Question about Brother MFC-J6710DW Multifunction Printer - MFC-J6710DW
Brother MFC-J6710DW won't print on 11x17
My Brother MFC-J6710DW won't print on 11x17 all of a sudden. All new ink cartridges are in, tray settings are correct, selection of correct paper size/type is accurate, but when I send to printer, it only prints in 8.5x11. Even when I specifically select the tray with Ledger paper, it's only printing a Letter size picture on Ledger paper. Haven't been able to find any troubleshooting help on this issue.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • Brother Expert
  • 236 Answers
Solutions to Fix Brother Printer Error Code 76:-
Solution 1:- Change the Fuser
The Error Code 76 in your Brother printers is also related to fuser error, so you need to change the fuser, but first just in case try to reset settings to factory defaults.
Solution 2:- Change or Update the IP Address
The other solution is that is to change the IP Address. For this you have need to do right click on your printer, click "Properties", then click the "Ports tab" then hit on your Brother printer and then click on "Configure port: (or you can delete the existing one and then add another one).
Furthermore, if you want to do is update the IP Address, you can. But the problem is that the Brother Printer doesn't have a static IP address, it's dynamic. If you want to confirm that, then go to your Brother Printer and press the "Reports" button and then print out the network configuration report. Now your IP address will show on that. It's actually the last digit in the IP address that changes. This will absolutely solve your problem.
For more Info Visit Us: Fix Brother Printer Error Code 76
Posted on Jul 25, 2019
    New Friend:
Same Problem. Any solutions?
Posted on Nov 22, 2014
  • 2 more comments
  • Chris Thayer
    Chris Thayer Nov 22, 2014
    Ok. I got it working. I'm not sure which of these did the trick.
  • Chris Thayer
    1) I uninstalled the brother software through the add/remove programs section in control panel, downloaded the newest drivers, and reinstalled them
  • Chris Thayer
    2) I saved the image I was trying to print and then loaded it in the imageViewer software that came with my printer. I have a feeling this might solve the problem by itself, but it happened to be the second thing I did before trying again
  • Chris Thayer
    I think not all software supports ledger printing, so try using theirs
3 Suggested Answers
SOURCE:
  • 4 Answers
SOURCE: Brother HL2070N won't print
At the first please check the power & than all connections after that please re-install the driver & go to printer settings & than select the default printer
Posted on Feb 24, 2009
SOURCE: factory reset brother nc 2010h
Same problem, did you find a solution ?
Pascal
Posted on Mar 02, 2010
After changing ink cartridge incoming faxes won't print. Does something have to be reset?
Some machines recognize you changed the ink cartridge and some do not. If you shut it down and restart it, this usually helps it reset.
Feb 28, 2015 | Brother Mfc-j6710dw Multifunction Printer...
Tip
Brother MFC-J6910DW Review Printer
The professional series MFC-J6910dw will help your company develop with the versatility of duplex printing, copying and also scanning. Make two-sided documents approximately 11 inches x 17 inches house. Easy to arrangement wireless (802.11 b/g/n) or Ethernet network cable televisions with embedded assistance web link to others on the network. 3.3-inch touch screen different colors LCD display menu navigation attributes are interactive and easy to use. Dual paper trays (up to 250 sheets each) supplies an overall capability of 500 sheets. Utilizing Super High Yield (XXL collection) replacement ink cartridge around 2400 web page black and also colour 1200 pages. Neglected tight Fax, copy or scan with up to 35 web page ADF. 3 year minimal guarantee gives peace of mind.
Brother MFC-J6910DW Along with way over the typical paper handling, MFC-J6910DW offers all the standard features of any type of Office supplies, and much more. For a beginning, can print, check, and also Fax over a network and work as a standalone copier, facsimile machine, and also email of the sender. It can likewise check in tabloid dimension, utilizing the automated paper feeder web page 35 (ADF) or flatbed.
Duplex scanning lets you Fax records conveniently duplex, duplex printing as well as mixes while duplex scan additionally allows you duplicate both Simplex (one-sided) as well as duplex record to your liked copy simplex or duplex. Keep in mind, nevertheless, that duplexing for scanning is restricted to an optimal legal size web pages, although the ADF can take care of tabloid dimension web pages to scan Simplex.
