Question about Ascend Huawei Y320 White GSM Unlocked Android Phone
Huawei settings How do I activate Remote speaker phone? That is which button do I press when driving car so I can talk remotely. Thankyou, Malcolm
  • Ascend Master
  • 3,247 Answers
I am guessing you are interested in handsfree call conversation. Whilst it is mentioned on the specification sheet of the phone that it has speaker phone, I do not see any mention of how this is used in the user manual. My guess is that only way to use a remote conversation with this phone is to have a bluetooth headset. Refer page 51 and 52 in the user manual from this site.
Ascend Y320 Manuals Support Huawei Consumer BG
Posted on Sep 08, 2014
Instructions on how to program GM remote key OEM 22733524
Switch ignition ON.
Repeatedly press vehicle information button (it is usually located on the right or left from the steering column depending on year make and model until PRESS TO RELEARN REMOTE KEY is displayed.
Press set/reset button until REMOTE KEY LEARNING ACTIVE is displayed.
Programming mode activated, proceed as follows:
Press and hold LOCK and UNLOCK remote buttons on first remote transmitter simultaneously for 15 seconds.
Wait for acoustic signal (indicates correct programming).
Repeat above procedure to program remaining remote transmitters.
Switch ignition OFF to exit programming mode.
May 17, 2015 | 2007 Pontiac G6 GT Convertible
Sony bravia sync
I'm assuming this is the Bravia "Scene" button that activates your custom sound and video settings, like cinema and sports and such.
Does the rest of your remote work? It's possible that the one button on your remote doesn't work. See my other post here (Cannot control receiver from remote) to check if your remote is working by seeing if the LED's on the end light up. Try buttons which do work, like volume, channel, menu, whatever and look for the LED lighting up. Then press the Scene button and see if the LED lights up. If it doesn't and you've tried pressing firmly, then likely the button is dead and it's time for a new remote. It's very rare, but it can happen. Talk to your sales centre or manufacturer for assistance.
If it does light up, and other functions on the remote work - then it's possible you can only use the Scene feature on the remote when the TV is in a different "state". For example, you might not be able to use it while watching a movie or show, but you may have to enter a menu first. This sounds silly - why have a button that only works some of the time? Because sometimes engineers (or the guy who develops the TV software) are forced to make things in a less than ideal way, for one reason or another. Now, as to what menu you might have to enter - try the general Menu, then try Settings, and look for something like "picture", "setup", "scene". After each on-screen menu change (if the image on the screen changes), try the "Scene" button again.
Apr 26, 2014 | Western Digital My Book Studio LX 1TB...
Message volume fixed
Zone 2 Setup on the RX-V773 using the ZONE2/PRESENCE Extra Speakers The RX-V773 extra speaker terminals can power one set of speakers for Zone 2 or Presence speakers. If the extra speaker terminals are utilized then the RX-V773 cannot be set for Bi Amp (Surround Back/BI-AMP terminals). Setting the Extra Speaker Terminals Note: The RX-V773 remote control will be used to access the On Screen Menu of receiver. 1. Press the On Screen button on the remote control to enter the On Screen Menu. 2. The On Screen display should be displayed on the TV/Monitor. 3. Press the Arrow Down button on the remote until Setup comes up in the screen. 4. Press the Enter Button on the remote control. 5. The Setup Menu will come up across the TV/Monitor screen. 6. Use the Arrow Left & Right buttons on the remote to navigate to Speaker. 7. Press the Arrow Down button on the remote to select Manual Setup. 8. Press the Enter Button on the remote control to enter Speaker Manual Setup menu. 9. Speaker Manual Setup menu with Power Amp Assign highlighted will come up. 10. Press the Enter Button on the remote control to enter Power Amp Assign menu. 11. Speaker Manual Setup, Power Amp Assign menu will come up with Basic highlighted. 12. Press the Arrow Down button on the remote to select 7ch+1ZONE. 13. Press the Enter button on the remote to select 7ch+1ZONE. 14. Press the On Screen button to exit the on screen menu. To control Zone 2 using the RX-V773 remote, the switch at the upper left side (above the BD/DVD Scene button) of the remote must be set to Zone 2. To see the operations on the front of the Yamaha receiver you must press the Zone Control button on the front of the receiver. Note: Only analog signals can be sent to Zone 2. If you want to output the sound from Zone 2, connect an external component to USB Thumb drive, USB iPhone/iPod, Network, AV 5-6 or Audio 1-2 by analog connection. For AM/FM radio the antennas must be attached.
