Question about Vtech DECT 6.0 Cordless Phone with Digital Answering System
My VTech CS6429-2 home phone no longer rings. How do I restore sound?
We have checked the volume and it is all the way up, when we choose a ring tone it plays out loud on the device, etc. However, when we receive a call the base and handset are silent. Has anyone else encountered this problem?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,449 Answers
Check your phone is set set to mute
Posted on Mar 03, 2015
SOURCE:
When people call there is no sound so we END up calling them back after they leave a voice mail. our phone it vtech ds5151-3
Check to make sure your phone is not on mute . Set your ringer to answer after 4 rings . Check the volume and make sure you assign your phone a loud ring tone . Good luck !
Aug 03, 2017 | Vtech Lands Phones
How do I set ring tone on base unit to match handset
You didn't state the brand and model of your phone, but my vTech and Uniden phones only have ONE RING TONE on the base, and it can only be turned ON or OFF (and the volume is variable on the vTech).
May 13, 2015 | Lands Phones
Uniden Model EX 14560 Ringer off How to put ringer on
Here some solutions for your problem + a link to the user manual.
**Selecting the Ring Tone and Volume
Your phone has five different ringer tone/volume combinations you can choose from.
To select the ringer:
1) With the phone in standby, press [vol/ / ] or [vol/ / ].
2) The phone will sound the different ring tones at different volumes. To turn the ringer
off, select RINGER OFF.
3) When the phone sounds the ring tone and volume you wish to use, press [end].
**Temporarily Mute Ringer
If the handset is off the base while an incoming call is ringing, simply press [end] to mute
the incoming ring. The ringer will sound with the next incoming call.
Note: You can only mute the handset ringer if the handset is off the base when the phone starts
ringing.
Adjusting the Earpiece.
**Here is also a link to the phone manual http://www.uniden.com/pdf/EXI4561om.pdf
May 18, 2011 | Uniden Cordless Phone
How do I adjust the volume,too LOUD?
Hello jinniq51,
i have some tips on how to do it hope it helps :D
Settings
In this menu, you can adjust various phone
settings. To reset some menu settings to their
default values, select Restore factory set.
Tone settings
Select Menu > Settings > Tone settings and from the available
options:
Ringing tone-To set the tone for incoming calls
Ringing volume-To set the volume level for the ringing and
message alert tones. If you set Ringing volume to be level 2 or
above, your phone rings with the ringing volume ascending
from level 1 to the level you have set when there is an
incoming call.
Vibrating alert-To set the phone to vibrate when you receive a
call or a text message
Message alert tone-To set the tone to sound when you receive
a text message
Warning tones-To set the phone to sound tones, for example,
when the battery is running out of power
Apr 15, 2011 | Nokia 1600 Cellular Phone
I have problem with my Nokia 2310 mobile phone.. it has very low sound of ring tone.. how can i increase the ringing sound
Dear Sir . Currently your mobile ringing tone is set at low ringing volume level.Thats why you are facing this problem.To increase your ring tone sound follow these step : Select Menu > Settings > Tone settings and from the available options: Select Ringing volume . Set Ringing volume to level 2 or above, your phone rings with the volume ascending from level 1 to the level for incoming calls. I hope this will works for you. Regards. Rizwan.
Mar 14, 2011 | Nokia 2310 Cellular Phone
I am having problems with my phone not ringing It sayes it is muted please help
make sure phone is off (no dial tone or caller) , then hit program it will say directory arrow down with the volume key until it says ringer tone. it give 4 options for ringer tones and off hit select (and choosing a ring tone)
Feb 13, 2011 | Vtech 9009111 Cordless Phone
The handset lights up and the incoming number is shown but you dont hear it ringing
Many times there is a volume switch on the actual handset itself. Most commonly on the left side of vtech devices. there are three different volume levels. By pressing up on the button you should be able to turn the volume up until it has an audible tone confirming volume change. Handset should ring with incoming call when audible tone is heard by pressing up on volume button.
Oct 13, 2010 | Vtech DECT 6.0 Cordless Phone with Digital...
The ringer of my phone is off. How do I turn it on?
flip open your phone -then increase volume with side ^ button...this toggles ringer on/off
no need to go into phone settings...
Aug 05, 2010 | Cell Phones
Telephone ringer volume
make sure phone is off, then hit prog it will say directory arrow down with the volume key until it says ringer tone. it give 4 options for ringer tones then has off hit select and there you go
Jul 03, 2008 | Vtech 5.8GHz Analog Cordless Phone
Ringer off
The VT-9118 can use one of 4 different ring tones, and can be turned off.
To reset your ring tone:
  1. Remove the handset from the base.
  2. Press PROG. You should hear a single short beep.
  3. Press #.  You should hear a single short beep.
  4. Press a number 1 through 4. You should hear a long "ring" tone (it might be startling!). You can try other numbers from 1 to 4 to hear them all.
  5. Press MEM to confirm your ring. You will hear a medium beep.
To turn the ringer off, follow the same instructions, but choose number 5.
Hope this helps you. If you need for information, you can download the user manual from http://www.vtechphones.com/docMgt/public/art/313/vt9118.pdf
Jan 17, 2008 | Vtech VT-9118 Cordless Phone
Vtech DECT 6.0 Cordless Phone with Digital Answering System Logo
182 people viewed this question
Top Vtech Lands Phones Experts
Marvin
Marvin
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
