Question about Sentry Fireproof Safe
Can u assist me with opening my safe
I have my combination and my key, but its been so long ive forgotten the direction of the nob to turn
    Scholar:
  • Sentry Expert
  • 170 Answers
Our tech team at Quality gun safes wall safes and floor safes store in Burlingame Ca produced this video
Posted on Nov 06, 2014
    Novelist:
  • 76 Answers
3 Digit Combination Lock
31-10-31
  1. NOTE: If your safe DOES NOT have a key, skip Step 3.
  2. Turn the dial to zero.
  3. Insert your key and turn it until the plunger pops out.
  4. Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
  5. Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
  6. Turn the dial to the left to the last number (stop the first time on your last number).
  7. Pull the handle down; the door should open.
3 Digit Combination Locks for Security Safes
31-10-31
  1. Turn the dial to zero.
  2. Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
  3. Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
  4. Turn the dial to the left to the last number (stop the first time on your last number).
  5. Insert the key; turn right.
  6. Pull on the key while it's in the lock to open the door.
3 Digit Combination Locks for Gun Safes
31-10-31
  5. Pull the handle down; the door should open.
Electronic Locks
31-10-31
  1. Insert the tubular key into the lock to the left of the key pad.
  2. Turn the key all the way to the right until the plunger pops out.
  3. Press the five-digit factory code. The green Proceed light will come on.
  4. Pull the handle down; the door should open.
4 Digit Combination Lock
31-10-31-10
  2. Turn the dial to the left (counterclockwise) four times to the first number of the combination (pass the first number of your combination three times, stopping on it the fourth time).
  3. Turn the dial to the right (clockwise) three times to the second number of the combination (pass your second number twice, stopping on it the third time).
  4. Turn the dial to the left (counterclockwise) two times to the third number of the combination (pass the third number of your combination one time, stopping on it the second time).
  5. Turn the dial to the right to the last number (stop the first time on your last number).
  6. Pull the handle down; the door should open.
Tags: I can not get into my Sentry Safe and I know the combination. Which way do you turn the dial to open the safe?
KB Results KB Results Keys Sentry Safe Replacement Keys
Posted on Nov 04, 2014
    Genius:
  • 1,406 Answers
Right, then left, then right.
6ya staff
SOURCE:
Anonymous
  • 78 Answers
SOURCE: sentry safe V530
Follow this link to the usermanual. On page 3 there is a guide to re-setting the code. http://www.sentrysafe.com/pdfs/OwnersManuals/172967.pdf
Posted on Aug 28, 2007
Anonymous
may have been 8 bucks , but it's 12 bucks now.
check out www.sentrysafe.com ,
look on right side menu for "keys" and/or "combination" .
Posted on Jul 09, 2008
Anonymous
SOURCE: sentry safe
u can request a lost combo from the sentrysafe.com u gotta get a it noteiatized and send it in to them the details are listed on the webpage i hope this helps u
Posted on Feb 20, 2009
tmburke
  • 76 Answers
SOURCE: How to open Sentry V330 with combination and key?
31-10-31
If this still does not open the safe, refer to the following page for additional different types of Sentry Safe models:
http://www.sentrysafeshop.com/kb_results.asp?ID=15
Posted on Jul 06, 2010
SOURCE: unable to open electronic safe
Locksmiths say this is how to install sentry safe batteries
slide open the battery cover located just below the keypad.
Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated.
reconnect the connector and put back the battery holder. Slide the cover back in place.
How do I insert the batteries on my advanced electronic lock safe? On the newer model Fireproof Sentry Safes my locksmith recommended me To install batteries,
turn the electronic lock case to the right and remove. Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
Posted on Aug 08, 2010
Says code error
How To: Open A Locked Sentry Safe If You Forgot ...
? 5:21
https://www.youtube.com/watch?v=Mr8QrvVAtuI
Jul 15, 2014 - Uploaded by TipsNNTricks
I show you How To Open A Locked Sentry Safe If You ForgotThe Combination Or Loss Your Digital Code Or Lossed Your Key. The Sentry Safe ...
