Question about Apple iPad 2 Wifi 16GB
How do I turn of private browsing on my iPad its in black and white mode
I think it's an iPad to no Plc to put a SIM card it's saying go to privacy settings but there's no were to turn it of don't even no how it got turned on
    Sergeant:
    New Friend:
  • 153 Answers
SOURCE:
How do I disable my private browsing
On an iPhone, iPad, or iPod touch, open Safari, then tap . Tap Private to turn private browsing off. While Private Browsing is on, Safari appears black or dark instead of white or gray. If you're using iOS 7 or earlier on an iPad, open Safari, tap to open a new tab, then tap Private
Jan 09, 2016 | Apple iPad Mini
How do I disable my private browsing on my apple ipad mini
Press the far right double page icon, and on the next screen you see
Private + Done
Pressing Private gets you into Private browsing mode.
Go back and press 'Private' a second time and it toggles you out of Private mode.
Turn off private browsing
When you open safari browser look to bottom left corner and click on "Private" that toggles between on and off!
Nov 07, 2014 | Apple iPad 64 GB 3G Tablet PC
When I open my google it shows sites that I have visited how can I remove them?
Try clearing your browsing history. Open up your Settings on your iPad, click Safari, then Clear History. This will wipe out your iPads previous knowledge of any sites you've visited.
To prevent them from listing moving forward, you can use private browsing. If you're using iOS 7, you can access it by opening Safari, hitting the + button near the bottom of the page, and hitting Private in the left hand corner. It'll ask you if you want to keep or close your currently open tabs after that.
Hope this helps!
Aug 25, 2014 | Apple iPad 32 GB WiFi Tablet PC
How do I turn off private browsing
Select the + to add a new tab in the lower right-hand corner you will see the public private toggle 85cf1006-3a73-4c26-a551-3c5265daf283.jpg
Aug 06, 2014 | Apple iPad (16 GB) WiFi Tablet PC
Where to put sim card on the ipad 3
http://www.ifixit.com/Guide/iPad+2+GSM+Headphone+Jack+%26+SIM+Slot+Replacement/6159
Follow Step 1 and 2 only.
Note: If you bought the wifi-only iPad then it won't have a sim card slot, if you bought the wifi + cellular version then it should have a sim card slot on the left-hand side towards the top
Apr 24, 2014 | Apple iPad 2 Wifi 16GB
I need to turn off private browsing to get into my yahoo account. I have followed instructions--settings, safari-- dead end. Been told to press 'pages'bottom right hand corner, but this isn't there. HE
Step 1: Open Safari on your iPhone/iPad
Step 2: Tap on the tab icon (bottom left). This shows you the tabs that are open (in the new rolodex style) 72c761aa-0c49-4247-8164-d7dba95926c6.jpg
Feb 16, 2014 | Apple iPad Mini
How can I tell if I have an iPad 1 or 2
Here's info from: http://support.apple.com/kb/ht5452
The (original) IPad ...
  • The model number on the back cover is:
    • A1337 on the iPad (Wi-Fi + 3G)
    • A1219 on the iPad (Wi-Fi)
  • Black front bezel
  • 30-pin connector
  • Standard SIM tray on the iPad (Wi-Fi + 3G)
  • The IPad 2 ...
    • A1397 on the iPad 2 (CDMA model)
    • A1396 on the iPad 2 (GSM model)
    • A1395 on the iPad 2 (Wi-Fi)
  • White or black front bezel
  • 30-pin connector
  • The micro-SIM tray is on the right side on iPad (GSM model only)
  • FaceTime and rear cameras
  • Nov 23, 2013 | Apple iPad 64 GB WiFi
    Ipad 4th gen with retina display wont open, says disabled for 60 min bc needs access code,, but i never have used any access code
    You will have to try and reformat it if you can (most will not allow you to) I say this because if it has been disabled the reformat option will not be available as the iPad or any iOS device is in "security" Mode. (It thinks that it's been stolen and someone I trying to access the private data) your best bet is to call apple or if you still have the receipt, take it to the place of purchase and have them swap the unit. Hope this helped :)
    Nov 07, 2013 | Tablets & eReaders
    My sim card not installed
    It may be a case of wrong cutting of the micro sim. Since the iPad uses a microsim, you haveto make sure that the sim card is cut perfectly. Do not use a pair of scissors, you have to cut it specifically using a micro sim cutter. Or you can check if the placement of the sim card is correct. Sometimes, the card seems to get loose thus making it unreadable by the iPad.
    Mar 07, 2011 | Apple iPad 64 GB 3G Tablet PC
    Apple iPad 2 Wifi 16GB Logo
    128 people viewed this question
    Top Apple Tablets & eReaders Experts
    john smith
     Mike M
    Mike M
    Ian_C
    Level 1 Expert
    Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
