Question about Westinghouse TX-42F430S Television
Have picture/video for tx-42f430s but no sound/audio
4 Suggested Answers
6ya staff
SOURCE:
westytech
vidal chavez
  • 120 Answers
SOURCE: No picture on Westinghouse TX-52F480S.
Hello, I will need a bit more information to help you out on this one. I can troubleshoot with you live on this one just simply email me your contact information to westytech@wde.com or send me an email and I will give you my contact info.
Posted on Jan 27, 2010
thomascha103
  • 58 Answers
SOURCE: what is the weight of
I found 2 different sources online that list the weight as either 61.1 lbs or 68.1 lbs. I think the 61.1 is more accurate for the bare TV without the stand or anything attached. But keep in mind that when mounting a flat panel TV to a wall, you should secure it with hardware rated for much higher weight tolerances. Many mounting brackets for TVs of this size are rated for 150 - 200 lbs, and for good reason. Consider a situation where someone trips and catches his balance on the wall-mounted TV. The TV is already putting 61 lbs of pressure on the bracket, so any force from any other contact is added to that. It doesn't take much to add up to 100 lbs or more. If the mount breaks free from the wall, you'll have damage to the TV, the wall, the mount, and any furniture or flooring beneath the TV, so the best advice is to mount it as if it weighed about 150 lbs. The 7 lbs +/- difference in reported weights won't matter at all.
Posted on Jan 25, 2011
Testimonial: "very helpful"
RNS-Systems
RNSeStore.com
  • 120 Answers
SOURCE: my 42 inch westinghouse wont turn onDTV 1080p TX-42F430S
If you are referring to that you are unable to select the the 1080p setting in the TV menu, first try changing the aspect ratio in the TV Menu.
If that does not do it, you have to change the display setting ion your device, if you can not or it does not have 1080p the problem is that resolution is unsupported by your device
Posted on Jun 07, 2012
I have a white westinghouse 40 inch tv model vr4090 and the tv wont come on it shows the power indicator turn from red to blue but no picture or sound
Westinghouse tx-42f430s wont turn on fix repair - YouTube
? 5:29
https://www.youtube.com/watch?v=DdfLu5RdVEQ
May 12, 2014 - Uploaded by After Hours Tv & Pc repair
Westinghouse model # 32H1G1 won't turn on , but If I unplug the TV and wait for a ... -tx-42f430s-42-inch-lcd-tv-appears-bricked-595806.html ... I have a Westinghouse 40" TV that is working, but sometimes it won't turn on.
Westinghouse LED LCD TV Repair - YouTube
? 12:32
https://www.youtube.com/watch?v=DGg5iuFEfdM
Feb 8, 2014 - Uploaded by INSIDEHARDWARE CHRIS
Westinghouse Model: LD-4680 Similar (LD4655VX LD4255VX ...Samsung LCD TV Repair - TV Won't Turn On - How to Replace Power Supply ...
40 inch Westinghouse lcd tv black screen help - YouTube
? 1:39
https://www.youtube.com/watch?v=tKLRihGgZAs
Nov 21, 2011 - Uploaded by Jason Flynn
Dec 19, 2015 | Westinghouse Televison & Video
Have sound on westinghouse 42 in tv but no picture..just vertical thin lines..thia happened suddenly have hd box rebooted cable. tv will not turn off or on but has power
check it against another computer if the same result then its faulty
is your graphics card a standalone if so that could be the problem
but i am assuming it built in then option 1
Sep 18, 2014 | Westinghouse Tx-42f430s 42" LCD HDTV...
Onkyo TX-SR701 getting sound but not picture from Video 4
you should check the video mapping in the setup of the receiver. video 4 may be associated with hdmi or composite video instead of component.
Feb 21, 2014 | Onkyo Audio Players & Recorders
I hooked up our Onkyo TX-SR607 system a few weeks ago and have watched several movies, but now I cannot get the Hitahci PH35811 TV to sync up to get video. I get audio, but no picture when we try to watch...
Are you routing the video into your reciver from the dvd player? If so route the video directly into your tv. It won't fix the initial problem but you will get picture and sound to watch dvd movies.
Feb 13, 2010 | Onkyo TX-SR607 Receiver
I have a Westinghouse 42" 1080p LCD TV. It doesn't pass stereo audio. I have an HDMI DVD player, HDMI laptop connection, composite video + stereo audio VCR, & OTA TV. None of them offer anything but...
Hello, this is an interesting one since on this unit what ever the device you are using will determin the type of audio you output on the speakers. I would love to troubleshoot a bit more with you live, can you please send me an email of how to get in contact with you to westytech@wde.com.
Nov 21, 2009 | Westinghouse TX-42F430S Television
Westinghouse tx-42f430s won't power on
More likely it's because of power circuit of your TV set. If you are not trained enough in repairing TV sets, appeal to your local repair center
Jan 25, 2009 | Westinghouse TX-42F430S Television
Won't power up past the W logo.
Try hitting the input button and selecting the correct source. Mine is YBPBR1. That should get you a picture!
Nov 17, 2008 | Westinghouse TX-42F430S Television
NO SOUND
REMEMBER VIDEO AND COMPOSITE SHARE SAME AUDIO SOURCE...CHECK AUDIO SETTINGS TO SEE IF HDTV AUDIO IS SET TO MINIMUM...IF SO, CHANGE TO HIGH..OF COURSE YOU MADE SURE MUTE IS NOT ON...PRESS VOLUME UP ON REMOTE..IF STILL NO SOUND...YOU HAVE A DEFECTIVE AUDIO/VIDEO PROCESSOR CIRCUIT BOARD..P/N 667-L32K5N-40...TRY ANDREWS ELECTRONICS IN CALIFORNIA..OR YOU CAN SEND BOARD TO PTS ELECTRONICS FOR REPAIR OR BOARD SWAP..JOE ACE
Mar 07, 2008 | Westinghouse TX-42F430S Television
Changeing display settings
I am not getting any audio out of my HDMI ports. I does not matter what I plug into them.
Feb 03, 2008 | Westinghouse TX-42F430S Television
Televison & Video Logo
Top Westinghouse Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
