Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Our Mitsubishi WD 52525 goes to blue screen and shuts off.
Our Mitsubishi WD 52525 will be on for a while and then become a bright blue screen. The green light flashes and then the TV shuts off. You have to wait until the green light stops flashing to turn the tv back on. The picture has also become very bad, it is blurry, dark and cannot tell that HD TV is on.
  • Anonymous Mar 18, 2014
    No picture screen
  • 64 Answers
It sounds like you TV is overheating and the video is suffering and the lamp is overheating as well. Also, if your TV is over 2-3 years old, the mirrors (behind and below the big front screen) desperately need to be cleaned. Clean all filters and fans as well. (Look on side and behind the unit). Is the TV in a "hot" environment and/or dirty environment? DLP TV's are NOT sealed units. They need to be cleaned every few years to work well to have a good, clear, bright picture.
Posted on Aug 01, 2009
SOURCE:
My Mitsubishi TV is flashing a green light and gos to the blue welcome screen,does anyone kno what wrong with my tv?????????
I have an old Mitsubishi Tv , your instruction manual is good and thorough and if you don't find it there check online with http://www.mitsubishi-tv.com/ use the support section there.
Jul 14, 2012 | Mitsubishi WD-73C9 73" DLP TV
Mitsubishi 52'' TV Model WD52525
U restart the tv,u hear alots of clicking?That mean the Ballast is dead or have problems,that why ur picture lamp not sustaning the picture.Replacing the Ballast might or will sustance the picture.
May 18, 2010 | Mitsubishi WD-52525 52" Rear Projection...
I have a mitsubishi tv model wd-52525 and the green timer light is flashing and it will not turn on. Just bought expensive bulb and replaced it and still blinking
Probley should check the DM board for bad capastors. DM board is inside of a metal case should be on left side of tv when looking from rear capastors should be marked 16v 1000 uF on them should be 4 of them about 1 inch tall green or black or blue or brown maybe even yellow in color if bulage on top then then thay are bad if not still could be bad common problem need to check may or may not be your problem does couse the power light to blink non stop.
Oct 01, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Blue screen and steady green status light.
mitsubishi will rebuild the chasis for $200 with a 6 month warranty
mits.parts 1-800-553-7278
fax 1-706-654-4299
Sep 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Wd-52525
This chassis has bad capacitors on the PWB,FMt, DM and the other boards that need to be replaced. They are all jamicon capacitors 1000uf and larger there are roughly 10 in the set that need to be replaced. Let me know if you need further instructions on this model.
Apr 10, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-62628 power shuts off!
hold the MENU and DEVICE buttons when turning on the TV and get error code
Dec 17, 2007 | Mitsubishi WD-52525 52" Rear Projection...
TV Shuts down
convergence amp IC's i would start with.
Dec 03, 2007 | Mitsubishi WD-52525 52" Rear Projection...
WD52525 had a blue screen when turned off
Perfect Blue screen usually means video problems. Leave unplugged and try again to make sure.
Aug 12, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
501 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
