
Sep 29, 2014 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony bravia 32ex400 5 time red light blink
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Jul 25, 2014 | Sony Bravia Klv-32ex400 Multi-system Full...
What would be the cause? Sony Bravia standby light 3 blinks times any ideas?
try re-closing your lamp door. indicates possible lamp door/switch problem
Jul 19, 2014 | Sony Bravia Kdf-46e3000 46-inch 1080p 3lcd...
Sony KDL32CX520 red light blink 5 times
IKR Error at power on 05. 5 blinks denotes this. Actually, the fault is related to its main digital board, and the work will not an easy one. Anyway, http://electronicshelponline.blogspot.com/ check this link. Pull up previous posts there, either by its left side bar, or view it in Timslide option, and see whether there is something to help you. If you're not sound in electronics, no need to proceed. Contact any service technician or authorized service centre for Sony.
Jun 29, 2013 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Sony Bravia KDL46XBR-LCD. No picture but sound. Trouble shooting light blinks 5 times in cycles. What does it mean.
If your television blinks 5 times or for a count of times, it simply is indicating that there is a problem inside the unit.
The problem applying to this situation is a faulty lamp. The lamp is bad and simply need to be replaced.
As soon as you replace the lamp, the television will be in good condition once again.
Take care and good luck
Nov 06, 2010 | Sony KDF-E55A20 55 in. LCD Television
I have a 52 inch sony bravia. turn it on and i hear a buzzing sound then the red standby light blinks 13 times.....what gives. I need help
Sounds like the lamp is blown. Check your manual to see what the blinking lights mean and how to check the lamp.
Jan 16, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony Bravia kdl-46S3000 flashing red lights
Sounds Lamp is weak in this TV.
Please replace lamp and procedure is written in TV user manual.
Mar 14, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Open Questions:
See all Sony Bravia KDL-40V4100 40 in. LCD HDTV Questions
Sony Bravia KDL-40V4100 40 in. LCD HDTV Logo
268 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
