Question about Apple iPad Tablets & eReaders
Change Apple ID on ipad - iPad Apple Tablets & eReaders
    New Friend:
    Problem Solver:
  • 6 Answers
If you have adopted a used iPad, I suggest that you perform a complete restore. This will give you a fresh and clean iPad to which you can register your own Apple ID. You will not be able to keep the contents on the iPad as you received it, but you will be able to enter your own ID.
Good Luck
Use iTunes to restore your iOS device to factory settings
Posted on Apr 03, 2015
    New Friend:
  • 81 Answers
You will have to sign out with the old owners passcode and icloud ID and password. If they didn't sign out their icloud acount. You need to get this information as iTunes will require this if it hasn't been done.If it has 4g and att is the carrier, this may also unlock your sim card
Posted on Apr 07, 2015
SOURCE:
My sister forgot her Apple ID on her iPad and she's 55 and can't remember her password what to do?
Under this circumstance you may have to reset the iPad if you forget both Apple ID and its password.
To reset iPad without Apple ID, you need first put iPad into DFU mode and connect it to your iTunes. Your iTunes will help you to reset your iPad without entering Apple ID easily. Resetting your iPad with this method will result in wiping all the data in your tablet. The following steps will show you how to do that.
Step 1: Open iTunes on your computer and connect your iPad to the computer with a USB cable.
Step 2: After that, turn off you device. Press and hold the Home button for 3 seconds.
Step 3: Put your iPad into DFU mode: Press and hold the Power and Home button for 10 seconds. Then release the power button and keep holding the home button. When you see the Apple logo disappears, you have successfully put your iPad into DFU mode.
Step 4: When iTunes detects that your iPad is in recovery mode, you can restore it now.
Step 5: Click on Restore iPad. Then you will be notified after the reset and your iPad will take a restart.
After resetting your iPad with the guidance mentioned above, you'd better create a new Apple ID and password in time. After resetting iPad, you will get all the data swept from iPad, and you can restore the files from your iPad, iTunes backup or iCloud backup. However, you can't backup iPad to iTunes/iCloud without Apple ID before you reset your iPad . In this case, you need the third-party iOS data recovery software to help you recover lost data from iPad after factory reset without Apple ID.
http://www.leawo.org/tutorial/how-to-reset-iphone-without-apple-id.html
Mar 19, 2017 | Apple iPad Tablets & eReaders
Re set ipad mini
Generally speaking, you need the Apple ID to reset your iPad. iPad needs you to enter the Apple ID to switch off your account and the Find My iPhone service will be turn off. If you are using iTunes to reset your iPad, you need to enter the Apple ID when your iPad reboots.
But if you have no Apple ID or passcode, you will have to reset your iPad without Apple ID. To reset iPad without Apple ID, you need first put iPad into DFU mode and connect it to your iTunes. Your iTunes will help you to reset your iPad without entering Apple ID easily. Resetting your iPad with this method will result in wiping all the data in your iPad. The following steps will show you how to do that.
After resetting your iPad with the guidance mentioned above, you'd better create a new Apple ID and password in time. After resetting iPad, you will get all the data swept from iPad, and you can restore the files from your iPad, iTunes backup or iCloud backup. However, you can't backup iPad to iTunes/iCloud without Apple ID before you reset your iPad. In this case, you need the third-party iOS data recovery software to help you recover lost data from iPad after factory reset without Apple ID.
Jan 01, 2017 | Apple Tablets & eReaders
How do I reset my iPad
You can go to iforgot.apple.com and change the apple email id password
here is the link https://iforgot.apple.com/password/verify/appleid
Jul 25, 2016 | Apple Tablets & eReaders
How do I sin out of my iPad my iPad won't let me
Understand that all the apps and data on the iPad are associated with an Apple ID so "signing out" of your iPad may render some apps and functions useless.
If you are looking to sell your iPad its best to plug it into a computer and restore factory defaults. This will remove all apps and IDs associated with your iPad.
If you are simply looking for security and worry that while signed into your Apple ID there is a chance for fraudulent downloads and purchases it would be my recommendation to set a password/passcode for the iPad that only you know. This will prevent other users form gaining access to your data without your permission.
The iPad is not meant to sign in and sign out at will but if you need to sign out and add another Apple ID then here are the steps to do so.
There are 2 places in which your Apple ID are linked with your iPad. Your iCloud account (photos/documents/ID) and iTunes (music/movies/apps)
You can adjust settings for these individually under Settings > iCloud and Settings > iTunes & App Store
Simply click on the Apple ID email and then choose "Sign Out"
REMEMEBER, some apps and functions may not work without an associated Apple ID registered with the iPad.
Apr 11, 2015 | Apple iPad (16 GB) WiFi Tablet PC
How do I change my Apple ID
Once you set up a apple ID you are marry to it. the easy way is to contact apple
Feb 28, 2015 | Apple iPad (16 GB) WiFi Tablet PC
I need to need to update password from old apple id how can i do this
Sign in to your Apple ID account using your old password and go to my Apple ID and change it there!
Oct 24, 2014 | Apple iPad (16 GB) WiFi Tablet PC
How do I change password to iCloud????????????????
Hi Betty
All you do to change your iCloud Password is to change your Apple ID password with Apple.
Apple My Apple ID
Here you click on "Manage ID" which will allow you to "reset your forgotten password".
I hope this helped have a great day.
Philipp
Sep 28, 2014 | Apple iPad 32 GB WiFi Tablet PC
Reset password
To change your iCloud (Apple ID) password you will need to do the following:
Go to the My Apple ID website http://appleid.apple.com and follow the instructions to reset your Apple ID password.
For more information, see the Apple Support article:
Apple ID: Changing your password.
http://support.apple.com/kb/HT5624
Hope that helps!
Aug 06, 2014 | Apple iPad (16 GB) WiFi Tablet PC
How do I Change my password on netflix IPad
In the settings, scroll down and a few lines under general you see entry code. There give in the old code and twice the new code.
If you want to change the password for your apple ID, goto manage my Apple ID on the Apple website and follow the instructions. Apple My Apple ID
Jul 21, 2014 | Apple iPad Tablets & eReaders
Tablets & eReaders Logo
161 people viewed this question
Top Apple Tablets & eReaders Experts
john smith
 Mike M
Mike M
Ian_C
Level 1 Expert
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
