Question about Logitech Ultrathin Keyboard Cover
Cannot establish blue tooth connection to ipad
Charging ,switch on logitech,ipad setting bluetooth on ,press blue tooth on logitech blue light blinks for 1-2 min,then goes off,ipad messege unable to estabish connection
  • Logitech Master
  • 2,075 Answers
Try to turn on BT on iPad while Logitech is blinking (which means it in pairing mode and can be discovered). If that doesn't help I'd suggest to remove batteries from Logitech for 3-5 minutes then put them back.
Posted on Feb 09, 2015
SOURCE:
Slim folio will not be found with new Ipad 6th generation, we followed the instruction and nothing happens
You have missed a step. Read again carefully
Connect the Slim Folio keyboard case to iPad
Before you connect your iPad 5th Gen to the Slim Folio keyboard case, make sure it's inserted correctly into the case:
Place your iPad so the camera lines up with the camera lens cutout on the Slim Folio case.
Snap the corners of the iPad into the holder to secure it.
To connect for the first time
The Slim Folio case doesn't have an On/Off switch. To turn on your keyboard case, open it and rest the iPad on the strip directly above the keyboard. The status indicator on the top right of the keyboard will glow green.
On first connection, your keyboard enters Bluetooth discovery mode and the status indicator will blink blue rapidly.
Go to the Bluetooth settings on your iPad and select Slim Folio in the Devices list.
If your iPad requests a PIN, enter it using the keyboard (not on your iPad).
Once the connection is made, the status indicator will turn solid blue. Your keyboard is ready to use.
To connect to a different iPad
If you've already connected the Slim Folio case to an iPad and want to connect it to another one:
Rest the iPad on the strip directly above the keyboard. This activates the keyboard. You should see the status indicator glow green, and then blue.
Press the Bluetooth connection button on the right side of the keyboard to make your keyboard discoverable.
Close
Apr 17, 2018 | Tablets & eReaders
I have an Apple IPad Pro. I bought a Bluetooth Keyboard Case from Amazon. I need to know how to get started. There doesn't seem to be an instruction manual. I'm in unknown territory.
It's fairly easy to set up usually. With the keyboard powered on there is usually a button that turns bluetooth on and a (usually) blue light will start flashing. At this point on the iPad you look in the bluetooth settings page and look for the keyboard to appear in the available devices. Tap the link to it and follow the instruction. The blue light should stop flashing and remain lit and the iPad BT settings will show that the keyboard is connected.
Oct 23, 2016 | Apple Tablets & eReaders
How to pair lg Bluetooth headset with ipadair?
on your iPad go to setting-> then down to bluetooth. on your headed set Press and hold the multi-function button for 10 seconds until the indicator light turns blue. It is now in pairing mode. it should show up on your iPad, click on your headset and it should pair.
Nov 26, 2015 | Apple iPad Air
How can I setup blue tooth on the tablet to talk to my cell
Go in to setting look for blue tooth press it, go to your phone settings and look for the same thing on both units press Pair with device. At this time the blue tooth should turn on, blue tooth then should allow both units to hook up with each other FYI pass word should be 0000. if you need it
Mar 14, 2015 | PANDIGITAL SuperNova
Using the keyboard for iPad not typing on the screen
check the manual...!
depends on the model - but it works with bluetooth- see a sample :
put the iPad in the slot built into the keyboard, and pair it with your iPad via Bluetooth
On your iPad, tap the Settings icon and then tap Bluetooth. Make sure Bluetooth is On.
Connect the Logitech Ultrathin Keyboard Cover i5 Logitech Support Article using-keyboard-ipad-not-typing-screen-jq4dbyibaqf10wv4m2e43laj-1-0.jpg using-keyboard-ipad-not-typing-screen-jq4dbyibaqf10wv4m2e43laj-1-2.jpg
Sep 15, 2014 | Apple iPad Tablets & eReaders
My shark keyboard for iPad air does not pair for blue tooth operation
Perhaps you look on this link to see you did everything right, like charging the battery, switching on and pairing. Don't forget to switch on bluetooth on your iPad. SHARKK Apple iPad Air Wireless Bluetooth Keyboard Case
Sep 10, 2014 | Apple iPad Tablets & eReaders
Cannot get ZAGG keyboard pair to iPad
Check that the keyboard's battery is working and it's on. Turn on Bluetooth on the iPad (Settings > Bluetooth). Press the keyboard Connect button. Choose the ZAGG Keyboard on the iPad, and type the code on the keyboard.
This doc describes the process: http://cfprod.zagg.com/downloads/ZAGGfolio%20instructions/ZAGGfolio%20instructions.pdf
Good luck! :)
Mar 25, 2014 | Apple iPad Tablets & eReaders
How do i connect my ipad to the hello kitty keyboard
After turning on your keyboard, the blue indicator light will come on for a couple of seconds, then go away. Next, press the button that says "connect" at the very top right corner of the keyboard. It looks like a wifi signal with a circle around it (I had trouble with this part, I didn't realize it was a button). Blue indicator light will start blinking, meaning that it's ready to connect. Go to Settings > Bluetooth (make sure it's on) > click on device. Voila!
Nov 29, 2012 | Hello Kitty Portfolio Case and Bluetooth...
Logitech Ultrathin Keyboard Cover Logo
255 people viewed this question
Top Logitech Tablets & eReaders Experts
Marvin
Marvin
Are you a Logitech Tablet and eReader Expert? Answer questions, earn points and help others
