Question about HP LaserJet M1522nf Multifunction Printer (CC372A)
My hp laserjet M1522nf is getting hang while scanning multiple document
I have installed everything and while scanning a single document it is working but while scanning multiple document it is getting hang
2 Suggested Answers
6ya staff
SOURCE:
pcdoctorX
  • 31 Answers
SOURCE: How do I scan a document on a HP Laserjet m1522nf...
install full software, download from www.hp.com
Posted on Aug 10, 2010
How do i make multiple pages scan as one document rather than each pages saving as seperate documents?
One of two things I can suggest:
1. make sure you are not scanning in JPEG or TIFF format as these are typically single page documents only. PDF is your best option for scanning.
2. Check settings, as some scanning software has an option that you can turn on or off depending on whether you want a single file with all pages or multiple files each containing a page.
Mar 09, 2015 | Canon PIXMA MP180 All-In-One InkJet...
How do i to scan multiple pages into a single pdf?
You can get third party software in order to avail the facility to combine pdf to a single file
Jul 26, 2014 | Brother DCP Office Equipment & Supplies
How can I print from the top of my brother printer
Hi
You cannot print from the top feed,
The use of the top paper feeder is the capability to make single or multiple photocopies and for single scanning or multiple scanning. All you have to do is to put single or multiple document in the top feeder and press the COPY BUTTON (third button-right side). Then it will feeds automatically.
The same with scanning, press the SCAN BUTTON (first button-left side) and it will scan single or multiple document.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
Apr 10, 2011 | Brother MFC-8460N Laser Printer
How do i scan multiple pages
Please perform the steps given below to scan multiple pages to a single PDF file.
NOTE: Before performing the steps please make sure that Adobe Reader is installed on your computer. If not installed then goto www.adobe.com and install Adobe Reader.
  1. Open HP Solution Center.
  2. Click on Settings.
  3. Click on Scan Settings.
  4. Click on Scan Preferences and Select the option 'Prompt for additional scans when preview is turned off'.
  5. Click on OK to apply changes.
  6. Now Click on Home and click on scan Document
  7. Select Document to File under scan shortcuts.
  8. Uncheck the option Preview Scan at right bottom of the scan window.
  9. Now Click on scan to scan document.
  10. When prompted for additional scan place the another document on scanner glass or ADF and Click on Scan.
  11. After scanning is complete Click on Finish to save the scanned document
  12. To Locate the scanned document (PDF) goto My Documents folder and Open My scans folder.
Oct 12, 2009 | HP Officejet 6500 Wireless All-in-One...
I can't figure out how to scan multiple pages to one file
Hi There !!
Thank you for choosing fixya.com
It is possible to scan different batches scanned from the ADF into one PDF file. When loading more pages in the ADF after the first realm is finished, it asks if you want to continue scanning to the same file. After that, it will continue scanning to the same file. However, this feature can be selected in the Adobe Acrobat application itself. From HP software, if we load the paper after one realm of paper in the ADF is finished, it will scan the second realm to a different file. If you want to continue scanning to the same file, you need to have either Acrobat Exchange or Adobe Acrobat installed on the computer. Adobe Reader will not provide this feature. After installing either Adobe Acrobat or Acrobat Exchange, perform the following steps to scan pages to a single file:
  1. Make sure your scanner is turned on.
  2. Start Acrobat Exchange or Adobe Acrobat.
  3. Put the document into the scanner (usually face down on the scan bed).
  4. In Adobe Acrobat, click File , then Import , and Scan .
  5. Select the device and whether you are scanning a single- or double-sided document.
  6. The scanning software opens and the scanner completes a preview scan.
  7. When the preview scan comes up, make any adjustments you would like, including selecting the area you want to appear in the final scan.
  8. Click Scan . This will get the final scan into the computer.
  9. Your scanning software should take you back to Adobe Acrobat.
  10. In Adobe Acrobat, you should see a small window asking you if you want to scan another page. If the document you are scanning has more than one page, click the Next Page button. If this is the only page, click Done .
    NOTE: Scanning multiple pages causes each page to append to the previously scanned page. If you have multiple pages, but want them to be in different files, click Done after each page to create separate files.
  11. When you have scanned the last page, click Done on the window described in step 10.
  12. Your scanned pages will open in Adobe Acrobat. Scroll through to make sure that everything is there.
  13. Click File , and then Save As to name your file and save it.
Still unable to figure out, How to do this? Here are some tutorial on HP website that might help.
http://h20000.www2.hp.com/bizsupport/TechSupport/SupportTaskIndex.jsp?lang=en&cc=us&taskId=120&prodSeriesId=1161389&prodTypeId=18972&supportTaskId=23095
Hope this would help.
Regard's
Anurag Shukla
Sep 04, 2009 | HP LaserJet 3055 All-In-One Printer
Scanning multiple pages as a single document
The pages you scan in are each individual "pictures" which are very different than the text in the everyday word processing file. What you can do is to make a new word processing document and insert each of the scanned pictures into this new document in order. This will allow you to print all the pages in one job by printing the word processing document. As far as I know there is no way to scan all of the pages into one single file.
Carl
Dec 05, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Scan multiple page with X4550
The 4550 will not allow multi page scanning into a single doc using the provided software. You should try another scan software that is TWAIN or WIA compatible. Those should work okay if you are using a USB connection.
Aug 23, 2008 | Lexmark X6570 InkJet Printer
HP LaserJet M1522nf Multifunction Printer (CC372A) Logo
50 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
