Question about Samsung Dryers
Samsung dryer dv209aew/xaa shows t0 error code, will start for a few seconds and then stop. I replaced the thermistor and it still won't keep running.
    Master:
  • Samsung Master
  • 996 Answers
Increase fan motor speed
Posted on May 09, 2015
6ya staff
SOURCE:
Anonymous
  • 525 Answers
SOURCE: LG DLE5977 Electric Dryer
Below are some solutions that other customers have cited. The control board seems to have a glitch in it, so I would take it back and get a replacement. New product is covered by a factory warranty or a dealer replacement guarantee. My husband and I just BARELY bought an LG Electric Dryer. I'ts model #DLE2516W. As soon as you hit the power button, "check filter" comes on. The right after that, the error code "Te1" flashes and it does nothing but beep. Clearly, the filter has NOTHING in it because I've never run a load of clothes thru it. When I look in the troubleshooting section of the owners manual, it tells me that this means that the thermistor is open and needs to be replaced. But I'm confused as to why a BRAND NEW dryer already needs a part replaced. Can ANYONE please help me. I have lots of laundry to do. Haha!
Comment by Amanda02, posted on Sep 11, 2007 Well... we took it back to Home Depot and they are replacing it. i was trying to fix it because it takes 3 weeks to get a new one. They don't have any in stock!! And it takes 3 darn weeks to get a new one.
Posted on Jun 11, 2008
canbruce75
Bruce Canfield
  • 1776 Answers
SOURCE: samsung dryer gets a to code
The thermistor or thermal fuse is about an inch long and is inside the rear of the dryer and is usually attached to or near the exhaust duct. It can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a blown thermal fuse. Hope this helped and best wishes.
Posted on Sep 03, 2009
rickead1
Rick Ead
  • 1998 Answers
SOURCE: samsung dryer dv317aeg/xaa has code on display
http://www.washingmachinereviews.org.uk/fault-codes/errors-and-solutions/ use this site try this solution is what the company suggests simply folo down the list till u see your error code with there solution if this does not work u willhave t call a tech to do test on your heater as well as the wiring going to the heater
Posted on Jul 26, 2010
cheergurlie_
SOURCE: My Samsung Dryer (DV218AEB/XAA) Error code HE
invalid heating temp when running. call for service.
Posted on Sep 18, 2010
Norm Dickerson
  • 291 Answers
SOURCE: have a samsung dryer model DV209AEW/XAA. I "hand
Check to make sure your child lock is off first. Hold the time and signal buttons simultaneously for three seconds. Unlikely, but do check. Some of these dryers have a safety switch that the idler pulley has to engage to allow the dryer to run. I tried to find a schematic for this model but could not get one to tell if you do have a safety switch. Look at the arm of the idler pulley and see if it is contacting the switch actuator correctly. When a belt breaks or pops off, sometimes the arm of the pulley will move to the other side of the switch actuator and will not allow the dryer to run once a belt is reistalled. I would also look to see if a wire was knocked off of the motor switch when your belt came off. Good Luck, Appliance Specialists
Posted on Dec 03, 2010
Dv328aew/xaa runs about 10 seconds then stops with error code hE
Heater Error. Samsung believes only its customer support team is capable of solving the problem. If you go to www.repairclinic.com and enter Dv328aew/xaa, you may find a more practical answer.
Aug 29, 2016 | Samsung WF419AA Front Load Washer / Dryer
WHAT DOES ts error code on a samsung dryer
A ts error means that there is either a thermistor short or the vent is blocked. First check the entire dryer vent from the dryer to the outlet. Clean any lint build up and make sure that the vent isn't constricted around any objects if you have flexible ducting. Check that the flap hasn't shifted to block the vent outlet. (I've seen this a few times.)
If that doesn't solve the problem, replace the thermistor. It's part 7 on this diagram: http://www.searspartsdirect.com/partsdirect/part-model/Samsung-Parts/Dryer-Parts/Model-DV209AEWXAA0000/1482/0151200/50039356/00005?blt=06&prst=&shdMod= . If your dryer is still under warranty, contact Samsung for the repair.
I hope this helps.
Sep 05, 2014 | Samsung Dryers
Dv209aew/xaa therm
u may have a bad motor windings problem, usually will rund for about 25 minutes to an hour then shut off, wait an hour and can run again then shuts off ? also check ur venting inside machine and to the wall a build up can cause it to overheat and then shut down? u may have to remove cabinet to see inside condition? which thermostats did u change, u may have bad hi-lo limit and cycleling thermostat
Jul 28, 2014 | Samsung Dryers
Dv337aer/xaa samsung dryer it had a t0 code i replaced the thermister. now i start it and all i hear is clicking, no spinning to heat? what should i do helppppp
You may have not put the belt on properly. These have a belt switch on the pully. So if it's installed wrong it'll pop off the drum causing the unit to be idle.
Nov 07, 2013 | Samsung DV419AGW Dryer
I am getting a T0 code on my dryer. I have cleaned all the vents
Thermistor open
Check for restricted vent Replace Thermistor
If you need further assistance please feel free to comment
Jul 27, 2011 | Samsung DV218AEW Electric Dryer
I GET THE t0 code which tells me its the thermistor. What is a thermistor and how do I replace it
I have that t0 sign appears too, it just stops anytimw, without drying the clothes.
Jul 03, 2010 | Samsung DV316LGS Dryer
Jun 07, 2010 | Samsung DV218AEW Electric Dryer
Anyone know what code t0 means? Dryer will start but never finish drying clothes regardless what cycle you're on.
To = Thermistor Open error.
The Thermistor resistance is very high.
Check for:
- Clogged lint screen.
- Restricted vent system.
- Check Thermistor resistance.
Replace themistor if out of range.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 04, 2010 | Samsung DV337 Electric Dryer
Dryers Logo
673 people viewed this question
Top Samsung Dryers Experts
Marvin
Marvin
Mike
Sheldon Dedek
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
