Question about AMS VENUS DS3 Aluminum Black 3.5" External Enclosure, USB2.0/Firewire Hard Drive Case with 80MM Ultr... (197055001) Drive Case
Computer doesn't recognize hard drive
Usb cable is working, problem is with hard drive
  • Dan Parker
    Dan Parker May 11, 2010
    External or internal
  • 53 Answers
If your hard drive is not recognize by your computer try to enter cmos set-up and see if your HDD is detected and if it is detected by your pc then you probably have error in your MBR, try to format your hdd using fdisk. If this doesn't work you maybe have a faulty HDD, try to replace with a new one to try if your HDD is really the problem, also replace your data cable (IDE/SATA) maybe that the problem. good luck with this.
Posted on Jun 12, 2009
SOURCE:
My Windows 7 cannot recognize my Sata/usb connector
USB hard drive is a portable external storage device that works just like a conventional hard drive. The device is simply plugged into a USB port on your computer as you would connect a flash drive. Unlike a flash drive, however, a USB hard drive can store a much larger amount of data. If your computer will not recognize your USB hard drive, you can try troubleshooting steps to resolve the problem.
Plug one end of the USB cable into the port on your hard drive and plug the other end into the USB port of your computer. Ensure that both ends of the cable are connected securely. Open "My Computer" (Windows XP) or "Computer" (Windows Vista/7). The USB device should be listed as "removable disk" once it is plugged into the computer. If it is not listed among the available drives on your computer, proceed to the next step. Ensure that the data cable is working properly. Try another USB cable if you have one available. Disconnect all other USB devices from the computer as they may interfere with the operating system detecting the external hard drive. Reboot the computer if the USB hard drive is still not recognized. Plug the USB cable into another USB port and check to see if the device is detected. If you are using a USB hub, remove the device and plug the external hard drive directly into a USB port. If the computer still fails to recognize the device, the external hard drive itself may be experiencing a hardware problem. Check the status of the hard drive in the "Device Manager" window. Under Windows XP, right click "My Computer" and select "Device Manager." For Windows Vista and Windows 7, click the "Windows" button in the lower left corner of the screen, then type "Computer Management" in the search bar and press "Enter." Select "Device Manager" in the "Computer Management" window. In the Device Manager window, click the "+" sign that appears beside "Disk Drives." If the external drive is not listed, click "Other Devices" in the Device Manager window and see if an "Unknown Device" appears. The external hard drive may have been detected but the device is not working properly. If it is still under warranty, take the device to the computer store where it was purchased to have it repaired or replaced. Hope this helps.
b>
Jan 04, 2013 | Apricorn SATA Wire 3.0 - storage...
Nexxtech external USB hard drive stopped working. Light comes on but drive does not seem to activate and produces no response in the laptop.
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
a cnet rview
Pros: Lots of space, very low price, doesn't require outside power
Cons: Sometimes stops working, no firewire (but still a quick transfer speed)
Summary: This doesn't require outside power, but sometimes you need to hook it up to 2 USB ports. The USB cable has 2 heads. Sucks when I only have 3 USB ports on my laptop.
Also sometimes it spontaneously stops communicating with the computer. I don
Oct 04, 2011 | SimpleTech SimpleDrive Portable USB 2.0...
The green light is flushing but nothing else happens. The connected laptop doesn't recognize the maxtor hard drive. 12 V 2A is fine. What else can I do or check?
hope this helps
Sep 18, 2011 | Maxtor BASICS Personal Storage 3200...
My toshiba external harddrive usb 3.0 won't work
hope this helps you
Sep 18, 2011 | Toshiba Notebooks Canvio E05a075cau3xw 750...
My computer doesn't recognize my dane-elec 8gb usb stick , although other usb devices do work.
1. Try a different USB port. If other ports recognize it, then the original port is fried. 2. Try a different computer. If the other computer does not recognize it, then your flash drive is damaged.
Good Luck!
Aug 19, 2011 | Dane-Elec DaneElec 4GB USB Drive Copper...
Loaded everything onto drive, now computer doesn't recognize drive when connected.
hope this helps
Jun 25, 2011 | Iomega HDD Portable (32379) 30 GB Hard...
Computer doesn't show that device is connected
if your computer came with a motherboard disc the drivers could be on it
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems hope this helps
Jun 11, 2011 | Western Digital My Book Essential 1TB...
Drive is not working. When you turn it on the blue light lights up but then goes off. The red light on the back stays on but the CPU does not recognize it. I have changed USB ports but it still doesn't...
please right click computer then Manager under storage, click Disk management. if you see you usb drive there, simply right click on it and format to exfat. fat32,or ntfs. if it doesn't show up, it pretty much shows that it needs an upgrade.
May 08, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
I can't get my computer to recognize my Garmin 255w on USB cable.
Change the mini usb cable. Some mini usb cable are for charging and not data. It happen to me and used the externo hard drive usb mini cable and zapppppp my computer nows read the gps and gave it a drive (h:\). hope it works for you.
Jul 15, 2009 | Garmin nuvi 255W GPS Receiver
Open Questions:
See all AMS VENUS DS3 Aluminum Black 3.5" External Questions
Computers & Internet Logo
347 people viewed this question
Top AMS Computers & Internet Experts
Alun Cox
Are you an AMS Computer and Internet Expert? Answer questions, earn points and help others
