Question about Crosley CAWC529JQ Top Load Washer
Why my crosley washing machine model CAWS823JQO made loud nosie then stopped spining
    Novelist:
    Scholar:
  • 166 Answers
Likely possibilities:
  1. Coupling between motor and transmission has broken.
  2. Transmission has failed.
Number 1 is cheap and relatively simple to replace. Tip the machine up in front and place a support under the front edge of the cabinet. Look for broken pieces on the floor. See if you can freely rotate the motor shaft without affecting the transmission shaft. Check that the transmission shaft can be turned by hand. If yes to both, replace the coupling. If it breaks again after a short time, transmission is likely bad
Number 2 is expensive and difficult. If the coupling's not broken and the motor is operational, OR the coupling breaks again after only a short time, then replace the transmission, or the whole machine entirely.
Posted on Jan 03, 2015
5 Suggested Answers
6ya staff
SOURCE:
rickyrt441
Richard Hale
  • 4399 Answers
SOURCE: my washer machine is not
Have you checked your belt? Have you tried to reset it?
Posted on Mar 06, 2011
john_cross
  • 6277 Answers
SOURCE: crosley washer (caw12444xwo) is not
Contact the vendor before doing anything else, especially if it is new as it will be under guarantee!!! Even if it is not new it should be under some sort of guarantee. Washing a blanket as a first try is possibly not the best thing to do- garments, sheets are not 'heavy' items and should let you get used to a 'new' machine ;-0)
Do you have a manual? If not you will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on Jun 16, 2011
caroldon
  • 17130 Answers
SOURCE: MODEL NUMBER CAWS9234BQ0 CROSLEY Washing machine water leaking
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Posted on Sep 04, 2012
chrispolkele
Electrolux
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: our crosley washing machine (model # cfw50000fw1) will not spin
    Hello - Does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned, or you have another issue with the door lock assembly or the timer and control board not communicating correctly.
    Posted on Nov 02, 2012
    Air power bubble washing machine model -dwf -1150p
    Daewoo Airpower Bubble Wash Machine Model - DWP - 1150P
    My Machine does not want to spin anymore. It makes a knocking sound and then stops and starts filling up with water again, then drains it and wants to start spining and again makes a loud knocking sound and the repaets the already mentiond sycle. Can you help me with this problem? Does Daewoo not have service centers for these machines?
    Apr 21, 2013 | Washing Machines
    Crosley washer (caw12444xwo) is not filling up all the way and is not spining out all the way, just got it today and just tryed to wash a blanket?!
    John C.
    Jun 16, 2011 | Crosley Washing Machines
    My washing machine sounds lika a tank when its spinning i think its the bearings
    Usually, if it is making loud nosies and thumps when spining, it is your basket drive. Of course, it would need changed.
    Mar 03, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
    Wasing mechine does not stop spining after draining water &keeps spining ,does not stop automatically untill i stop manually eitherby opening the lid or pulling the knob
    You need to replace the timer switch on your machine. If you will post your Maytag model number I can direct you to the part you will need.
    Happy Holidays
    Dec 13, 2010 | Maytag Washing Machines
    Making loud nosie
    Here is a tip that I wrote about dryers and noises...
    It will help you determine what is happening there...
    Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
    http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
    heatman101
    Jul 09, 2010 | Crosley CDE6000 Electric Dryer
    My front loader wont pump out the water when spining and when the machine is washing it makes a terrible loud screeching noise.
    Mine does the exact same thing, only now I can only wash underwear in it as anything else is too heavy for machine to turn while washing.... My socks have dissappeared wonder if thats whats stopping it from turning or maybe thats just my messy kids making them dissappear!lol I've all but given up on it and think I'll dump it for top loader...
    Feb 16, 2010 | Samsung WF337AA Front Load Washer
    My zanussi washing machine is leaving little black spots and holes in my clothes why?
    well my washing machines is make loud nosies ???? any ideas what wrong
    Feb 14, 2010 | Zanussi Washing Machines
    WHIRPOOL WASHER LSQ9564MQ0 Started making loud
    judging by the description i would say more likely the coupler
    its a three peice part that sits between the mototr and transmission, kinda like a clutch,
    anyway it is easily repaired
    and available on appliancepartspro.com
    type in your model number.....
    look for motor coupler
    Oct 13, 2009 | Washing Machines
    Pav2300aww spinning very slow,and not draining
    In all these Cases it sounds like a faulty lip seal. These special seals have Sealed bearings inside. Water gets through the seal and into the bearing which causes it to thump (like a helicopter) or squeal very loudly. As far as draining, the machine has to reach a curtain speed before the pump can turn fast enough to work.
    Nov 02, 2007 | Maytag Performa PAV2200
    Crosley CAWC529JQ Top Load Washer Logo
    120 people viewed this question
    Top Crosley Washing Machines Experts
    peter gittos
    peter gittos
    jdthefixer
    Evan Benson
    Evan Benson
    Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
