Question about LG Computers & Internet
I have an LG Ultimate 2 an it just keeps flashing on an off saying, error : boot certification verify secure booting error, cause : boot certification verify. How do I fix that?
  • Russell Bixby
    Russell Bixby Aug 25, 2019
    Not sure why idiots are adding advice related to PCs, but idiots will be idiots.
    The tag says "DOLVED;" what was the fix?
Not sure why all the idiots give PC advice for a 'phone issue, but idiots will be idiots.
The tag says solved; what was the fix?
Posted on Aug 25, 2019
    New Friend:
  • 16 Answers
This requires more technical in person diagnosis. some things you can try are to boot in to the bios menu.
  • To do this you will have to watch as it is turning on and on one of the startup screens it will tell you to press one of the function keys (F10, F2,F12, and so on) click the one that says "bios" or "settings".
  • After that you will need to search through all the settings for something called the "IDE self test" run that once, it will take a while.
  • and lastly look for another option called the boot order. you have to make sure that the option that says hard drive is first.
I am sorry i can't be of more assistance but not much can be done without seeing the laptop.
Posted on Jul 08, 2015
6ya staff
SOURCE:
Pyrhyc
Ryan Rogers
  • 2028 Answers
SOURCE: wont boot up
This could be that the disc is corrupt. Check it for obvious signs, scratches, miscolloration, etc..., or try a different disc if you have one available.
Posted on Aug 25, 2008
Anonymous
  • 36 Answers
SOURCE: boot failure
Here is some great source to solve any kinds of laptop's problem.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
» Gateway Laptop's Solution
» IBM Laptop's Solution
Here is some another Great source to download any kinds of laptop Drivers.
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
» Gateway Driver's Download
» IBM Driver's Download
4s132
Posted on Jan 07, 2009
SOURCE: Hi I have Sony VAIO
This means that the operating systems was not installed properly...."Boot manager is failed... and ntldr is the main file... which help computer to boot up..." try reinstalling the operating system again...
Posted on Jan 12, 2009
Anonymous
  • 167 Answers
SOURCE: Acer 5100 Vista Boot up issue
hi, i have had 2 acer 5100 notebooks for nearly 2 years now bolth had failed, short time after warranty was up took me many hours to get them working again.. did acer not put the recovery on another partition on your hard drive? if you open my computer-drive c-then you may see a recovery drive,named acer or recovery. do you have the option at post for recovery mode(push f10)? look for this. other than that you have to buy the recovery disks. or buy an operating system. my favorite phrase comes to mind-don't let an update bring you down. i hope this helps you,good luck!
Posted on Mar 04, 2009
parrotheadpc
Chip
  • 2600 Answers
SOURCE: G320 will not boot completely keeps going back to
Try this fix.......
Windows Start-up Errors
Step one, you need a Windows Installation CD. If you only have a recovery disk set like the ones from HP or Compaq they will not do what you need done. Under normal circumstances however, you can use a Dell disk because the Operating system is on a stand-alone disk. All retail versions are also acceptable as well as upgrade disks. For a rule of thumb, if the disk has the Microsoft hologram it should work.
While the computer is first starting up and you see the manufacturers splash screen, tap F12 (some computers it’s F9, others it may be another key, you may have to watch and see if the computer lists the key strokes for getting to the boot menu. If you still cannot find it, boot into the BIOS settings and change your boot order there. Save your settings and exit, the computer will now seek the cd rom as its boot source first.
Place your Windows disk in the computer and start it up. When you see the test at the top of the page “Press Any Key To Boot From CD” Just hit the space bar to activate. The next screen you will see will most likely be a Windows setup screen, when you see this press the “R” key to get to the recovery console. It will get there, it may take a little time, patience. Once it loads you will be given a choice of Windows installations, there should only be one, if there are more, always pick number one. It may ask for an administrators password, if you have not set this particular password, then just leave it blank and press enter. The next prompt you see is:
C:\Windows>
You need to type the following:
cd \
hit enter. Pay close attention to the spacing between the characters. There is a space between the character “d” and the “\”
You are now at the ROOT of the drive, this is where basic commands can be given and changed. You should now see the following:
C:\>
Now type the following:
CHKDSK /R
Hit the enter key.
The chkdsk /r command also includes the P command and will also look for lost recoverable information in bad sectors.
There are occasions depending on how corrupt the system is, that this process could take several hours, so be patient with it.
Now, after chkdsk has run type the following:
FIXBOOT
Hit the enter key.
