Question about Refrigerators
Samsung SRS2028CVW fridge freezer
I have the samsung (sr-s2028cvw) american style fridge freezer. Just recently it keeps defrosting by itself and half of my frozen food has to been thrown away. I have noticed that it does this when the freezer temperature starts to flash on the front panel display. I do know that it needs a new filter and wondered if this has n e thing to do with what its doing!! Its also started to leak when its defrosting from the water/ice compartment on the front.
Have u n e suggests on what it up with it and can it be repaired??
  • 2 more comments
  • Anonymous Nov 06, 2007
    I Have the same fridge and have had the same problem. Had about five diffrent engineers try five different things that didn't work to fix it. Finally they put in a new board, very costly and it now works, although the ice and water have been turned off for a while now as they have broken and I can't be bothered to deal with the engineers again just yet. But fridge is no longer defrosting as it was.
  • Anonymous Sep 14, 2008
    i have the same problem.. need to get some one out to help as i cant set the temps as the freezer one just keeps flashing
  • Anonymous Mar 18, 2009
    I have the same problem, error code is 3 what does it mean.
    I have the same problem, error code is 3. what does this mean?
    Producer:
    Uploaded 30 video answers.
  • 117 Answers
Check out this samsung diy repair channel on youtube ... some great stuff on samsung
samsung fridge freezer problems
Posted on Oct 02, 2010
  • 100 Answers
I don't think your freezer is defrosting per say it is shutting down and everything is starting to thaw out which is why the ise that naturally builds up in your freezer door is melting and leaking. If you unplug your fridge and wait 60 seconds and plug it back in it will give you any error codes that are in the unit. You should have 4 8's on your freezer door 2 for the fridge section and 2 for the freezer. Depending on what dash of what 8 is lit up is the error for a variety of parts.
If you don't have any errors that show up check to see that your door switch is functioning correctly. Shut the freezer door and peel the gasket back so you can see if the light shuts off with the door closed.
Posted on Nov 03, 2007
    New Friend:
Does the fridge and freezer share a compressor or have one each on a Samsung SR-S2028CVW?
Posted on Oct 30, 2010
Refridgeration temperature problems. Buttons not responding.
Posted on Jan 02, 2009
SOURCE:
How to remove door handle from a Samsung fridge freezer model no srs2028cvw
wonder why the fridge parts cattle dog lists torx screw sets and allen keys
two somethings hold the handles on at each end
Samsung SRS2028CVW Fridge Freezer Spares
Sep 03, 2016 | Samsung Refrigerators
Hi there- recently my samsung fridge began to make a bit of a knocking noise like the fan was dying down whenever I opened the fridge door. Now my fridge won't cool down below 58 degrees. From what I can...
It sounds like the defrost is not working properly and ice has built up inside where the fan is and the ice is restricting normal operation of the fan.Try fully defrosting over 24 hours if possible the defrost heater will still need investigating.
Hope this helps.
May 18, 2010 | Refrigerators
I have a samsung SR-S2028cvw American style fridge freezer. The temperature on the dials are at the coolest but both the fridge and freezer are warming up to the warmest temperature before the motor kicks...
Try hoovering the cooling rad on the back of the fridge freezer, as this tend to clog up with dust and other matter, which reduces the cooling efficiency
Feb 28, 2010 | Samsung Refrigerators
Samsung SR-S2028DVW american style FF keeps defrosting
I would suspect the thermostat or the defrost timer is malfunctioning.
Jul 18, 2017 | Samsung Refrigerators
Fridge defrosting
Sounds like the defrost is cycling on and off. The model number is incorrect and I will need a correct model number to help you better. Sea Breeze
Aug 25, 2009 | Samsung Refrigerators
Fridge freezer samsung model no sr-s2028cvw
fridge side should only be around 36 to 40 degrees freezer side around 0 to10 below
Apr 13, 2008 | Refrigerators
Samsung american style fridge/freezer needs repairing
Spray a good quantity of WD-40 on the spindle of the fan motor where it enters the motor itself. This should get the fan working smoothly with no noise. This will probably solve the other problems, as the fan prevents various components from overheating and shutting down.
Apr 01, 2008 | Refrigerators
Refrigerators Logo
2,260 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
