Question about Apple iPhone Smartphone
IPhone won't shut off.
Okay, here's my problem. Earlier today, I was trying to check a missed call on my iPhone, and I tried to click the phone button, and the iPhone wouldn't let me click on anything, so I try to shut it off, and it acts like it's about to shut off (With that circle thing that lights up, like it's loading...the sign that tells you the iPhone is about to shut off.) and the iPhone has been like that for about an hour now, and won't shut off.
Can someone help me?
Thanks.
  • 26 more comments
  • Anonymous Jan 06, 2008
    Won't shut off! Have the Apple icon on it....I push the sleep mod with the home button and still no can do?
    Thanks for help
    coolkat1@cox.net
  • Arsenal101 Jan 18, 2008
    Hi I have had my iphone for about a week now, When I try an shut it off it goes through the whole process fine then screen goes black, but automatically turns itself back on, everything still works on phone but still weird, It just won't shut off. I have tried holding the home home an power button for like 15 secs until it resets but still same problem.
  • Anonymous Feb 06, 2008
    it wont let me touch anything on the screen and it wont shut off.
  • ggman Apr 05, 2008
    my iphone goes on and off untill i plug it to my computer it comes back on..if i plug it to my car charger it wont come back on
  • RPinLA Jul 04, 2008
    Mine just did the same thing - lit up but wouldn't let me slide to unlock it and wouldn't respond to my attempts to shut it down. I held the sleep button on the upper right and the home button simultaneously until it finally shut down...
  • Anonymous Jul 14, 2008
    yes same thing i would push the home button but it wont bring up the main incon desktop, so I went to shut it down by pressing the upper right and home button and now i just have a white screen and cant turn it off completely or get it back to the main icon page ....just a white screen HELP!!
  • mary_decicco Aug 16, 2008
    I used the power button on the top to turn off the iphone. I moved the slider and got to the small circle of lines showing that it was powering off. It has been powering off for over an hour now. I have tried it docking it into the charger, and plugging it into my lap top. Neither one has had any impact. I have had my iphone for almost a year and this has never happened.
  • laurenk23 Aug 18, 2008
    I don't have a solution unfortunately. In addition to the iphone not shutting off, when it is not being used, the phone will light up after a minute, utilizing unnecessary battery. I am not sure what to do about it. I am using firmware 2.1.
    Lauren
  • Anonymous Aug 19, 2008
    it wont shut down i turned the power off but just got the circal off lines 4 2hours now
  • ajhswim2010 Sep 05, 2008
    I am having a problem with my iphone. I just got the new upgrade 2.0.2. for my phone 5 days ago (I have the original Iphone). I downloaded some new apps from the apps store within those 5 days and did not have any problems. Today I was listening to my ipod part of my phone without any headphones and also texting. After about one hour of listening to music and texting I tried to look at my home page so i clicked on my home button and all that showed up was my contact favorites. So i tried to turn my phone off because I couldnt go to my home page but all it does is lock the phone the off slide doesnt even show up. so i tried to put it in my charger and it wont even charge its like my phone is frozen. but the only things i can use on my phone are my contacts, texting, and my ipod on my phone. all of the other parts i cant see.
  • tehtrix7 Sep 13, 2008
    so i was playing labyrinth and after maybe 10 minutes, if not more, i clicked the home screen button which after a slight lag took me to my phone favorites. I tried to go to the home screen once again but my attempts failed. my iphone would only work on as a phone. i tried shutting it down, but when i pressed the button on the top right of the iphone it only went to sleep mode and wouldn't turn my phone off no matter how long i held down the button. i then pressed the home button and the off button together and this turned my screen all white and then nothing worked at all, all i could do was put it to sleep, and if i turned it back on it was just white. what i did was plug it in and once itunes recognized it, i restored it and updated it as well as backed it up. now it's fine:) hope my advice helped:D
  • Anonymous Sep 13, 2008
    i have exactly the same problem. I sent a txt i think, then the next time i went to the iphone it was on "favorites" and takes me there even if I click the home button once. I can't get to any screens at all except favorites, recents, contacts, keypad, and voicemail! When I press the top button to turn it off it just goes to sleep then i get the "slide to unlock" when turning back on. Charger won't work, and itunes is about to update to 2.1 so hopefully that ill solve it, I'm very wary of holding both buttons together because my last iphone had a problem and that was the cause of it, it was in a continual loop of never turning on just loading loading!
