Question about Westinghouse TX-42F430S Television
Westing house tv wont detect hdmi and goes back to pc
Computer wont detect hdmi1 on tv
HDMI 1 and 2 are physical sockets. If you need it on HDMI 1, plug it into the HDMI 1 socket.
Feb 27, 2014 | Computers & Internet
Samsung sp01 is undetectable through PC HDMI I am
This could be as simple as a defective HDMI cable. Have you tried connecting anything else with this cable? Have you tried another HDMI cable?
Oct 21, 2013 | Fujitsu Siemens LifeBook® C1410 PC...
Can't get the hd on my tv to work with the hdmi cable - i only have one port in the back of the tv - the tv was taken to a friends house who tried the hdmi cable through a pc into the tv and it works
if it worke at your friends house then it must be the cable or what you are trying to use via the HDMI cable some devices turn of HDMI if it has been unplugged and you have to manually turn it back on itn setting. its a bit hard to do on some as they don't have a scart socket. but if you turn of the device for about half hour and have the HDMI lead in and turn it back on it will reset to HDMI. its a surge protector.
Oct 03, 2013 | Televison & Video
My ps3 is not working it wont show a picture and when you try to turn it og it goes bip bip bip
  1. Make sure the HDMI cable is connected to the HDMI OUT port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the HDMI Input port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive power button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light --> green light --> then back to red light). This will ensure that you have held down the power button long enough to reset the Video Output Settings.
  3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Jun 28, 2010 | Sony Playstation 3 (PS3) Console
No picture on Westinghouse flat screen tv
westing house flat screen tv hd...has sound no picture
Feb 15, 2010 | Westinghouse LTV-37w2 HDTV
Macbook Pro wont connect to Vizio tv
disconnect hdmi cable and shutdown pc, completely power it off. plug your hdmi cable back in to your pc and power it up. it should properly detect your tv. i use projector mode. tv must stay on while performing this procedure.
Feb 11, 2010 | Apple MacBook Pro Laptop Computer with...
TV wont detect HDMI Devices except a pc.
Something is wrong whith the HDMI jack it's self, or the electronic switching is not sensing a signal is present. In either case the board that has the HDMI jack you are using needs to be replaced. Most all these boards are double printed, Multi-layered or both which prevents replacing the jack it's self. I do have a question though, do you only have on HDMI jack on the unit or do you have another one available.
Jun 18, 2009 | Televison & Video
No signal on my TV
try connecting the ps3 to the HDMI only, now when the ps3 is off and all but the single red light is on rest your finger on the on button for about 8 seconds, as soon as you touch it it will turn on but just wait a bit and you'll here the a second beep- this should reset your ps3's video output settings. Try it out, it works for me when i go back and forth from av to HDMI.
Please remember to rate my response if helpful.
May 30, 2009 | Sony Playstation 3 (PS3) Console
JVC LT-32DS75SJ issue with HDMI
Try this
1. Turn ON TV
2. Connect PS3 to TV HDMI input
3. select TV HDMI input for PS3
4. turn OFF PS3 if it is ON
5. Press and hold the [I/O]Power button until the PS3 until you get the "HDMI Detected" message.
Also, this TV has a circuit that deactivates the HDMI if the rear cover is removed. It is possible the HDMI may have been turned OFF. This is reset in the service menu of the TV.
Dec 17, 2008 | JVC LT-32X575 32 in. HD-Ready LCD...
PS3 won't connect to TV with component video.
You need to connect the PS3 to the television with both connectors (HDMI and Component). Then in the display settings change it from HDMI to component and during the 30 seconds that the screen goes black you need to disconnect your HDMI cable from your playstation. Then switch to the input that the component cable is connected to on your television (ie. AV1, AV2, etc). From here you will see the countdown for the test and you can continue with these settings.
Nov 20, 2008 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
Top Westinghouse Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
