Question about Westinghouse LTV-32w1 32 in. HD-Ready LCD Television
LCD tv screen black with ones no pic has sound
Connected to cable box sound no picture reboot left tv on 3 hrs. fine. turned off. 2 hours later turned on now no pic just sound. When the tv is cold no pic. when warm pic. ???
https://www.Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc
May 13, 2017 | Sony Televison & Video
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
I have a hisesense 40" lcd lked tv.i grabbed it fron the top and my finger touched the screen.now its has about 12"black uneven spot and in the spot i have rainbow lcolor lines..plus one blue vertica
It sounds like you cracked the screen. If it is cracked, you cannot fix it. Your only options are to replace the screen (BIG $$$) or buy a new set. If you can email me a pic of the TV I can tell you for sure if the screen is cracked. LCD screen are very thin, about as thick as a dime and it doesn't take much to crack them.
info@back2lifeelectronics.com
Nov 25, 2012 | Televison & Video
I have one side of my tv is black and look like you have a negative picture
LCD it is likely an inverter board--one drives left and one drives right side of screen--a few combine both into a single board.
Apr 24, 2012 | Sanyo DP46848 LCD TV
Wife was watching tv when the tv went black but still has sound. thought it was the dish network but they walk her through it all and no pic what so ever even if we switch to dvd or the Wii just sound and...
Your LCD backlighting system is not functioning.Your LCD main board should detect the problem and would give you and error code.This needs an immediate service.See if the Tv is under warranty then you can return it an get a replacement.It usually the inverter that has the problem but also either one(even just one)baclighting bulb goes off it will shut off all the backlighting bulbs,thus a sound with no picture as a result.
Feb 02, 2011 | LG 42LG30 42 in. LCD HDTV
While watching it, the screen went black (totally). Sound was still there but no pic. When I tried a different channel to see if it was cable or tv, it shut off. Now the green light will come on and the...
The tv have a long board call a LCD inverter board.This LCD long inverter board,it dead.This long LCD inverter board,help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish long LCD inverter board for the replacement.
Oct 25, 2010 | Akai CFTD2011 20 in. EDTV-Ready LCD...
The screen stays black but have only the sound
if u have sound, hold a flashlight to the screen and look for a picture. if u see a pic, the backlight/inverter has failed.
Dec 06, 2008 | Televison & Video
Black screen no picture got sound
if its an LCD check by holding a flashlight to the screen looking for the pic. if u see the pic the backlight/inverter has failed.
Westinghouse LTV-32w1 32 in. HD-Ready LCD Television Logo
62 people viewed this question
Top Westinghouse Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