  • ljw1949 Nov 08, 2008
    The only thing that will show up when I "slide to unlock" is the phone part.  When I press the usual button to go from mode to mode, nothing happens.  I thought maybe turning the phone all the way off and then on again might work, but it won't turn off.  Will go to black screen, but no matter how long I hold it, won't turn off completely.  At one point, the play/pause part of the iPod screen showed up at the top of the wallpaper screen.  How can I fix?
  • horvatherwin Nov 16, 2008
    my iphone just stays on the regular "slide to unlock screen" but it doesnt let me slide to unlock it................it doesnt let me turn it off or anything it just stays on the slide to unlock screen.....then I thought maybe I won't charge it and it might die so I havent charged it in about 4 days and the battery sign didn't even go down a little bit, it still has full battery so can anybody help?? please
  • greengurl1 Nov 18, 2008
    when i held the button on the top for more thatn ten seconds the slide to power off thing came up but it wont let me slide it and it wont let me cancle its frozen on the screen. it wont go away.. what do i do
  • kingzeke_1 Dec 22, 2008
    will not go to the home screen
  • ac1227 Jan 05, 2009
    my iPhone does not shut off completely i try to turn it off but it stays where my icons are ... what do i do im scare my battery wont last...
  • Anonymous Feb 03, 2009
    iPhone won't turn off and on/off switch and home button perform functions they are not supposed to. Still unresolved. Even soft keys do things they are not supposed to
  • beelovelyn23 Feb 11, 2009
    I can't turn off my Iphone.. even if i turn the tab to luck it, it wont... please help me how to fix it.... thank you
  • Anonymous Feb 18, 2009
    My problem is the same! I can't go back home, or turn it off! I can call and text... but nothing else... i think i may die...haha jk...but for real HELPP!!!
  • haleysaylo Mar 02, 2009
    I had the same problem...
    First my IPhone would not exit away from the "Favorites" list,
    Then it would not even allow me to use the home button to exit that application
    Things continued to quit working...
    It wouldn't turn off or even allow me to insert my password to gain access to the main screen after hitting the Sleep button.
    BUT... after many tried things, resetting the phone worked! Just hold down the "Sleep" button on the top, while at the same time holding the "Home" button for at least ten seconds. The apple logo should come up and everything went back to normal for me after that.
  • barbieandlh Mar 05, 2009
    i have a jailbroken/unlocked (2g) iphone. When I tried to power off it never went to the slder screen asking me to power off. Now everytime I try to power on, about 20 seconds after the apple appears the circle thing starts spinning and then freezes. HELP!!!!!!!!!!!!!
  • kellykeys Mar 25, 2009
    iphone won't shut off - just keeps rebooting.
  • natickmills Mar 30, 2009
    iphone won't let me shut it off. It won't let me out of phone screens
  • Anonymous Apr 22, 2009
    fiufff! omg, i thought i was gonna die too. i was stuck in the phone contacts page, but could still make calls and access the ipod playing. Reseting it by pushing the top button and the circle button for like 10 seconds did restart it though and it seems back to normal now=]]]
  • jrmullat Apr 25, 2009
    I have the same problem... early this morning (too) I checked my iPhone to see if I had a missed call. But some strange message apeared in the screen saying something about Mocha (the VNP program) and if I want to allow some number to connect... WTF was that!? Then I dsicovered I could'nt go to tha main screen. When I touch the home button once nothing happens, but twice it takes me to the favorites.
    The first thing I tried is to shoot down my iPhone and reboot. But the shoot down button only worked for going to the lock screen.
    I'm so scrared! I thing someone entered in my iPhone!
    My iPhone is 2G and jailbreacked.
    I have the openSSH installed and the Mocha VNC lite installed. I think that someone entered that way...
    Can anybody help me!?