Aug 19, 2012 | Yamaha RX-V773
How do i manually release the rear door on a ssab 9-3 2003 as the door module has failed
Trunk Lock After Closing
Desc.: What happens to the trunk lock when closing it.
Settings:
Yes: Automatically lock Boot on closing
No: Boot can be reopened using micro switch button located on the trunk/boot
* Trunk Lock After Drive Off
Desc.: Should the trunk be locked at drive off or after 30 sec.?
Settings:
Yes: Trunk/Boot will automatically lock when vehicle increases speed
No: Trunk/Boot will remain closed, however will be in the unlocked
condition if No was selected in the previous option.
* Door & Trunk Unlock at Key Out
Desc.: When the is removed from the center console should door/trunk
be unlocked?
Settings:
Yes: All Doors & Trunk/Boot will Unlock when the Key is removed from
the Ignition Switch If Driver frequently locked all Doors when
driving
this feature would be beneficial.
No: Doors and Boot will remain in the same condition as they were
prior
to Key removal
* TSL Locking Logic (Theft Security Locking/Deadlock)
Settings:
TSL at first Press: Default Setting. All Doors will lock in Deadlock
Mode
TSL at Second Press: All Doors will lock in Deadlock mode at the second
press of the Remote.
* Lock /Unlock Acknowledge
Settings:
None : No acknowledge will be visible
Indicators: Indicators will blink as acknowledge
* Follow Me Home Function
Settings:
Tail Light: When selected Tail Lights will be illuminated
Back Up Light: When Selected Reverse Light will be activated
Tech 2 Body Exterior Lighting & Horn
* High Beam Follow me home Active Time
Desc.: Follow Me Home Active Time can be adjusted between 0- 10 minutes
Settings:
This Feature can be turned on or Off .Yes / No can be selected.
Low Beam Automatic / Low Beam also in Position 0 (light switch)
Yes / No
- Daytime Driving Lights can be activated
* Parking Lights
Settings:
Act as Lead Me To the Car Light.
* Park Light On Reminder
Settings:
On / Off
If Ignition is turned Off and the parking lights are active, Driver will
be warned if set to on.
* Show Trailer Light Outage
Desc.: REC will detect blown trailer light and display on SID
Settings:
Yes or No
* Trailer Light / Fog Light off
Settings:
Yes: Fog Light Rear will be disabled When Trailer is connected Yes
No
* Horn Lock Unlock Acknowledge
Settings:
On: Horn will honk when car is locked
Off: Horn will not honk if car is locked
Tech 2 Body Locking
* Panic Alarm Activation (Vehicles fitted with /Alarm only)
- Panic Button / Locking Switch
Central Locking Switch Driver /Passenger
Settings:
- Panic Button on Remote and locking switch inside vehicle will
activate alarm
- Panic Button will activate Alarm only
- Locking Switch inside vehicle (driver /passenger will activate
alarm only
- No Panic Alarm function required.
* Unlock Logic
Settings:
All at first press : All Doors will open & Fuel Lid will unlock if the
Driver or Passenger Door Switch is activated
Driver Door & Fuel Lid at first press : Only the drivers Door will unlock
& Fuel Lid will unlock when door
switch is activated
* Remote unlocking One Press
Settings:
All at first press: All Doors will open & Fuel Lid will unlock if the
Remote is pressed
Driver door & Fuel Lid at first press: Only the drivers Door will unlock &
Fuel Lid will unlock when the Remote
is pressed
Dec 17, 2010 | 2003 Saab 9-3
How do i turn up my back speakers?