' Sentry® Safe ' Lost Your Combination
https://www.sentrysafe.com/.../Lost_Your_Combination
Sentry GroupCombo Recovery. What you'll need: Model Number; Safe Serial Number; Notarized Statement of Ownership. Step 1. Safe Info. Step 2. Notary Form. Step 3
opening a electronic safe forgotten the lock code ready to ...
www.instructables.com/.../OPENING-A-ELECTRONIC-SAF...
InstructablesJul 6, 2009 - I HAVE A SAFE GAURD COMPANIES SAFE I HAVE FORGOTTEN THE LOCK CODE TO OPEN IT. THEIR IS NO ALTERNATIVE OF KEY ...
How to Crack a Safe (with Pictures) - wikiHow
Jan 10, 2016 | Home Security
Sentry S 3110. Combination lock with 3 numbers. How do I open it?
First insert the key into the lock, if there is a keyhole, and turn it until the plunger pops out. (You must have the key to unlock the safe for the keyed version of the safe.) Remove the key.
Set the dial to zero. Turn the dial to the right (clock-wise) three times (pass zero three times) then stop at the first digit in the combination. Turn the dial to the left twice and stop at the second digit given in the combination. Turn the dial to the right again and stop as soon as you reach the third digit. The safe should open.
Sentry has the manual available for the S3110 safe on the product page: http://www.sentrysafe.com/Products/36/S3110_FIRE-SAFE_Home_Safe . The direct link to the manual is http://www.sentrysafe.com/pdfs/OwnersManuals/514472.pdf . The directions for opening the safe are on page 2.
If you do not have the key and your safe has a keyhole, you probably need to contact Sentry or a locksmith.
I hope this helps.
Aug 30, 2015 | Home Security
I also have a hyundai electronic safe and I've forgotten my password. I know I need to push the center S button first but that;s all I remember. I have the serical number if that'll help.
The serial number is of no use. If you could obtain the combination simply by asking on a public website then your safe would be, by definition, an unsafe... Many electronic safes come with an emergency bypass key, so check that you haven't got one ferreted away somewhere.
If you have forgotten the combination and have no bypass key then the only option is to cut or drill the safe open. You can call out a locksmith if you like, but will find that the only difference is that he/she may have better tools and safety equipment than you and will have a better idea where to cut. Some cheap, pressed steel, safes with plastic front combination panels can be opened even more easily by just hammering off the plastic bits until access can be gained to the sliding door bolt mechanism.
Sorry that this is not the answer you were hoping for, but safes are not meant to be easy to open other than by using the correct key or combination.
Sep 24, 2010 | Vacuums
31-10-31
Aug 25, 2009 | Sentry Fireproof Safe
Nutool sf20 safe
I need an instruction Manual for a Nutool sf20 safe
Jul 15, 2009 | Computers & Internet
Century safe lock , not able to open the combination lock oper b
just boughy it and instructions got thrown away by accident . I have keys but no combination please advise..... Numbers on door that are tagged on is: BJ-285913* an another sticker that says 50310 BJ285913 please advise...
Apr 28, 2009 | Safe International Digital Electronic Safe...
Need assistance opening my Sentry 1250 safe. I have combination but do I start at 0 and pass the first number then stop 2nd time around at first number then go straight to the other 2 numbers?
Locksmith instructions for sentry safes
on how to dial open sentry fire safes.
NOTE: If your safe doesn't have a key, skip Step 3.
Insert your sentry safe key and turn it until the plunger pops out.
Pull the handle down; cracking sentry safe open.
May 06, 2008 | Sentry Fireproof Safe
Sentry Fireproof Safe Logo
418 people viewed this question
Top Sentry Home Security Experts
Hannah Johnson
Level 1 Expert
Colin Stickland
Colin Stickland
 Brian Main
Brian Main
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