  • Anonymous Apr 29, 2009
    I am in the process of trying to restore my phone. It's hooked up right now. At first, it was stuck on the phone screen, where I could just make phone calls and such. I kept trying to turn my phone off, but no matter how many times I pushed it, it wouldn't turn off. Then on top of that, the home button wasn't working at all and it wouldn't recognize that I had plugged it in to charge. So I hope that this works out after restoring it and all.
  • aaron Apr 17, 2013
    well ive tried the reset thing to make the slide to unlock thing work but it still dosnt
    President:
From the apple.com website - the 2nd one worked for me:
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears.
Posted on Nov 18, 2008
  • 6 more comments
  • David Y Oct 19, 2010
    I have never beeen able to turn off my iphone....EVER. It's been on for 1-1/2 years. Can not manually shut it off. The only way it powers down is when the battery dies. That's it. Tried everything...i think. Hence, in order to jailbreak it, you must be powered off and rebooted from the off position. This sucks because I can't do that and I want to jailbreak it!!
  • tiarana_sene Dec 03, 2010
    I have the same issue, did you ever find a way of fixing this problem? Please let me know.
    tiarana_senele@yahoo.com
  • jtcntpl Dec 31, 2010
    did u ever fix this problem, as I have exactly the same problem, my i phone hasnt been off for almost 2 years?? Any help would be greatly appreciated
    jt.construction@bigpond.com
  • Andre Ploeg Jul 29, 2011
    This worked for me, it hung on the allpe logo for about 15 mins but then it started up. I then turned my phone off and on again, it took sometime but it worked. This happened after I installed lockdown Pro, the cracked version, but it seems to be working fine now!
  • Silver Fox Dec 11, 2011
    THANK YOU! IT WORKS! The last suggestion! I have the same exact problem, it froze when I was on YouTube and I tried to turn it off but a black screen lit up and there was a white "loading" circle. This happened like nine months before to me and that time I had to wait until the batteries die. It was so annoying because I had to wait like a whole day until it shut off. To kobikobi and everyone else who has the same problem he/she has, if it's like that everyday, call Apple Support and get a replacement. Unless I'm wrong, and it's not the same as Amazon due to experience with my Kindle breaking two times -.- I talk a lot and waste time so just one more thing before I go to bed, THANK YOU!
    Oh wow thx! I have the same exact problem! I was on youtube and everything froze, then a black screen showed up with that white circle too. This happened to my Iphone before and it was really annoying because I had to wait for it to run out of batteries (the buttons don't respond) . It worked perfectly fine after that and for like 9 months until it did it again. Which is today. But then I found this, and I tried the last suggestion and it worked! THANK YOU!!! I wouldn't waste a bunch of time now waiting for it! And for the people who tried all of these and this happens repeatedly similar to kobikobi, I think you should call the apple company and demand a new iPhone/iPod. They'll probably give you a free one for the broken one. Unless I'm proven wrong because I'm assuming this happens at Apple too due to my experience with my Kindle breaking two times -.- Anyways I talk a lot, and that all I have to say except for one last THANK YOU!
    XD sorry I made an account before my last one, so that's why there's two. I didn't see that one until now.
  • amazing_tran
    amazing_tran May 18, 2012
    Here's a solution worked for me!!! Press Home button for 2 seconds first and then while holding it press power button along with it too. After 3 seconds it will turn off... :
I had a similar problem. The iPhone went to a black screen and buttons wouldn't work at all, not even the shut down button. I pressed the shut down button together with the main function button (the one in the front) and it turned off. Afterwards, it turned on properly.
Posted on Oct 16, 2008
I had a similar problem, that is, the iPhone came up with that little circle thingy, and I figured out how to turn it off while this was happening (it was pretty scary since it was just out of the box!).
If it happens again, Hold down the home button and the sleep button at the same time and it should turn off.
Have a good one!
Posted on Dec 10, 2007
  • Little dobey Feb 23, 2012
    My iPhone won't lock or turn off and it's really annoying the **** out of me how the heck am I supposed to fix it? Apples website sucks it's no help
  • Arienmughare May 29, 2012
    Thanks man it really worked
    New Friend:
Reset the phone by holding down the top button and the circle button for 10 seconds. It should start up normally from there.