Grab the remote for your vsx1018 and press receiver at the bottom of the remote then press the number zero button (this button acts as the channel level function when remote is in receiver mode) you will then notice that if you repeatedly press the zero button that it will cycle through each channel on the vsx1018 display (L for front left, C for center, R for front right, SR for side right, SBR for sarround back right, SBL for sarround back left, SL for side left, and last but not least SW for subwoofer rca jack output to your sub amp. After you have selected the speaker volume you want change ( SBR and SBL in your case) then push the left or right of the circle that sarrounds the enter button on the remote in order the fine tune the volume for each speaker,and after you are finished setting the volume the way you want then push the return button that is to the lower right of the circle that sarrounds the enter button on the remote. Cool huh!! :-) Oh ya, somthing else that is cool about the vsx1018, you can put music from your computer onto a thumb drive and then plug the thumb drive in the the ipod usb and the music will play!! IE press ipod button on remote and then use the circle to change music tracks.
Aug 29, 2010 | Pioneer VSX-1018AH-K Receiver
Code to activate
You will have to do the CODE SEARCH on this one,..Press TV once on the remote, press and hold the SET button until the LED blinks twice then release it, enter 9-9-1. The LED will blink twice, Point the remote at the TV and slowly alternate press between TV and POWER buttons, stop when the TV turns off after pressing POWER, if it does not have a POWER button, you can use 1-2-3, CH+ or PLAY. to lock in the code, press and release SET....hope this was helpful...
May 31, 2010 | One For All URC-3605 Remote Control
TV LC32SB24U will not respond to the remote control. I check the remote signal using a camara cell phone by pointing the eye of the remote towards the lens of the cell phone camera. I press each button on...
Are you using a remote from a cable issued cablebox or the orginal remote? I noticed my cable company DVR remote stopped working when the OPC setting on the Picture menu of the TV was set to the 'ON' position. Once turned to the 'OFF' position it stopped the OPC feature from activating which seemed to interfere with the response of the remote for some reason.
Mar 22, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
How do I program my new Suzuki keyless entry remote to work with our new SUV?
I bought a remote the other day and got these instructions with it. They worked!
1. Make sure vehicle is in Park
2. Press Vehicle Information button (has the icon of a car and an 'i')until 'PRESS *check mark* TO RELEARN REMOTE KEY' displays.
3. Press set/reset button. The message 'REMOTE KEY LEARNING ACTIVE' will display.
4. Press and hold the lock and unlock buttons on the transmitter at the same time for about 15 seconds. A beep will sound indicating that the transmitter is matched.
5. To match additional transmitters at this time, repeat Step 3. Each vehicle can have a maximum of four transmitters matched to it.
6. To exit the program mode, you must cycle the key to LOCK.
Jul 20, 2008 | 2007 Suzuki XL-7
Unlocking my DVD Player
Try this,it should work....Rod
To change the current region setting on this player
1. Press the Standby button on your remote control to place the unit into Standby
2. Press the Standby button on your remote control to turn on the unit
3. Press the Open/Close button on your remote control to open the drive tray
4. Press the Clear button on your remote control
5. Press the 1 button on your remote control
6. Press the 3 button on your remote control
7. Press the 6 button on your remote control
8. Press the 9 button on your remote control
9. Press the 0 button on your remote control
10. Press the Open/Close button on your remote control to close the drive tray
11. Press the Standby button on your remote control to place the unit into Standby
12. Press the Standby button on your remote control to turn on the unit
Jul 16, 2008 | Durabrand Televison & Video
Ascend Huawei Y320 White GSM Unlocked Android Phone Logo
235 people viewed this question
Top Ascend Cell Phones Experts
Marvin
Marvin
Are you an Ascend Cell Phone Expert? Answer questions, earn points and help others
