Question about Panasonic NV-GS50 Mini DV Digital Camcorder
How to take tape out from camcorder with no battery
    New Friend:
  • 6 Answers
How to take the tape out from camcorder with no battery?
It depends.
If you want to keep using the camcorder, you should buy a proper AC adapter.
On the other hand, any repair depot will gladly take the tape out for you, either for a modest fee or even for free if you offer them the camcorder.
Posted on Dec 25, 2014
6ya staff
SOURCE:
How to fix sony camcorder with tape deck that won't close. camcorder squeals and ejects tape.
bit late...but. STOP ASAP! by removing the battery, after removing battery, wait 20 seconds, re-fit battery & CLOSE the cassette door.
then wait 10 seconds, slap the closed door twice quite firmly. then open, if it opens, discard that cassette tape, clean the players head using cleaning tape.
use new cassette tape.
Jun 30, 2015 | Sony Video Cameras
Play back of video recorded on a different camcorder
sir,
you must have run a dry run before recording them in blank tape
Jan 11, 2008 | Sony Handycam CCD-TRV87 Camcorder
Canon charge light blinks 7 times
If your Sony camcorder displays a tape transport or mechanical error code always try resetting the camcorder. This is done by removing the battery or ac power, wait 10 seconds, reapply the battery or ac power and try again. If it still goes into error try another tape. The camcorder will not always display an exact error code. Sometimes you may see an error message such as, "Reinsert the cassette", on the LCD screen. This is the camcorders way of saying, "Take the tape out and try again." Try reloading the same tape as well as a new tape. If the camcorder is still going into error this means it is time to send it in for service or repair.
The camcorder may also sometimes display a "Reattach Power Source." This is the camcorders way of saying,"Try resetting my system,so I can try again." Many people mistaken this error and think they have a problem with the battery or ac adapter. This is not true and has nothing to do with your battery or ac adapter. Reset the camcorder by removing the battery or ac power, wait 10 second, reapply the battery or ac power. If the error reappears the unit needs to be serviced or repaired.
Jan 23, 2013 | Canon VIXIA Video Cameras
I have a sony dig 8 trv340 and am receiving an error code of c31:42 what does this mean?
In DCRTRV430 Camcorder, the C:31:42 error message is a Self diagnostic display. This message can be clearly identified by the help of a Sony Authorized service technician. Each of these codes indicates the symptoms and resolutions of the Camcorder. In C:31:42, the issue is with the tape and the tape mechanism.
I suggest that you remove and reinsert the tape to check if it helps. You may also try inserting new tapes in the Camcorder. Please remove the battery and/or power cable, connect, and perform operations from the beginning. You may also try resetting the Camcorder back to factory default after removing the tape.
To Reset the Camcorder, perform the steps below:
? Please open the LCD screen to locate the RESET button.
? To reset the Camcorder, press the RESET button using a sharp-pointed object.
? Please make sure that the Camcorder is turned on while pressing the reset button.
Also, try turning off the Camcorder and remove the battery pack. Then move the 'Power Switch' of the Camcorder to the ON position
for 1 minute. After about 1 minute, move the 'Power Switch' to the OFF position.
Now reinsert the battery, turn on the Camcorder and check whether it is working fine.
Thanks.
KenSolutions
FixYa
Oct 23, 2010 | Sony Video Cameras
My sony handycam dcr-hc26 door won't close. error C:32:11
Remove battery/ power source from camcorder for minute, reattach battery/ power source and close the tape door.
If that does not solve problem then I'm afraid, tape mechanism got defective and will be replaced.
Let me know if you need tape mechanism part number info.
Thanks.
Dec 09, 2009 | Sony DCR-HC26 Mini DV Digital Camcorder
I have a Sony DCR-TRV250 Digital Handycam Camcorder. Currently a tape is stuck in it and the camcorder won't eject it. The tape unit comes out but won't open.
I got the tape to eject by removing the battery from the camcorder, putting it back on so that the tape would go back inside the camera. Then I had the tape eject again. Several times the tape would not be ejected but I repeated my steps until the camera released the tape.
Nov 16, 2009 | Sony Handycam DCR-TRV280 Digital Camcorder
Videotape is at end of recording space. went to record new event and tape came out of casette and will not play or rewind in video camera
Try another tape in camcorder to make sure that camcorder is OK.
If same problem comes with another tape, check any error sign blinks in camcorder LCD? Usually this kind of problem happens when Dew sensor activated.
Remove battery/ power source from camcorder for 30-40 minutes, reattach battery / power source with camcorder and try.
Let me know model and brand of your camcorder for more research.
Thanks.
Oct 31, 2009 | Sony DVM60PRL/1BP Premium Mini Digital...
Sony DCR-TRV238E
You need NP-FM30 Rechargeable Battery and Video-8 Tape for this camcorder as shown in below image..
Mar 03, 2009 | Sony Handycam DCR-TRV265E Digital...
Tape stuck in camcorder
Turn off
Take battery out
plug in to power
turn on
Tape shoudl pop out.
it worked for me!
Jul 31, 2007 | Sony 8mm Stantard Grade 120 Minute...
Panasonic NV-GS50 Mini DV Digital Camcorder Logo
80 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
