Question about Westinghouse LTV-32w1 32 in. HD-Ready LCD Television
I have a ModelVK-42F240S that has no audio. Anything to try to cure the problem? Westinghouse TV
  • Westinghouse Master
  • 727 Answers
Hi, bad speakers in many flat panel TVs is a common problem. There will be av out sockets at the back of your tv. Please connect the audio from here to any amplifier or any music system you have. If you get the tv programme sound, most probably the speakers are bad. In case you do not get sound, your tv is not producing it. If the speakers are bad and you can change yourself, give it a try. Otherwise show the set to someone qualified to repair it.
Posted on Feb 24, 2015
6ya staff
SOURCE:
How do I connect my Sylvania DVD VCR Player to my Westinghouse LCD TV?
Your Sylvania player probably has three outputs: right audio (red), left audio (white), and video (yellow). Use a corresponding three conductor cable to connect to corresponding inputs on the rear of your Westinghouse TV (if it has them).
Sep 19, 2015 | Sylvania Televison & Video
My audio is out on my Westinghouse Tv VK-42F240S. How do I fix it?
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Spare parts are available at most of the electronic spare part selling shops.
Nov 10, 2014 | Westinghouse Televison & Video
TV has video but no sound
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Sep 11, 2014 | Westinghouse 55.70E01.021G Main Board for...
I just bought an westinghouse 42'' led tv and im trying to hook my surround sound and my xbo 360 to it and i keep getting an no signal message everytime and it worked on my 42'' sanyo lcd...
Sounds to me like you are trying to use a composite hookup or a generic HDMI cable. If you get the official Microsoft HDMI connector it also includes phono audio outputs and an optical audio out for 5.1 surround,
Aug 27, 2011 | Westinghouse Televison & Video
I have a westinghouse 42" VK-42F240S tv. No input signal. I have reset factory setting, changed cables, and boxes. Any suggestions?
Normally it depends on what connection you are using to output a signal, all of the inputs on this unit are in one single board. What you need to do is to replace the main board because it sounds like your inputs migh have gone out. To check price and availability on the main board you can contact Westinghouse parts department at parts@wde.com, please make sure to include the model # along with serial # and TW# all loacted on the back of the unit. Hope this information was helpfull.
Jan 21, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
I have a Westinghouse 42" 1080p LCD TV. It doesn't pass stereo audio. I have an HDMI DVD player, HDMI laptop connection, composite video + stereo audio VCR, & OTA TV. None of them offer anything but...
Hello, this is an interesting one since on this unit what ever the device you are using will determin the type of audio you output on the speakers. I would love to troubleshoot a bit more with you live, can you please send me an email of how to get in contact with you to westytech@wde.com.
Nov 21, 2009 | Westinghouse TX-42F430S Television
TV won't recognize signal from a DVI to HDMI input adapter
I had a similar problem with a Mac Mini.  The problem was caused by a mix-matched resolution (the Mac tries to use 75Hz refresh rate, TV expects 60Hz).  The best solution I found was to remote into the Mac (I used LogMeIn.com) and change the resolution on the Mac from a remote computer until the image appears on screen.
Process: 1) Connect Mac to a normal monitor and install the LogMeIn server (or other VNC type application) 2) Connect the Mac to the TV 3) Connect to LogMeIn from another computer (preferrably one where you can see the TV) 4) Go to Applications / System Preferences / Display 5) Change the resolution to your TVs native resolution, and change the refresh rate to 60Hz
Apr 08, 2009 | Westinghouse Televison & Video
Westinghouse
This is an inherant problem with TV and according to dealer there is no cure. My dealer made a deal on another TV for me. Tough luck
Sep 03, 2008 | Westinghouse LTV-30W2 Television
Remote control code for westinghouse sk-19h210s television
I just tried a Sony code for my Westinghouse tv after reading other sites, and it worked. The code that worked for me was 10000
Oct 21, 2007 | Televison & Video
Westinghouse LTV-32w1 32 in. HD-Ready LCD Television Logo
90 people viewed this question
Top Westinghouse Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