The common setup. The printer offers Ethernet and WiFi assistance. For the tests I attached to a wired network and installed it on a Windows View system. Not incredibly, offered the similarity between the printer, MFC-J6910DW the outcomes are basically the very same, documents by file, the MFC-J6710DW, as well as the Bro MFC-J6510DW ($ 250, 4 stars), basically the budget variation of the very same ink-jet printer, with just one paper tray.
I clocked up all 3 printers on our business applications suite (making use of QualityLogic's hardware and software for the time) in 4.1 reliable pages per min (ppm), making them is bound to be a tabloid-capable inkjet asserts the fastest we've checked to this day.
Brother MFC-J6910DW
Amongst the single-function inkjets, editor options Canon Pixma iX7000 Inkjet business Ink-jet printer ($ 399.99 straight, 4 stars) are primarily slower, ppm 1.7. And also between inkjet MFP, HP Officejet options editor formerly 7500A Wide Layout e-all-in-one ($ 299.99 direct, 4 celebrities), can be found in at 3.4 ppm.
The quality of output and also other troubles
Generally, the top quality of the outcome of the MFC-J6910DW equal to or far better than many inkjets across the Board, and also the lid fits MFC-J6710DW MFC-and J6510DW. This text agrees with for a lot of company applications, as long as you do not have an uncommon demand for small fonts, as well as the photo output on picture paper are roughly matched to prints of **** stores, making it greater than adequate for a lot of business requirements.
Different colors in the graphics are slightly dulled down yet also within affordable variety. Right here once again, the quality is conveniently adequate for a lot of business needs, including, as an example, PowerPoint handouts. I see some allure in the default mode, yet it relies on how much of a perfectionist, you can take into consideration a sufficient graphics for outcome will certainly be essential clients or clients.
Dued to the fact that the MFC-J6910DW provides every one of the very same capacities that make MFC J6710DW-editor choices, including the capability to copy, fax, print as well as scan in tabloid dimension, and also print in duplex, extremely easy to suggest. Certainly, if you ever before have to scan a two-sided paper, you're far better off conserving a couple of bucks and purchase a MFC-J6710DW instead. Yet if the duplex Scanning is something that you need or believe you could need, Brother MFC-J6910DW is the apparent option, and also it is still cheap.
All in One Multi Function Brother MFC-J6910DW
on Mar 29, 2016 | Office Equipment & Supplies
Brother mfc j6710 tabloid print problems
ARE YOU PRINTING THICK PAPER IF YES THEN CHANGE THE PAPER TYPE THICK PAPER
Jun 22, 2017 | Brother "mfc-j6710dw professional series...
Brother MFC-295CN printer was stored for 2 years. Black ink won't print now no matter if brand new cartridge.
this work for me with a mfc 255cw. why it works I don't know but I will continue to use this setting. thank you
Jun 05, 2012 | Brother MFC Office Equipment & Supplies
What's your problem?brother mfc-j6710dw paper jam
I had problem with Brother MFC-J6710DW complaining about paper jam. Went through whole paper jam procedure a few times with no avail and no visible paper jam anywhere. Found (googled) this to be a common problem for this device. Turn off / on didn't help either.
Finally ... I followed procedure to the letter, bowed possible dust away and ... pushed tray 1 all the way in. (It turned out it was not all the way in when I first started troubleshooting, and was pushed to the same inadequate position subsequently.)
This MFC is low-cost. Meaning it has few sensors, and subsequently is not very precise reporting errors.
Remember: "paper jam" alert may mean something not on exact place it should be, with this otherwise (so far) good value for money MFC.
Mar 26, 2012 | Brother MFCJ6710DW All-In-One InkJet...
Brother MFC-420N : Color Problems
You need to start the ink cartridge changing procedure over. Try unplugging the machine for a few minutes.(from the wall and the computer) Then try the ink change over...If that doesn't work don't waste time. Download and install the latest drivers for your printer. Uninstall then reinstall with newer drivers. Let me know what happens. Good Luck, Tim
Feb 19, 2007 | Brother MFC 420CN All-In-One InkJet...
Open Questions:
See all Brother MFC-J6710DW Multifunction Printer - Questions
Brother MFC-J6710DW Multifunction Printer - MFC-J6710DW Logo
442 people viewed this question
Top Brother Computers & Internet Experts
gary433
Are you a Brother Computer and Internet Expert? Answer questions, earn points and help others
