Question about Maytag Atlantis MAV6000 Top Load Washer
Remove maytag inner tub
Inner tub removal
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 413 Answers
Remove top cover, take out the bolt remove the small cover to expose the plate with several screws,remove the screws and lift the inner tub up. Usually this requires two people to get the tub up and out as it is very hard to pull up as it kind of sticks to the shaft
Posted on Jul 28, 2015
  • Jimbo Carver
    Jimbo Carver Feb 10, 2016
    yes my wife and I have been trying and trying. There was tons of old liquid fabric softener I had to dig out just to get this far, I think it has practically glued the tub in. Was wondering if there were and tricks to breaking it loose. Guess I will just keep working it over and over until it breaks loose.
  • Jimbo Carver
    I see some are posting there is a nut to be removed. I do not believe this model has one. It is just the 4 screws. I watched a video on it and it didn't show one either. I was confused about this but according to Bob L and his answer there is none. Thanks for all the help though.
    video link http://www.appliancepartspros.com/whirlp...
3 Suggested Answers
SOURCE:
SearsTechToo
  • 261 Answers
SOURCE: maytag mav6200aww removing inner tub
I broke a hammer removing the basket on a 6000 series today. These are known to be a real ***** to remove. Once those screws are out there is a seal nut to remove and the basket hub assembly is what it sits on. Look at 5 and 7 below.
Posted on Oct 12, 2008
aborcass
  • 2651 Answers
curious as to why you would be removing hte inner tub??? possibly to repalace the main seal??? if thats the case the directions are in the newseal kit. but htere should be a starlike plastice hub seal that will need to be unscrewed that is whats holding down the tub
Posted on Nov 18, 2008
How do I remove the drum on my aav7000aww
To remove the inner tub
remove front panel
remove screws holding top to cabinet
raise top
remove hoses from tub cover
remove tub cover
remove agitator
remove bolts holding inner tub to hub. 5-6 hex head bolts
lift off inner tub
Aug 20, 2011 | Maytag Washing Machines
F1 off balance how do I balance my bravo washer, to get it back on balance?
Their could be objects between the tubs, remove the inner tub nut under the agitation device and lift out the tub. look for objects in there. Also the inner basket has a balance ring in it.
Service manual and failure codes
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 20, 2011 | Maytag Bravos MTW6600T Top Load Washer
Maytag Neptune Model #mah5500BWW We know it a bearing that's causing the loud noise when it spins. How do you remove the tub to get to the bearing?
There are 2 bearings and a seal. To remove inner tub you'll need to use a hammer/mallet or special tools, and you'll need to basically strip the washer to get to the inner tub. Maytag (Whirlpool) does not sell bearings separately, look them up on ebay, use "maytag neptune bearings" as a key phrase. IIRC, the special tool was also available on ebay for lease. Instructions on how to replace bearings are available there also. If no luck on ebay, try googlee for the same key phrase.
Good luck,
Vlad
First Choice Appliance
Oct 28, 2010 | Maytag Neptune Washer
Maytag Dependable LAT8824AAE. Main tub seal leaks
The part number for the mounting stem and seal kit is 6-2095720 it cost about 85 bucks retail. You will also need to buy a special maytag spanner wrench to remove the inner tub. Its NOT an easy job the inner and outer tubs and hoses all need to be removed. The seal kit comes with no instructions. If you had a service company do the job it would be probably around 250 maybe more. We charge 104.95 labor for the job. Good luck _MJ_
Mar 04, 2010 | Maytag Washing Machines
Maytag mav6200aww removing inner tub
Nov 18, 2008 | Maytag Performa PAV2200
Jul 29, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Washer: How to Remove Tub
Under the agitator is a flat nut with notches in it. this nut requires a spanner wrench that will fit into the notches. You can use a large channel lock plier. rotate the nut counter-clockwise. under the nut will be a seal. remove the nut and the seal and pull up on the inner tub. to replace you'll need to replace the seal. if the nut isn't too chopped up, use this to refasten the tub.
Sep 05, 2007 | Washing Machines
Removing Tub from Maytag Atlantis Washer
I do believe that when you remove the four bolts, it should come out. Sometimes you have to use a little force and shimmy left to right to get it to break loose (no hammers please) especially if you have a lot of scum build-up from soap. They can really be a bear sometimes to remove. Maybe put your foot in the bottom of the tub and hit it on both sides to work it free. Good Luck!!! Jim
Maytag Atlantis MAV6257AWW
I have a Maytag Atlantis MAV6257AWW. I need to replace the transmission. So I removed all four screws from the inner tub but I couldnt get the inner tub pull out, it's stuck.
From what I read on here, the seal nut doesn't have to be remove in order to remove the inner tub.
I tried every, I even hammer the shaft down from the inside of the tub but still no luck. Can someone help, thanks.
Jun 23, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
296 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
