Question about Toshiba Televison & Video
What is the Remote Model for TOSHIBA Colour TV Model 2168TIV
I lost my Remote for TOSHIBA Colour TV Model 2168TIV. I went to buy the remote but they are asking for the remote model.Please let me know the Remote Model No which works for TOSHIBA Colour TV Model 2168TIV
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 70 Answers
In my opinion, you should not have to give them the remote number, but you can look this up by contacting the customer service website of Toshiba, giving them the model number of your tv..and explaining your situation...also check eBAY for remotes.
Posted on Sep 15, 2014
6ya staff
SOURCE:
Anonymous
  • 68 Answers
SOURCE: remote control will not work
That is certainly unusual for a remote receiver to go bad unless it was struck directly or exposed to damage. Anyway.... the procedure obviously involves getting to the PCB to replace the module. I've not worked on that exact model, but all CRT televisions are similar, and that one is made by Orion.
There really are two options: Front and back.
You can go in the back way, by removing screws and such until you can pull the rear housing off. Make sure you first unplug the unit for about 15 minutes. Leave it unplugged.
If you are uncomfortable doing this, then, please, buy a new TV.
I STRONGLY suggest that you discharge the main capacitor by grounding the anode. If you don't know what this means, then buy a new TV. You don't need a special tool, just a long, flathead screwdriver grounded with a wire to an earth ground will do. If your are afraid of getting shocked, buy a new TV.
The CRT will be mounted in a chassis attached to a main PCB at the bottom. It will be screwed to the housing face. You will have to separate the chassis/board from the face of the housing also, being careful to remove all the screws around the front input assembly. The housing removal is quite easy, but it will take time. You will then be able to locate the IR module at the front of the board. Carefully de-solder it and install the new one. Reassemble.
Somethings I would do before I undertook this venture:
Be ABSOLUTELY sure that the IR module is at fault. Not the remote.
Check the IR module for 5V at Vcc to rule out a faulty IC.
Confirm replacement module is similar in pin-out, freq. (bandwith), voltage
Reserve a good afternoon block of weekend time.
Chill some brews.
Create a large work space if you don't have a bench. And if you do have a bench, clear some space.
Be prepared to be without this TV forever, because everyone screws up sometimes.
The front inputs may give a bit of trouble. Take it easy there if you wish not to break anything.
If you are afraid to open the back. You could always go in the front. Unplug. Dremel a hole under the IR module using a depth limiter. Remove Vcc from existing module. Piggy back new module. Tada! Cake. Remember that is you put it under the board, the pins will be reversed.
If you are careful enough, after the anode, there is not much to screw up besides some broken plastic or bent front inputs.
Good luck.
Posted on Jun 30, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: old Sylvania model #6420FB lost remote how to switch to av mode
Unless the TV has a front-panel menu button and allows you to switch modes from there, you are out of luck. There are two possibilities. One is to try another replacement remote. If you get a universal remote made by the TV manufacturer (Magnavox), it may have buttons that will work. The other option is to purchase an RF converter, which will cost around $15. This will take the video/audio signals from the game and convert it to a channel 3 or 4 signal you can then tune in on the TV. The picture won't be quite as bright and clear as with direct AV input, but it will do the trick.
Posted on Jan 12, 2009
Anonymous
SOURCE: Phillips PC7225 Menu
Found it!
I have a Philips universal remote. After trying half of the codes for Philips TVs, I came up with one which allowed access to the SETUP menu. It was 0621. This allowed me to run the auto channel setup, as well as fix some of the other functions. I don't know if this works with all remotes, but if you try different codes, you should get lucky. I'm sure it helps if you have a SETUP button on your remote.
Posted on Mar 22, 2009
Anonymous
SOURCE: Matsui tv assistance
Have just read up on this. It seems you have to hold the - volume on the front of the TV at the same time as the no 7 on the remote for 5 secs to reset the PIN number.
Posted on May 26, 2009
Anonymous
SOURCE: no signal
Hopefully, anyway.
I had a similar problem, and my solution was this: I pressed menu on my TV and using my universal remote, went into setup, and then channel search (or near to that), at which point it began searching for analog and digital channels. This can take up to approx. 30 minutes. I suggest you occupy yourself while waiting; it is a sluggish process.
