HOW DO I LOOP A SOUND FILE TO KEEP PLAYING TO THE END OF THE SLIDES WITHOUT EXTENDING THE TIME OF EACH SLIDE?
  • 430 Answers
1) File > New > Presentation > Create (new presentation with all default settings)
2) Panel at right: Slide Transition > Modify Transition > Sound = "apert" (fourth in the drop down list)
You should hear a short (~2s) sound at this point, as the effect is "previewed". If you don't hear it, try the "Play" button at the bottom of the Slide Transition panel. If that doesn't work, then OOo is not able to play sounds and you have to fix that before proceeding.
3) Slide Transition > Modify Transition > Sound = "Other sound" > (select your long music file).
You may or may not hear the preview for this, it depends on whether your music file has a quiet leader at the beginning. If the audio starts right away, you should hear it. If the audio starts after 1-2s of silence, you won't hear anything.
4) Click "Slide show" (bottom of the Slide Transition panel) or F5.
You should hear the music start. It will continue to play even after you advance to the next slide (which is the black "End of show" screen. Advance again to end the show and the music should stop.
Posted on Jul 29, 2015
SOURCE:
Music in power point presentations
  1. Display the slide to which you want to add music or sound effects.
  2. On the Insert menu, point to Movies and Sounds, and then do one of the following:
za079005000.gifInsert a sound file
za079005000.gifInsert a sound clip from Clip Organizer
  1. Double-click the sound file that you want to insert.
  2. When a message is displayed, do one of the following:
    • To play the music or sound automatically when you go to the slide, clickAutomatically.
    • To play the music or sound only when you click the sound icon za006052183.gif, clickWhen Clicked.
  3. To adjust the settings for when the sound file stops, click the sound icon za006052183.gif, right-click, and then click Custom Animation.
  4. In the Custom Animation task pane, click the arrow on the selected item in the Custom Animation list, and then click Effect Options.
  5. On the Effect tab, under Stop playing, do one of the following:
    • To stop the sound file on mouse-click of this slide, select On click (the default).
    • To stop the sound file after this slide, select After current slide.
    • To keep the sound file playing for several slides, select After, and then set the total number of slides the file should play on.
Mar 24, 2011 | Microsoft Windows Vista Home Basic Edition
How can I add a .wav file to an entire PowerPoint slideshow? I only know how to add sound to a single slide and want the file to play through the entire presentation. Thanks in advance for your help.
Since you have not mention the power point version that you are currently using I give you the method to embed sound in your entire slide show for both PowerPoint 2003 and PowerPoint 2007.
Lets start with PowerPoint 2003 : Go to the slide where you want to initiate the sound track in .wav form.(1st slide is the default).
Go to Insert> Movies and Sound> Sound from file
Select your .wav sound file and click ok.
After you click OK you will se a dialogue box appearing asking you "How do you want the sound to play". You have to specify that. If you are not sure select "Automatically" so when you land on that slide during the slide show your music or sound will start automatically.
Select Slide Show ->Custom Animation to enter the Custom Animation pane. Confirm Your soundtrack is listed below in the pane.
  • In the drop-down list of the sound, choose Effect Options. Then the Play Sound interface appears. In the Effect tab, click the radio button beside Stop Playing After XXX slides (which indicates how many slides you want this song to play across) to enter the number of slides you intend to add. For example, you can enter a number from 1 to 999 for this field. Then the sound will play throughout the specified slides.
  • Next, check the settings in the Timing tab. To play automatically, you can set to Start After Previous with a 0-second delay. Click OK to exit the dialog box.
  • Then go to Sound Settings tab, adjust the sound volume as you like. You can also tick to hide sound icon during slide show if you don't want it appear.
Now your sound will play from the first slide till the last.
Life is much much easier with PowerPoint 2007
  • On the slide, click Insert to pick the Sound drop-down list on the very right below the tab. Select Sound from File in the list and choose the specified sound track from your hard drive.
  • Click OK and a message prompts, saying How do you want the sound to start in the slide show? Click Automatically.
  • Now click the sound icon to display the Options tab. Click on the tab, and set Play across slides for Play Sound.
At the moment, it is time for you to play the entire slide show while enjoying this pleasant sound score.
NOTE:
  • The sound you insert must be as long as your slide show. That is, if the slide show lasts 5 minutes, your soundtrack should also be at that length. Otherwise, the sound would be cut off until the slide show ends.
  • It is highly recommend that you take PowerPoint 2007 for your convenience.
Jul 17, 2010 | Microsoft Office 2000 Web Components Book...
I made a powerpoint presentation with PP2003, first added 6 slides, then added another 20. When I add music to the presentation, the music stops at the 6th slide. HELP!
To make a sound continue through multiple or all slides, follow these steps:
  • Go to the slide where you want to begin your audio track (defaulted as the first slide), and select Insert -> Movies and Sounds -> Sound from File to insert the sound.
  • After you click OK, you can see a message pop up asking how you want the sound to start in slide shows. Click Automatically.
