Question about Danby Dehumidifiers
Dehumidifier danby DDR 501
Fun doesn't work
  • 3,103 Answers
Do the panel indicators light up? is the tank full? is the tank properly seated in position..check the tank switch for operation..
Posted on Aug 03, 2014
5 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 117 Answers
SOURCE: Danby Dehumidifier DDR557HE has never dehumidified
either lacks coolant or compressor bad
Posted on Jan 05, 2010
Testimonial: "Thank you, I didn't even know a dehumidifier had coolant. "
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: My Danby dehumidifier will not dehumidify but the
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Posted on May 10, 2010
jyackle5
Jyackle5
  • 8197 Answers
SOURCE: I'am looking for an owner's manual Danby DDR 451
You can get the manual on the link below. Click on where it says it is free PDF then click on the stars to download.
http://safemanuals.com/user-guide-instructions-owner-manual/DANBY/DDR451-_E
Good Luck
Posted on May 26, 2010
Rich Landrum
  • 4736 Answers
SOURCE: just purchased a Danby dehumidifier
Depending on which mode you have the unit set on, will determine if it shots OFF entirely or the fan continues to run. In the Constant or Continual mode, the compressor will turn OFF, once the humidity extraction level has been reached. But, the fan will continue to operate, in an effort to keep the air circulating, so that if the humidity level rises, the compressor will turn ON and start extracting again.
In Timed Mode (usually 2 hour or 4 hour) , when the compressor turns OFF the fan does too.
Hope this helped you. Please let me know. Thanks.
Posted on Jun 06, 2011
How do u operate Danny dehumidifier model DDR607EE I don’t have a manual for it
I found a PDF of the owner's manual for the Danby DDR607EE at Reliable Parts, http://www.reliablepartsinc.com/danby/dehumidifiers/DDR%27S/DDR607EE/ . The direct link to the manual is http://www.reliablepartsinc.com/danby/dehumidifiers/DDR'S/DDR607EE/OWNERS%20MANUAL.pdf . However, before you use this dehumidifier, go to https://www.recallrtr.com/dehumidifier . Use the drop-down menus to select Danby and the model. Then enter the serial number and make sure that this unit doesn't have the manufacturing flaw that could cause a fire.
I hope this helps.
Sep 11, 2018 | Dehumidifiers
Fan running but no water and hot on inside. 50 pint danby premiere dehumidifier
Compressor not running, possibly because refrigerant is low
Jul 30, 2016 | Danby Dehumidifiers
I have a danby premiere r410 a, the compressor will not come on
Hi There,
I would love to help you, however I am not sure which model you have. R410A is not a Danby model number. The correct number can be found on the back of the unit as well as on the front cover of the owners manual. The numbers usually begin with "DDR"
Jun 28, 2012 | Danby Dehumidifiers
Looking for replacement blower fan for Danby premiere DDR 7009 REE. The part is ABS D5304-130. Any help?
If your Danby humidifier is still under warranty, call 800-263-2629. If it's not still under warranty call
800-496-6049.
Jun 16, 2011 | Danby DDR7009REE Dehumidifier
I have misplaced my operating instructions for my Danby dehumidifier model DDR 3008 EE. When I plug it in, turn it on, it runs for maybe a minute then the red full water tank lights up and it quits. The...
The model number you listed did not reveal anything. However, the link below is a link to a Danby model, that had a model number closest to yous. Most of the units have the same parts and function. Click n the literature tab and the Owners Manual will come up.
http://www.danby.com/product/DDR30E/12
Hope this helps you. Please let me know.
May 15, 2011 | Danby Dehumidifiers
I need a operation manual for a Da by DDR 451 for some reason I cannot get one from your site. Can you help me. Bernard Bouchard
Bernard, the Model you listed is no longer manufactured. However, you can obtain an Owners Manual by calling Danby Customer Service at 800-263-2629.
Apr 13, 2011 | Danby DDR451 Dehumidifier
Good Luck
May 26, 2010 | Danby DDR451 Dehumidifier
Same Problems as Everyone Else
I have a Danby DDR 458EE dehumidifer that I purchased May 27, 2008.
Used it for the summer and stored it until May this year. At the end of July of this year it started not working. It freezes up. Called Danby, they told me it was out of warrenty and to take to a repair shop. Problem being it was leaking freon so have it recharged. Called the repair shop and they explained that it is a closed system and if it is leaking Freon, they can not recharge it until the leak is found and repaired. It's against the law to discharge freon in to the atmosphere. Stated cost to repair it would be greater then buying a new one. Called Danby back and explained what repair person said. Still waiting to see if they will give me a pro-rated refund.
Jun 13, 2009 | Danby DDR6588EE Dehumidifier
Danby DDR401. Can't get it to remove moisture from the air.
Hi Fred, let me see if I can assist you. If your dehumidifier doesn't seem to run often but the humidity in the room is high, try adjusting the humidistat control on the dehumidifier to a dryer setting. If the dehumidifier seems to run constantly, but there's little or no water in the container, there may be a problem in the refrigeration system. Try cleaning the unit. If that doesn't work, you can't repair the refrigeration system yourself, you need a qualified appliance repair technician to do that.
May 27, 2009 | Danby DDR401 Dehumidifier
Dehumidifiers Logo
145 people viewed this question
Top Danby Dehumidifiers Experts
Bill Long
Sr. Pelo
Sr. Pelo
Vincent G
Vincent G
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