Posted on Dec 09, 2010
I had a similar problem with my iPhone seizing up- wouldn't go back to main screen or recognize that it was plugged in to charge- and when I tried to reset it by pushing both buttons simultaneously it just took a photo of the screen.  Just before I called Apple Care I took out my SIM card out of phone and then put it back in.  The screen unlocked temporarily and the next time I tried to reset- as prompted by Apple Care- it reset.  It did take longer than the estimated 30 seconds to get back to the standby screen- more like 1.5 minutes.  Now all seems to be fine.
Posted on Jan 13, 2009
    New Friend:
My IPHONE WILL NOT GO OFF! !st Gen 2G. The only way I can get it off is to run the battery out. I have tried everythin. Anybody?
Posted on Aug 14, 2010
My Iphone 3g locked up today in the "phone" menu, and no matter what I did, I couldn't turn it off or reset it. The solution: I connected it to my computer, took a backup via iTunes (ticked all the right boxes in iTunes under the iPhone icon, also took extra backup of contacts into outlook), and clicked "restore" on the summary tab. The phone then reset itself to factory settings, started up normally, and then continued to restore almost everything I had on the phone, including address book, full txt msg history, photos, bluetooth pairings etc. It even manage to restore data in some of the downloaded apps from iTunes store (such as all voice recordings in AudioMemo). The only thing I have found so far that it didn't restore, understandably, was my music, which was no problems since I only downloaded it again from my iTunes. I am really amazed at how well it worked.
Posted on May 12, 2009
    New Friend:
I just bought a new computer and when i hoolk my iphone up i get a message that says....one of the USB devics attached to this computer has malfunctioned, and Windows does not recognize it. I have tried to turn my phone off and it wont turn off. I have tried pushing the sleep button. I have tried pushing both the sleep buttut it on and the home screen button and holding them in for a while, but it still wont shut off. what should I do?
Posted on Mar 19, 2010
@ ljw1949
u may have already fixed this by now, but mine was doing the exact same thing, until i plugged it into itunes and upgraded the software, it took about 20mins to do but eventually it worked and all has been fine since. Since then I have gone into setttings and there was an option saying when home button is pushed twice take me to the favourites list or something, so i have disabled that.
Posted on Dec 11, 2008
    Scholar:
  • 50 Answers
It's usually an issue with the logic board, so ultimately if you want to resolve it, the logic board needs to be replaced. Try to restore the iphone to exclude that it's a software issue, but if that doesn't work and If you're under warranty apple will likely give you a new one. If you're out of warranty you can attempt a self-repair if you're comfortable with opening devices like that, There are iPhone Repair guides that show you how at http://www.portatronics.com/guide. It's kind of a minor issue to take the risk of breaking things further though.
Posted on Jun 02, 2009
    Habit-Forming:
    Scholar:
  • Apple Expert
  • 51 Answers
Just force restart your iphone. try to power of iphone and power on. this is normal thing occure when some app not working properly. If you want to restore your iphone without deleting data then here is the way.
Ipad iphone restore without losing data . But in your case i dont think you need to restore your iphone it just force restartyour iphone and it start working normally.
Posted on Jul 25, 2018
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Apple Master
  • 545 Answers
Switch is full off dirt
Posted on Mar 11, 2015
THANKS!
Posted on Oct 15, 2008
My iphone is currently at lock with password but when i try to unlock it it unlocks but i try entering the password it goes weird. It shows that it is touched it sounds too but it doesn't open and doesn't put either that the password is incorrect and it won't turn off it just goes sleep CAN SOMEONE HELP ME?
Posted on Sep 01, 2008
    New Friend:
  • By iPhone won't shut off. - avatar9.jpgkobikobi Oct 19, 2010
  • I have never beeen able to turn off my iphone....EVER. It's been on for 1-1/2 years. Can not manually shut it off. The only way it powers down is when the battery dies. That's it. Tried everything...i think. Hence, in order to jailbreak it, you must be powered off and rebooted from the off position. This sucks because I can't do that and I want to jailbreak it!!
