Question about Panasonic Viera TX-32LX70 32 in. LCD TV
My panasonic viera keeps going to no signal found. No changes have been made and this is twice. i have directtv and verified with them it is not our box
No signal found in game mode connected to satellite box
  • michelle adkins
    michelle adkins Mar 10, 2015
    Thank you for your response. I tried this and did not work. Also had looked up somewhere it could have been dusty, so we cleaned fans etc and still have the problem. It only does it plugged into the cable box. The DVD player and other all work on the correct channels, cable box goes into the video(game) spot. Tried cable box on another tv and its not the box. I am still at a loss here.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,449 Answers
Go to your source button on your tv remote then select HDI 1 or two if it is plugged into that one.
Posted on Mar 09, 2015
  • michelle adkins
    I tried changing the input etc, did not help. Only happens with the cable box. I tried cable box on another tv and no problem so I know it is within my tv. Also tried removing dust on fans etc as someone had suggested and that also was not the issue. It has been working fine for several months, the way the wiring etc is.
    New Friend:
  • 115 Answers
U did not tel about audio it producing or not
Posted on Mar 18, 2015
SOURCE:
How do you change the hdmi on a Panasonic tv?
HDMI is a signal what do you have going on here?
Oct 04, 2016 | Panasonic Viera TX-32LX70 32 in. LCD TV
Panasonic Viera TC-37LZ85 powers on with a solid red light that does not blink, the screen slightly illuminates but no picture. Blown fuse?
T'Con board fault. In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Apr 10, 2015 | Panasonic Viera TC-37LZ85 LCD TV
How do i turn off the closed caption on my toshiba 51h84 tv? i tried setting via the remote and changed the CC option to OFF but i still see the closed caption wording...it is driving me crazy!! help!
What is the source of your TV signal: Cable? Dish Networks? DirectTV? Antenna?
Many times the Cable/Dish Networks/DirectTV controller also has an option for closed captioning. Please verify that a controller is not setup to deliver the CC data.
Also, try setting the TV CC using 'C1' or 'T1' and selecting 'Enter' to accept the change; then come back and set CC to 'Off' again to see if toggling on/off helps.
Dec 31, 2014 | Toshiba 51H84 51" Rear Projection...
Panasonic Viera TX-L32X20B no channel found
the problem looks like bad main board , try to do the auto program , and see if it works , if dont work main signal board need to be replace
Feb 07, 2012 | Panasonic Televison & Video
Panasonic plasma viera tv will not auto tune, can not pick up any signals at all. All cables are plugged in correctly. Model number TH-P46G10A
Reboot all cables,satalites,and telicoms boxes.Like unplug,replug the box an hour later.Let the boxes up grade software,go to ur tv menu setup rescan all channels again well get them back.Ur signal not there after that, than ur Tuner Signal board is dead.Need it replaced.
Mar 13, 2010 | Panasonic Viera TH-46PZ85U Plasma TV
Would not turn on power light flashed twice
Backlight video board,have prob.keep happening must change.
Nov 24, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
Connection problems with Panasonic Viera Cast
I have had the same problem with my Panny DMR-BS850 which was resolved by changing the ethernet cable I was using which had only 4 contacts on each plug end for one which has 8 contacts. I tried all variations & combinations of IP & DNS before buying the new cable from my local pc store (£10 for 10m cable) and was relieved when setting the system to auto connect it worked within 3 mins. I think the slight delay was the router setting up a new address for the new hardware it detected.
My new cable states on it "Verified For Gigabit Ethernet" and is Cat 5e rated and I was assured that it will carry data for runs up to 95m long, which is contrary to the Panasonic support agent who told me to shorten my initial 5m cable to prevent signal degradation.
Give it a try.. it might just work.
Jul 13, 2009 | Panasonic Home Theater System System
Panasonic viera has flashing channel info in upper left corner
I had this exact same issue just yesterday. Channel info would flash intermittently. While set was in this mode, could not enter menu, change channels, etc. from remote or front panel controls. Similar to tjh492, I thought it might be an overheating issue. But unplugging the Viera and waiting for set to cool made no difference.
I then remembered that this issue popped up the instance I surfed to a particular channel (FWIW, 26-3 "Me Too" on Comcast here in Aurora, Illinois, USA). I had a hunch that there might be an issue with the signal on the channel that prevented the Viera from properly syncing, so I decided to unplug the antenna cable. Once I did that, the channel info displayed steady. I was then able to change channels (of course screen was blank as antenna cable was unplugged) and enter the Viera menu. I immediately went to channel set-up and manually removed channel 26-3 from the channel list. After reconnecting cable, Viera was back to normal. Since I'm not a big fan of "Me Too", problem solved :)
Not sure why a digital channel sync issue would effectively make the Viera remote and front panel controls inoperable. Pure speculation, but it could be that the Viera microprocessor was overloaded trying to sync to channel and this prevented any interrupts from remote or front panel controls.
Jun 24, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
I have DirectTV and a DirectTV remote RC64. I can
Here are all the codes I have
10171 10096 10187 10020 10381 10024 10030 11314 10186
here is how to set up without a code:
mode switch set to TV
PRESS & HOLD Mute and Select buttons at the same time UNTIL light blinks twice
enter 9911
keep pressing channel up until the channel changes on the tv
Maker sure to test the VOL button, if volume works
PUSH select key to set the code
THESE PROCEDURE CAN BE USED WHENEVER A REMOTE KEY IS NOT AVAILABLE.
CHANGE THE LAST NUMBER, 1 TO
2 for AUX1 (VCR and DVD)
3 for AUX2 (Audio Devices)
Mar 27, 2009 | Sylvania LC320SS8 32 in. LCD Television
Power light flashing...TV won't turn on
Two flashes sugests that the power supply is faulty.It will have to be taken in to a service centre for repairs.
May 30, 2008 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Panasonic Viera TX-32LX70 32 in. LCD  TV Logo
120 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