It may prompt you with a warning, that’s ok, just continue. When fixboot has finished, type: EXIT hit enter and windows will reboot. When the system reboots, tap the F8 key during this time and you will see the multi-boot menu come up. Scroll to the title “Last Know Good Configuration” and hit the enter key. If you were having some simple drive errors this should have fixed them.
Posted on Nov 16, 2009
Testimonial: "Worked very well thanks a lot my grandson will be pleased to have his laptop back for his school work"
Ntldr is missing
The most common reason for this error is when your PC is trying to boot from a hard drive or flash drive that is not properly configured to be booted from; in other words, it's trying to boot from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
Other possible causes include corrupt and misconfigured files, hard drive and operating systems upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables. If all of these are good, reinstall the OS. Also make sure you are installing from a legitimate source. Some downloaded ISO's off of the internet have security features that if it detects its not from the actual disk, it will leave out certain required files in order to function. It sounds like you are trying to boot from a flash drive.
Nov 10, 2013 | Microsoft Windows Vista Ultimate Edition
Ntlrd missing xp tablet on my hp tc1000 with no cd rom
Causes
  1. Computer is booting from a non-bootable source.
  2. Computer hard disk drive is not properly setup in BIOS.
  3. Corrupt NTLDR and NTDETECT.COM file.
  4. Misconfiguration with the boot.ini file.
  5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
  6. New hard disk drive being added.
  7. Corrupt boot sector / master boot record.
  8. Seriously corrupted version of Windows 2000 or Windows XP.
  9. Loose or Faulty IDE/EIDE hard disk drive cable.
  10. Failing to enable USB keyboard support in the BIOS.
Solutions
Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD-ROM. First verify that no floppy diskette or CD is in the computer, unless you are attempting to boot from a diskette.
Note: This error has also been known to occur when a memory stick is in a card reader and the computer is attempting to boot from it. If you have any card reader or flash reader make sure that no memory stick is inside the computer. Additionally disconnect all USB drives, cameras, ipods, iphones, etc. from the computer.
If you are attempting to boot from a floppy diskette and are receiving this error message it is likely that the diskette does not have all the necessary files or is corrupt.
If you are attempting to install Windows XP or Windows 2000 and are receiving this error message as the computer is booting verify that your computer BIOS has the proper boot settings. For example, if you are attempting to run the install from the CD-ROM make sure the CD-ROM is the first boot device, and not the hard disk drive.
Second, when the computer is booting you should receive the below prompt.
Press any key to boot from the CD
Important: When you see this message press any key such as the Enter key immediately, otherwise it will try booting from the hard drive and likely get the NTLDR error again.
Note: If you are not receiving the above message and your BIOS boot options are set properly it's also possible that your CD-ROM drive may not be booting from the CD-ROM properly. Verify the jumpers are set properly on the CD-ROM drive.
Verify that your computer hard disk drive is properly setup in the CMOS setup. Improper settings can cause this error.
Corrupt NTLDR or NTDETECT.COM file
Windows 2000 users
Windows XP users
Sep 24, 2011 | Computers & Internet
Ntldr is mising
Related errors
Below are the full error messages that may be seen when the computer is booting.
NTLDR is Missing
Press any key to restart
Boot: Couldn't find NTLDR
Please insert another disk
NTLDR is missing
Press Ctrl Alt Del to Restart
Causes
  5. Attempting to upgrade from a Windows 95, 98, or ME computer that is usingFAT32.
Solutions
Feb 19, 2011 | Microsoft Computers & Internet
Server certificate
When an SSL certificate is created, the address that will be used to connect to the web page is specified. (www.mywebpage.com) If you are connecting to the IP address of the website, it will tell you that the addres that you have gone to, and the site on teh certificate don't match. There are also some problems with forwarding domain names improperly. what address are you trying to go to, and what exactly does the error say? I have a DI-614, and have never had a problem getting to Secure sites.
Feb 10, 2009 | Microsoft Windows Vista Ultimate Edition
Gmail, Blogspot & Googletalk
hello, this is the problem with the SSL security certificate.. to solve this problem in firefox ... first when this error is displayed there wil be a link that says " add this certificate " , click that link and add the certificate to ur browser.. the problem will be solved ... or else go to internet options in ur browser and check for certificate settings .then download the certificate from google with the option given there....
Feb 03, 2009 | Google Talk
Computers & Internet Logo
385 people viewed this question
Top LG Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