If you want assurance, your TV will have the majority of analog channels (basic cable), and a couple digital. I am basing this wholly on my experience, however. Once finished, it should switch immediately so a channel. Mine was a weather station.
I hope this is successful in helping you and those in the future.
Posted on Jul 15, 2009
I have a toshiba dramatic theatre tv that is on wheels that i received from someone, but the remote is lost and the convergence settings is out. where can i buy a remote for this tv in cape town as th
Hi Carmen.
I also had one of theses rear projection Toshibas. Tedelex are the agents for Toshiba in SA, however they aren't very helpful. Your best bet is to buy a one 4all remote and go through the Toshiba codes. This is what I did when I lost my original remote. It worked fine for me. I have since given this TV away so I can't give you the exact code, but those in the instruction manual do work.
Jan 07, 2015 | Toshiba Televison & Video
Can any one tell me the Remote Model No for TOSHIBA Colour TV Model No: 2168TIV
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops.
Sep 10, 2014 | Toshiba Televison & Video
Remote to an OLD Toshiba TV (model 37a33) is lost and I'd like to replace it OR possibly use cell phone for IR signal. Reason is I want to change video source but TV does not have button to allow it. Any...
If you wish to buy its original remote control, contact the authorized service center for Toshiba. If you wish to buy a universal remote control, check the code list to the remote control you do buy, have set-up codes to Toshiba TV. Setup codes to Toshiba are
1088 1077 1061
1070 1203 1423
1093 1466 1048
1213 1047 1141
1046 1231 1144
1276 1054
If you wish to get more details, check the sites linked here. It has setup code list and setup procedure to many popular brand remote controls. Check it, and find out which brand remote control have setup codes to your Toshiba TV, and buy that brand remote control according to availability. Brand name to a universal remote isn't a matter, but it should have setup codes to Toshiba. http://remotesearch.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 05, 2013 | Toshiba Televison & Video
I 've lost the remote control for our toshiba super c3 tv, can I buy another Toshiba control ?
Try the toshiba site or Google the model number with "remote" to try to locate an original not a universal.....
Nov 05, 2012 | Televison & Video
Toshiba tv lost remote how can I make adjustments to television
You must have its remote control to adjust most of its functions. Try to buy and original one. Contact the nearest authorized service center for Toshiba at your town.
Oct 22, 2012 | Toshiba Televison & Video
I lost the remote and can no longer change the input. The only buttons on the tv are power, channel up and down, and volume up and down. I have also tried changing channels past 0 and nothing is working. I...
Hello
It will be best for you to buy its original remote control. Universal remotes may also work with it, but some functions may not work properly. You can buy it from the Authorised Service Center for Toshiba at your town. Just give them the exact model number of you TV set [which can be noted at its back side]. They will give you the exact original one.
RCA RCR 311B model universal remote have setup codes for Toshiba. You may also try this remote. The codes are:
1047, 1071, 1103, 1105, 1108, 1159, 1163, 1178, 1188, 1190, 1191, 1196, 1211
I strongly advice you to buy its original one. OK.
Sep 04, 2011 | Toshiba 27AF45 27" TV
Lost the remote for my toshiba tv model 27a32, need the model number to replace the remote (prefer to get a toshiba remote rather than a universal)
The model number will be on the back of the tv. You'll have a model number serial number and a few other numbers. But for the price of a factory remote you can get a really nice universal....
Dec 07, 2010 | Toshiba 27A32 27" TV
Need the tv coes for my toshiba tv
I have a older Toshiba TV CE20F10,but I lost the codes tomy TV,Ineed them.Tkank you
Dec 12, 2008 | Toshiba CT-90157 Remote Control
Remote control code
Lost Toshiba CF2047, trying to use a universal remote. I really need a code. Thanks
Oct 08, 2008 | Televison & Video
Rear projection
you will need the remote to adjust conversion and what not. www.replacementremotes.com can get your origional remote just enter the model number of the tv and it will pull up the origional as well as a substitute that will work all the functions.
Mar 23, 2008 | Toshiba 55H70 55" Rear Projection...
Televison & Video Logo
145 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
