Question about Westinghouse LTV-32w1 32 in. HD-Ready LCD Television
How do I reset the color balance to default
Everything looks purple and orange but no green tones
    Top Expert:
  • Westinghouse Master
  • 76,143 Answers
Refer its user manual for details. How to set it the color to its default settings, is described by it. Try a reset too.
To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Posted on Sep 16, 2014
6ya staff
SOURCE:
I have a 3 ton Bryant split unit I'M trying to rewire.
what colors are landed where on the tstat? and does the tstat wire that goes BOTH inside and outside have the same colors. also why are you in this situation, has everything been unhooked?
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Feb 09, 2018 | Heating & Cooling
Problem with color on my lumix dmc-fh25 camera
Set the camera's white balance to match the lighting. Most indoor lighting has a yellowish cast to it, while by default cameras are set for sunlight.
Jan 10, 2013 | Panasonic Cameras
Is there a way to correct color issues on my lumix dmc-fh25
Jan 10, 2013 | Panasonic Lumix DMC-FH25 Digital Camera...
My tv only shows in green and purple
Have you examined the color wheel this set should have?
look for (remove lamp as it faces that) any segments broken or missing.
A color wheel also can have a high pitched or fan like sound but not always.
check the wheel first.
Jun 15, 2012 | Samsung HL-67A510 67" DLP HDTV
My CP2025 colors are not balanced. It prints purple, red, orange and yellow. Green is faded and looks yellow. Cartridges are new and look fine.
there is software cd along with printer u need to setup the software. if u installed it go to the main menu & find cartridge level. see if green is low. there are also utility like clean cartridge. use it. also reseat the cartridge. if nothing is working use new cartridge.
Sep 03, 2011 | HP Laserjet Cp2025n Printer
My kids changed the color on my 61 inch RCA and now i cant get it back to normal. Everything thats suppose to be purple is brown and pinks are orange and yellows are pale. Everything else is ok a little...
Someone probably played around with the "Tint" settings in the TV menu. The easiest way to fix it is to go into the TV picture menu and reset everything to the default settings. There's probably one option for "Reset to Factory Default" or something along those lines. Since every TV is different with this, you should read your owner's manual to find how to enter the menu and find the reset button.
May 04, 2011 | Televison & Video
What does the stereo colors stand for on an 1992 crown victoria Red, black, Grey/blue, yellow/black, white/purple, green/black ,blue/red, orange/green, white/green, blue/white, brown/yellow,...
Red = ground
black = ground
Grey/blue = Left rear (+)
yellow/black = ignition 12v
white/purple = right rear (-)
green/black = (could this be green / violet?) than it is 12v constant
blue/red = illumination
orange/green = left front (+)
white/green = right front (-)
blue/white = left front (-)
brown/yellow = left rear (tan / yellow) (-)
green/orange = right front (+)
orange/red = right rear (+)
blue = not used
Nov 10, 2010 | Ford Car Audio & Video
I need to know what does the colors on the harness to the sony radio mean?
Most aftermarket cd players have the following wiring diagrams
(+)Red..............12v ignition
(+)Yellow...........12v battery (Memory) Constant Hot
(-)Black............12v Ground
(+)Blue.............12v Power antenna
(+)Blue/white.......12v Remote turn on
Orange...........Dashlight/dimmer
Orange/white.....Dashlight/dimmer
Orange/black.....Dashlight/dimmer
(+)White............Front left positive
(-)White/black......Front left negative
(+)Grey.............Front right positive
(-)Grey/black.......Front right negative
(+)Green............Rear left positive
(-)Green/black......Rear left negative
(+)Purple...........Rear right positive
(-)Purple/black.....Rear right negative
Hope this is what you were looking for.
Nov 07, 2010 | Car Audio & Video
Screen Color Looks Like a Rainbow
Good day.
The problem includes malfunctioning of you units deflection yoke, color circuit and failures in the chroma system.
Have it check by a repairman.
chris
Aug 04, 2006 | Toshiba 36A40 36" TV
Westinghouse LTV-32w1 32 in. HD-Ready LCD Television Logo
93 people viewed this question
Top Westinghouse Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
