Question about Sony Bravia KDL-40V4100 40 in. LCD HDTV
Sony bravia kdl40v4100 picture too big for screen
Cuts off tops of people heads. Can't see all of titles on the sides or on bottom. Tried adjusting wide, zoom, etc but no help.
SOURCE:
SOURCE: Sony Bravia - Picture in ZOOm Mode
I corrected mine by adjusting my cable settings. It had been set to "zoom" / "wide" mode. I reset to "normal" and now channels look fine again.
Posted on Jan 06, 2008
Coldcut
  • 1554 Answers
SOURCE: cannot fill screen with normal picture size setting
assuming you all have comcast and using an hdmi cable
first access menu (hit it twice) and go to set picture format, choose passthrough....or in your case auto hdmi
then turn box off, press guide and info on the front of the box, proceed through the setup, advanced is more in depth..lol...
select 1080, 720, and then either the standard or widescreen 480s to your liking.....
voila....
now check your tv settings to accommodate
Posted on Feb 18, 2008
SOURCE: Screen settings for Sony Bravia KDL52XBR2
I had that same problem, I finally figured out that on my COX cable remote there is a "zoom" key, hit that and it should go back to normal.
Posted on Mar 28, 2008
dave1645
  • 834 Answers
SOURCE: HD broadcast picture is not full screen. How do I
go into your customers setting and change you aspect setting to either full or auto
Posted on Sep 17, 2009
  • 210 Answers
SOURCE: My sony bravia tv's picture is so wide it cuts off
change picture format to 16.9 in the menu or if there is button on remote ( aspect / format or zoom ) or a picture of a square with two lines in it press until picture look ok
Posted on Dec 14, 2009
How do I get my Samsung and Dynex tvs to fit the program to the screen size. 16:9 aspec ratio leaves a black ribbon top and bottom. Zoom cuts off the head on some programs
Some program material in widescreen format (16:9) will be displayed as a "letterbox" with black bands at top and bottom because of the technical difficulty in adjusting to the 4:3 aspect ratio of the TV screen.
Apr 17, 2018 | Samsung Televison & Video
How do I access advanced menu options so I can adjust overscan settings?
get to the on screen tv menu and look for aspect ratio change that ,save and exit
May 18, 2015 | Toshiba 32ZH46P
Projection is too close cuts the screen what do i do
have you tried zoom setting in the menu? wide, full , or zoom?
Feb 16, 2012 | GE D52GW12 52" Rear Projection HDTV-Ready...
Picture too large for screen
Press "wide mode" on TV remote until it is on "full". Check for same on set-top box.
May 02, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Picture Zoomed in too much, no zoom button
I had the same problem after plugging my pc into the pc-in socket. The problem happened with the scart connections after.
I solved it by turning the tv off/on from the wall plug socket.
Mar 06, 2010 | Televison & Video
Pic size on vw32l cuts off top
you have to bring up the onscreen menu by hitting menu button then go into dettings, this should help,let me know if it works
May 19, 2009 | Vizio VW32L 32 in. LCD HDTV
Viewing mode will only go from zoom to wide!!!! please help
Hi!
Found some relevant info on how to adjust your video settings... You might want to give it a try!
Thanks! =)
4.12 PC Input Picture Adjustment
The Picture Adjust menu operates in the same
way for the PC Input as for the DTV / TV input in
section 4.2 for Backlight, Contrast, Brightness and
Color Temperature.
4.12.1 Auto Adjust
When the MENU button is pressed, the On Screen
Display (OSD) appears on the PICTURE ADJUST
page. Press the button to highlight the Auto
Adjust selection.
Press the button for the LCD HDTV to adjust to
the PC signal timing automatically.
4.12.2 H-SIZE
Press the button to highlight the H-Size selection.
Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
the horizontal size.
4.12.3 Horizontal Shift
Press the button to highlight the Horizontal Shift selection.
Press the button to start adjusting the horizontal position of the picture. Use the or button to
adjust the horizontal position.
4.12.4 Vertical Shift
Press the button to highlight the Vertical Shift selection.
Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
the vertical position.
4.12.5 Fine Tune
Press the button to highlight the Fine Tune selection.
Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
4.14.1 Understanding Viewing Features
Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
You can switch viewing modes using the remote control.
4.14.2 Viewing Modes
Normal Mode
The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
added to the left and right of the display image. Standard TV broadcasts are
displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
to as pan-and-scan or full frame. These movies were originally filmed in 16:9
(widescreen), and then modified to fit a traditional TV screen (4:3).
Wide Mode
When watching a standard broadcast or full-frame movie in this mode,
the display image is stretched proportionately to fill the TV screen.
When watching a widescreen (1.78:1 source) program or movie, the
display image fills the TV screen. If you are watching a widescreen
(1.85:1 or 2.35:1 source) program or movie, there will still be black
bars at the top and bottom.
Zoom Mode
When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
program or movie, the display image is zoomed proportionally to fill the
width of the screen. The top and bottom are cut off to remove most of
the source material’s black bars. This mode is good for programs or
movies with sub-titles.
Panoramic Mode
When watching a standard broadcast or full frame movie in this mode,
the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
horizontally on the left and right sides to fill the TV screen. The center
of the image is not stretched.
Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
will return to widescreen.
Jan 04, 2009 | Televison & Video
My tv zooms in and changes the format.
This is normal - you are zooming in on the picture. Most people use the zoom feature to "stretch" a widescreen movie so it will fit the screen.
Dec 19, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
I cannot reset the picture to Normal (which should fill the entire screen). f
on what dvd player also has zoom mode set it at 16.9 on all units once no zoom in or do u use dish hd page up down will adjust size also
Jan 31, 2008 | Akai PT46DL10 46" HDTV-Ready Television
Open Questions:
See all Sony Bravia KDL-40V4100 40 in. LCD HDTV Questions
Sony Bravia KDL-40V4100 40 in. LCD HDTV Logo
104 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
