Question about LG Tablets & eReaders
Dual xdm260 radio usb port won't charge. I get a message it is reading and then error message. I only need it to charge.
I am trying to charge an LG gpad tablet that I want to charge while using GPS on the tablet
  • LG Master
  • 3,042 Answers
Is the charge adaptor good? Test with a known good charge adaptor.
Posted on Jun 07, 2015
SOURCE:
My kindle won't charge. I have tried 3 different chargers.
Lillian, May have to try hard reset or possibly repair charge port to get battery to start charging. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
My Kindle won charge
Kindle Wont Start or Charge How to Reset Kindle
Troubleshooting Kindle Fire That Won Charge
Kindle Fire Won Charge Fix
May 22, 2016 | Tablets & eReaders
Tablet wont charge
you most likely need a new charging port,,,, they are available on amazon, just search for #### charging port , , #### being your model number,,,, or remove the back number and read the number on the harness for the charging port and amazon search that number,
you tube videos will show you how to replace that, if you watch the vid for replacing the screen, you will see the charging port being removed and you'll then know how to do it
Mar 31, 2015 | Tablets & eReaders
Will my zeepad charge threw my pc. charge light has come on but zeepad has not
You cannot use a computer USB port to charge a tablet, unlike charging a smartphone. You will have to use the supplied charger. If you really want to use the USB port to charge your Zeepad, you will need to custom-built a cable using any extra USB cable you can spare. Just change the connector at the remote end of the cable to one that suits your Zeepad's 5V DC IN socket. You are forwarned the connector is not easy to find.
Jan 12, 2015 | Red Tablets: Zeepad 9XN Dual-Core 1.5GHz...
I have the Trio 7" Dual core tablet. The battery is not charging completely, can this battery be replaced and if so where do I find the battery in the unit?
Battery replacement is possible. The battery is a flat component encased in a shiny silvery sheath behind the speaker area inside the back cover. It's mounted with double-sided (very) sticky-tape. A replacemnent battery should be sourced, having the same power specifications as well as physical dimensions. (see detailed close-up photo attached.) Replacement involves desoldering the 2 terminal wires (1 red and 1 black) which attach it to the main board, and replacing the battery with a new(er) unit.
The above having been said,I'd only replace the tablet battery if I was sure that it's the battery at fault. Here's what I'd suggest.
First, check that you're using a charger with the proper 5 Volt / 2Amp (2000milliamp) output. Also I'd suggest you use a charger designed to be plugged intothe G2 7" Dual-Core tablet's dedicated charging port. (See sample tablet charger in attached photo) The G2 tablets WILL typically accept charging output via the micro USB port, for example, from a typical cell phone charger. However typical phone chargers which will happily attach to the Trio or other similar tablets, via the micro-USB port do NOT often have the same output power specifications. This I think may cause difficulty with the tablet battery not reaching the fully-charged status. Also, the use of the USB port for charging may cause access problems if the battery power is low during some operations (eg data transfer in slave mode), as the charging port can not multitask as the USB port can. If power to the main boad is lost during such operations the tablet may become "bricked". Bottom line for me would be to use the dedicated appropriately rated charger whenever possible: it's the reccommended charging method.
25239131-kxzyo1nfvoux0zgzt1u5dqab-5-3.jpg 25239131-kxzyo1nfvoux0zgzt1u5dqab-5-5.jpg
Oct 18, 2014 | Trio Mach Speed Stealth G2 Tablet - Teal...
What is wron with my tablet?
You need to do a hard reset,, read the owners manual for that step, as far as it telling you it would go faster if you had a USB 2.0. , that means your computer is way out of date
May 15, 2014 | ProntoTec 7 Inch HD 1024x600 Capacitive...
Tablet won"t charge with charger
Make sure you are using the charger that came with the unit.
Wiggle the cable in the USB port on the tablet to make sure you have a connection and that it isn't a faulty USB cable or that the USB port is failing.
Try using a different charger that will deliver 5 Volts at 2 Amps...no less.
If none of these solutions work, return the unit to the GeekSquad Bench and have them look at it.
Mar 12, 2014 | Insignia - Flex 10.1" Tablet with 16GB...
My kindle will not turn on
  1. Connect Kindle to a different outlet and/or USB port. If available, also try using a different USB cable or power adapter
  2. Verify the yellow charge light in the power switch at the base of the Kindle is on. When fully charged, the light will appear green.
  3. Restart Kindle by pressing Home > Menu > Settings > Menu and select "Restart." Is the charge light on?
  4. Is the charge light off? AC adapter needs to be replaced.
  5. Contact Amazon if under warranty if those steps don't work
Sep 05, 2011 | Amazon Kindle Wireless Reading Device
Tablets & eReaders Logo
191 people viewed this question
Top LG Tablets & eReaders Experts
 Mike M
Mike M
gbob59
Marvin
Marvin
Are you a LG Tablet and eReader Expert? Answer questions, earn points and help others