    Here's a solution worked for me!!! Press Home button for 2 seconds first and then while holding it press power button along with it too. After 3 seconds it will turn off... :)
Posted on May 18, 2012
You are the best!!
Thank you!
Posted on Mar 11, 2008
    New Friend:
My Iphone's screen went slowly white I had to hard reboot.
itunes and computer see's the phone but I have no display. Help...
Posted on Nov 15, 2009
    New Friend:
    Problem Solver:
  • 6 Answers
5 Suggested Answers
SOURCE:
SOURCE: iphone froze
hold down the power button and home button for roughly 10 seconds sometimes it can take anything up to a 1minute. This almost always works. My froze and i tried this, worked first time.
When your screen goes off from holding them down. Plug you iphone into itunes and it will load and your all set.
Posted on Jan 07, 2009
  • 5 Answers
SOURCE: I can't hear anything when I get or make calls on my iPhone
Please take a look at Apple's Support Page, try all of these, if required.
http://support.apple.com/kb/TS1630
Posted on Aug 17, 2009
  • 100 Answers
SOURCE: MY iphone won't shut off
Probably the flex cable that connects the button to the mother board is damaged. This part is cheap and easy to install.
You can find the replacement parts here:
http://www.piezas.biz/epages/wwwpiezasbiz.sf/en_GB/?ObjectPath=/Shops/demo132390/Products/%22Piezas%20Iphone%203G%22
Posted on Aug 19, 2009
SOURCE: okay today i dropped iphone on the ground and
Most likely you destroyed your #1 connector that goes from the LCD to the logicboard. A $25 investment for a new LCD will solve the problem!
Posted on Mar 24, 2010
Iphone won't start up
Un plug the battery check the connections on the battery and the iphone clean with some stochbrite and wipe off with 90% alcohol let dry and should work fine as long as the battery is fully charged.
Dec 26, 2012 | Apple iPhone 3G
Iphone shuts off and won't turn back on what do i do?
You might try holding down the power and home buttons at the same time. Wait until you see the silver apple. Thats what I did when mine wouldn't turn back on.there is an easier way instead of just guessing....
when you plug it into any form of charging source...just completely shut down your iphone...and leave it there for how ever long it takes to charge...(to be able to use it again is about 30 minutes)depends on your energy sourceFirst open iTunes and Conect your iPhone cord to your computer, but do not plug it into your iPhone. Then press and hold the home button on your phone while conecting the iPhone cord into your iPhone continue to hold down the home button. Then click restore in iTunes
Feb 15, 2012 | Apple iPhone 4 Black Smartphone
I have an iPhone 4 and an ihome that waS working perfectly fine earlier today and now when I plug my phone into the home it says not compatible with this device. I have cut my phone off then on again and I...
the battery cannot be easily removed form you iPhone, if at all.
how did you turn off your iPhone ? Was it using a long press on the Sleep button, which makes a slider appear saying " Slide to Power Off" ?
if that didn't work, try this :
-press and hold the Home button, while at the same time pressing and holding the Sleep button
-keep holding those 2 buttons until the Apple logo appears. This could take as long as 10 seconds or more.
this action resets the memory circuits, and may resolve the problem.
Jan 30, 2018 | Apple iPhone Smartphone
Iphone screen locked
try switching the phone off and on again
Jun 05, 2010 | Cell Phones
My i phone wont turn on or charge
try cleaning your charging port.
Mar 22, 2010 | Apple iPhone Smartphone
Okay today i dropped iphone on the ground and
You have been dropping your phone so hard that the body cracked. With your second dropping, the circuits may have got disconnected. Take it to your service centre to get it going.
Aug 01, 2009 | Apple iPhone 3G
Maytag Washer Stopped Working
I was about to order a new lid switch assembly, but I decided to try one more thing. I disconnected the wires from the check switch and cleaned the connections - there was a layer of oxidation. The machine started right up after I reconnected the wires and plugged it back in.
Dec 17, 2008 | Washing Machines
Apple iPhone Smartphone Logo
167,772 people viewed this question
Top Apple Cell Phones Experts
Ekse
jacobcheatha
Level 1 Expert
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
