Question about Panasonic TH Televison & Video
Hdmi problem no detecting video on hdmi.everything else is good.cables resolution 1280*720.it was working
6ya staff
SOURCE:
Anonymous
  • 4 Answers
SOURCE: ilo 42" plasma tv
Go the the settings on the cable box. look for output resolution, then change it to 1080i and 720p. now turn the box off and back on your tv will now display the input of wither 1080i or 720p depending on the hd channel your watching.
Posted on Jan 12, 2008
marketex
Maurice B Thomas
  • 371 Answers
SOURCE: TH-42PX60U All output ports works but HDMI ports
Problem is with your ISP/Cable Company accepting the installation as one with HD clients, which while
not necessarily costing you more, must be specified to the cable box by your installer.
Make the call.
Posted on Apr 17, 2009
Chi Chu
  • 8457 Answers
SOURCE: hdmi ports are not working
That HD mode.That good what else do u want.Unplug,replug the tv an hour later,might get HDMI ports work again.Not,ur Tuner board is dead.
Posted on Apr 26, 2010
hotaruseriza
  • 639 Answers
SOURCE: I have a Magnavox 42MF439B LCD TV. It was working
Maybe the problem is not from cables but from HDMI hole/jack, rusted or something
Posted on Jan 20, 2011
aslemp
Andrew Slemp
SOURCE: im getting a resolution mismatch
Having the same problem myself. Let me know if you figure out how to fix it.
Posted on Feb 10, 2011
I am unable to get a picture on hdmi when i connect my ps3, but am able to get sound when i use ps3 controller. any ideas ?
Steps
  1. Step 1 Check for an HDMI port Check the back of your television for an HDMI port and refer to your owner's manual for your television's resolution. A resolution of 1080p offers the highest quality.
  2. Most PS3 systems support 1.3 HDMI, but older systems may need a software update from the 1.1 or 1.2 version.
  3. Step 2 Disconnect cables Disconnect all the cables and adapters from the back of your PS3, and then unplug your TV to reduce the risk of shock as you work.
  4. Step 3 Connect HDMI cable Connect the HDMI cable. Reconnect the power cables on both the TV and the PS3 system.
  5. Step 4 Hold power button Hold down the power button until the PS3 beeps and continue holding it for an additional five seconds until the system makes a second beep.
  6. The Playstation 3 should detect the high definition cable and automatically adjust the settings to give you the best picture and sound possible.
  7. Step 5 Test the connection Test the connection. If the HDMI cable isn't working, turn everything off and reconnect the original cables to manually change the settings.
  8. Step 6 Adjust the settings Turn the system back on, select Settings, Display Settings, Video Output Settings, and then HDMI. Repeat the process for your Audio Settings. You can now experience your games with the highest video and audio quality available.
Dec 01, 2014 | Sony KDF-E50A12U 50" LCD HDTV
How to connect sony ps3 to toshiba 32av500a
Use any HDMI cable to to this.
Connect cable to the "HDMI" port on the back of the PS3. Connect the other side of the HDMI cable to the "HDMI" port on the Toshiba TV. If the Toshiba TV has multiple HDMI ports, make note of which port you plugged the HDMI cable into.
Change the Toshiba TV to its "HDMI" video display mode. Press the "Power" button on the PS3 to turn the console on. The PS3 will automatically detect the HDMI cable. Select "Yes" to use the audio and video from the HDMI cable. Select "Yes" to have the PS3 automatically use the optimal settings for the Toshiba TV. Select "Yes" to accept the recommended resolution. Press the "X" button to save the settings
Dec 22, 2012 | Toshiba Televison & Video
How do i make my resolution go up on a ps3 from 480 to 720
Check out this Youtube video - it explains exactly how to do this. It's got great information and very complete. Since you've already got an HDMI cable, you don't need to buy anything else.
Nov 27, 2012 | Computers & Internet
Everything is hooked up and the ps3 turns on but it doesn't show up on the T.V
  1. Make sure the HDMI cable is connected to the HDMI OUT port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the HDMI Input port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive power button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light --> green light --> then back to red light). This will ensure that you have held down the power button long enough to reset the Video Output Settings.
  3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Jun 27, 2010 | Sony Playstation 3 (PS3) Console
Hook up computer to tv
The Vizio GV47LF HDTV's connection bay has everything we'd expect. It includes a pair of HDMI inputs which can take 1080p sources (at 60 but not 24Hz), two component-video inputs, one A/V input with composite video and one with composite and S-Video, one RF input for cable for antenna connections, an optical digital audio output, and a VGA-style PC input for PC connections.
If you're connecting a computer, you'll probably be disappointed that the VGA input maxes out at 1,360x768 resolution (which did look pretty good) instead of the full 1,920x1,080. We did connect a PC via HDMI and got 1,920x1,080 resolution, but the image didn't look as sharp as the 1,360x768 version. Again, we believe this has to do with the lack of a dot-by-dot mode, although perhaps people playing with picture settings, either in the Vizio or in the video card's drivers, can achieve a better-looking higher-resolution computer image. All-in-all, shoppers looking for a big computer monitor would be better served by the Westinghouse LVM-47w1.
Jan 30, 2010 | Vizio GV47LF Television
PS3 no picture problem..
Try using RGB cables and unplug the HDMI cable from the PS3, then while the PS3 is off, hold down the power button/sensor on the PS3 untill you hear a beep or a few beeps. This will force the PS3 to automatically detect the TV/cable resolution settings. Hope this works.
Aug 25, 2009 | Sony PlayStation® 3 (80GB) Console
Ps3 has no video
I would first try changing the inputs if there is an HDMI cable connected the PS3 will detect it and change the output to HDMI. Make sure when you connect any HDMI cables that the power is off on ALL Units that are using HDMI. Connect the cables then power up all units. Change TV and Receiver or Amp to correct HDMI Inputs. On the PS3 go to Display Settings over to the left of the Crossbar. Select output settings and select HDMI and everything after select AUTOMATIC! Then Set your Audio (Also use Auto) and Save by pressing X.  Good Luck!
Apr 29, 2009 | Sony PlayStation® 3 (80GB) Console
Resolution problems/ Game problems
Well it might be becuase your ps3 is european. Im no expert on the matter, but when i bought an hdmi cable and hooked it up to my hd compatible tv, i switched to the hd input (which happened to be input4 on my tv) and a message popped up saying that the ps3 has detected hd output, would you like to change settings? and it did it automatically after i hit yes.
Jan 10, 2009 | Sony Playstation 3 (PS3) Console
Hitachi 46W500 loses video after 10 seconds when connected to motorola HDPVR using HDMI/DVI cable. Works with Yb Yr...ideas?
Check your setup in HDPVR lower resolution to 720P or 1080I or check HDMI cable adaptor or set your Hitachi on auto detection video in MENU
Good luck
Dec 02, 2008 | Televison & Video
Televison & Video Logo
119 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