  • Select Slide Show ->Custom Animation to enter the Custom Animation pane. Your soundtrack is listed below in the pane.
  • Then go to Sound Settings tab, adjust the sound volume as you like. You can also tick to hide sound icon during slideshow if you don't want it appear.
Now you can play the soundtrack from the very beginning to the end of your slideshow.
Source:
http://www.dvd-ppt-slideshow.com/powerpoint-knowledge/sound-across-slides.html
Jan 16, 2010 | Microsoft PowerPoint 2003 Student &...
Humming sound in subwoofer after it's been playing for a while
It sounds like you are describing an earth loop problem. I won't go into detail in this post, but try an isolation test first. disconnect everything from the reciever except the sub and try connecting say a BATTERY powered mp3 player or cd player to minimise connections to the electrical mains earth. you could also isolate things by taking your sub to a friend's house and trying it on their system.
If it is an earth loop use a process of elimination to find out which two pieces of equipment causes the earth loop. then apply filtering.
you can buy earth loop isolation transformers for about AU$26 and I've used one on my sub myself. Theyhave RCA (phono)plugs on each end and they connect inline with the signal cable to the sub amp.
as for the thumping sound it might be the speaker protection circuitry cutting off the amp to protect the subwoofer speaker from damaged. This might be triggered if the earth loop sound is causing the sub amp to overload and clip.
Failing this there might be a dried out overheated electro capacitor in the amp circuit causing the hum. Hav a chat to your local electronics person, who should be able to spot it!
Hope this puts you on the right track
Happy Hunting!
Jan 07, 2010 | Sunfire Audio Players & Recorders
How to fix a stuck seat belt VW GTI 2009
I just solved the problem for a stuck rear center seat belt in my 2002 Jetta.
Flip the base seat cushion forward against the front seat backs. Trace down along the belt to its tether point on the floor. The belt is sewn around a steel loop. The loop is anchored to a black steel hook. A thin silvery retainer plate is spring tensioned on top of the loop to prevent it from sliding off of the hook when the seat back is folded.
Therefore, you need to press the silvery retainer plate away from the hook (push up) to allow the loop to be slid from the hook. The belt was tight with the seat back in the upright position, so it was necessary to fold the seat back forward to create slack in the belt. Now push the belt loop towards the trunk and slide it off of the end of the hook (only possible with the retainer plate pushed up out of the way).
Now with total release of tension on the system via the bottom end of the seat belt being untethered and with the seat back returned to the upright position, normal extension and retraction of the belt will be reestablished. Next, simply extend the seat belt and slide the loop back into place over the floor hook. It snaps past the silvery retainer plate without all the effort required to hold the plate up during removal of the loop during disassembly.
Check again, the seat belt should be extending and retracting properly. Now just put the seat cushion back into regular position and you will be able to safely buckle up three people across the back seat.
It took about as long to do this repair as it has taken to post this answer to the problem. Note, the seat belt safety mechanism only allows normal extension and retraction of the belt when the seat back is upright.
Nov 29, 2009 | Volkswagen GTI Cars & Trucks
Sometimes stop advancing. sometimes keep advancing 5 to 8 slides.
the mechanism needs cleaning. it is an almost purely mechanical device and needs greasing. the old grease gets hot and dusty and starts to get sticky. when this happens, the moving parts tend not to move. the mechanism needs to come out for a cleaning and regreasing.
Jul 11, 2009 | Kodak Carousel 4600 Slide Projector
Changes from slide to slide
it's likely that the rest of each slide is not exaclty equal (e.g. the amount of text) which could push the picture a little bit in one direction or another or make powerpoint automatically resize the picture or text objects to fit the slide. I'd have to really see the slide presentation to be 100% sure but orientation on each slide is likely the cause.
Mar 03, 2009 | Microsoft PowerPoint 2003 Student &...
Slides
Yes and no. Photographic slides are film positives printed as transparencies, At one time there were kits available for printing or typing slides on transparent acetate material but I have not seen these for years. Two ways to create slides now:
1 Take the slides with a 35mm camera and have them processed. Expensive.
2. Create the graphics/images on computer and send the digital file to a conversion house that will make the images into slides. Also expensive. Much easier to go the othwer way - slide to video or slide to digital images via a scanner.
Mar 03, 2008 | Elmo Projectors TRV-35H Slide Projector
Adding music to a powerpoint presentation
Does the music file play when you click on it? (Drag the sound icon someplace visible on your slide and preview it.)
If it does play when you click on it, you just need to animate the music. The sound file has to be a part of your slide animation--that's what tells it when to start/stop playing. When you insert a sound file, PPT may ask you whether you want it to start automatically or wait to be clicked.
Or, you can right-click an existing sound file and go CUSTOM ANIMATION. Depending on your version of PPT, what happens next will be different. But you should be able to set the sound file to play when the slide displays without being clicked.
Dec 03, 2007 | Computers & Internet
Open Questions:
Computers & Internet Logo
124 people viewed this question
Alun Cox
