Question about AEM 2000 Ford Explorer - Sport, 4.0L V6 - Brute Force Air Intakes
Ford Explorer Sport Oil Pump
My oil pressure gauge started jumping up and down yesterday. If I gave it gas it went back to normal and the check gauge light went off. However today it is low and not moving. I drove it home (less than 10 miles) and I could smell oil burning. Is this my oil pump?
    New Friend:
    Problem Solver:
  • 7 Answers
Perhaps,sounds more like a clog in your system. Oil filter a nd changes to your oil should work.
Posted on Jan 03, 2015
SOURCE:
Lost oil presure on a 1999 ford explorer
might just be faulty oil pressure gauge or oil pressure gauge sender unit. I would start by having these both checked. hope this helps
Aug 03, 2014 | 1999 Ford Explorer
Oil pump ford explorer
No that is not the pump that you smell. You need to have a test gauge hooked up to verify that you have good oil pressure, if it is ok then replace the sending unit for the oil pressure gauge.
Mar 20, 2014 | Ford Explorer Sport Cars & Trucks
1995 Ford Econoline 150 with 302 engine. Oil pressure indicator starting dropping when idle speed went down, Had a new oil pump and sending unit replaced, still does the same thing. Has 190K on it, now as...
When you had the pump replaced did anyone look at the rod and main bearings? 99% of all low oil pressure problems I've seen has been directly related to bearing wear, not a bad oil pump.
Replacing the pump will give you slightly better pressure temporarily but that won't last very long.
Verify the actual oil pressure using an external mechanical gauge. If it's low (likely it is) go back into the oil pan and use plasti-gage on the bearings to measure clearances.
In reality though, in an engine with that many miles, it's best to either completely rebuild or replace it though.
Sep 10, 2011 | 1995 Ford Econoline
I have a 2000 Ford Explorer Sport. After driving 15-20 minuets and coming to a stop the oil gauge fluctuates wildly. Sometimes the check engine light comes on. When I put the vehicle in park and give it a...
Sounds to me like it could be a bad oil sending unit or gauge. I would take it in to a shop and have them test the oil pressure with their equipment.
If they tell you the pressure is good try changing the oil sending unit first then if that don't work, replace the gauge.
Aug 26, 2010 | Ford Explorer Sport Cars & Trucks
OIL GAUGE DROPS LOW THEN WHEN START TO GO IT GOES TO THE MIDDLE START TO SLOW DOWN THE GAUGE GOES DOWN AGAIN
this is almost certainly a oil pressure gauge sending unit problem, replace it and recheck.
Apr 16, 2010 | 2001 Ford Explorer Sport
1996 Explorer 4wd sport - oil pressure
I would use 10W-30W, but that should not make the oil pressure read low, have the oil pressure checked with a mechanical test guage, if it tests within normal range then start by replacing the oil pressure sending unit.
Jun 17, 2009 | 1996 Ford Explorer
Oil pressure problem
Replace your oil pressure sending unit. Usually costs about $10.
May 25, 2009 | 2000 Ford Ranger SuperCab
Oil Pressure Gauge/Engine rattle 2000 Ford Explorer 4.0 6cyc 4wd
Your Oil Pump is Out and will need to be Replaced. This is not a Job that you would want to attempt on your Own unless you have been a Mechanic. Trust Me. Been an ASE Certified Mechanic for 35 Years.
Jan 22, 2009 | 1999 Ford Explorer
AEM 2000 Ford Explorer - Sport, 4.0L V6 - Brute Force Air Intakes Logo
Top AEM Tools & Hardware - Others Experts
Marvin
Marvin
Lawrence Oravetz
tau1618
Are you an AEM Tool and Hardware - Other Expert? Answer questions, earn points and help others
