Question about Toshiba E-Studio 3511 Color Copier
My Toshiba estudip 3500 is not printing no color on transfer belt during calibration
  • Toshiba Master
  • 727 Answers
U might need to check your laser unit...
Posted on Jul 30, 2015
SOURCE:
Hi dear experts ,hp color laser printer cp1215 is out of calibrate.What can I do to solve this problem ? Thanks .
  1. to recalibrate: first open Toolbox.
    • For Windows XP:
    • Click Start (), click All Programs, click HP, click your product, and then click HP Color LaserJet CP1210 Series Toolbox.
    • OR in Windows Vista:
    • Click the Windows icon (), click All Programs, click HP, click your product, and then click HP Color LaserJet CP1210 Series Toolbox.
  2. Click the Device Settings folder, and then click the Print Quality page.
  3. Under Print Quality, click Calibrate next to Calibrate Now.
  4. Click OK when the 'Your request has been sent to the device' message appears on the computer. The calibration process begins.
    NOTE: Calibration might take 2 to 3 minutes. Do not turn the product off during calibration.
  5. When calibration ends, try printing again. If the issue is resolved, stop troubleshooting.
    • If you are still experiencing print quality issues, repeat steps 1 through 5 in this solution. You can recalibrate the printer as many as 3 times.
Oct 02, 2017 | Laser Office Equipment & Supplies
How i replace ETB for hp cp4025
Replacing the Transfer Belt (ITB, Transfer Kit) HP Color LaserJet CP4525 CM4530
1. Open the printer's right side door.
2. Use the blue lever (see callout 1 in picture below) to lower the secondary transfer assembly.
3. Grasp the small handles on the transfer belt assembly (circled in blue in picture below), and begin gently pulling the assembly out towards you, until a set of 2 larger handles pop free on the sides of the transfer belt assembly.
4. Now grasp the larger handles on the transfer belt assembly, and continue pulling the transfer belt straight out of the printer until it is completely removed.
5. Avoid touching the surface of the new transfer belt. Install in reverse order, sliding it securely into the machine.
6. After replacing the Transfer Belt, it's a good idea to perform a Full Calibration (or even several Full Calibrations in a row, if you are having print quality issues). Full Calibrations help with print quality by aligning the color tones, the drums, and the color plane. Each Full Calibration takes about 4 minutes. To perform a Full Calibration: Press MENU to enter the menus. Press Down Arrow to highlight CONFIGURE DEVICE. Press Checkmark to select CONFIGURE DEVICE. Press Down Arrow to highlight PRINT QUALITY. Press Checkmark to select PRINT QUALITY. Press Down Arrow to highlight FULL CALIBRATE NOW. Press Checkmark to select FULL CALIBRATE NOW. Wait for the printer to calibrate (usually takes 4 minutes or so), and then print a test page. If print quality still needs improvement, repeat the Calibration. If multiple Calibrations don't help, some of the toner cartridges may need replacement.
5e5fcf65-5757-40c3-a110-1a2864982d2e.jpg 554a3a0e-c038-46ec-983d-7467c3deeccf.jpg 7883eb6b-6a29-43fd-b69a-0ff825f60373.jpg bb2de9b0-8f0f-4f6a-a69f-ed1001f8bd09.jpg
Jul 15, 2014 | HP Laserjet Cp2025n Printer
Toshiba 3511 color print problems
Hope it's not the calibration. This could happen due to transfer belt timing problem. There are sensors and reflectors inside the transfer belt assembly. They may be dirty. Clean them or replace the transfer belt if required.
Oct 03, 2012 | Toshiba E-Studio 3511 Color Copier
HP 3550 printer: copies are coming out with faint images of previous printing jobs
Ghosting is caused by a failing transfer belt assembly. The transfer belt is how the printer moves the image from the colored toner cartridges to the paper. The surface has a special organic that allows the toner to be picked up and is transferred to the paper but when it gets worn down some of the toner stays on the transfer belt which causes the ghosting of the previous image. The transfer belt assembly is user replaceable and looks just like a big toner cartridge. You can get them from Office Depot or Amazon.com as well as almost any place you can get the toner for the unit. Here is a link to Amazon.com
http://www.amazon.com/HP-Color-Laserjet-3500-3700TRANSFER/dp/B0001GKY7C/ref=sr_1_1?ie=UTF8&qid=1315341092&sr=8-1
I hope this helps, if so please rate my solution.
BuddyMc
Sep 06, 2011 | HP Color LaserJet 3500 Printer
I have a hp cp4005dn on a network. The prints have color repeating dotts . I have change the toner cartidges and transfer belt. I still have issues.
Calibrate the printer after replacing the ETB.
Full Calibrate Now
Use the following procedure to calibrate the printer whenever you replace the DC controller, the ETB,
the drum drive motors, the drum drive gears, or a laser/scanner. Full Calibrate Now includes theQuick Calibrate routines and adds Drum Phase Calibration and Color Plane Registration. Full
Calibrate lasts for about four minutes.
1. Press Menu to enter the MENUS.
2. Press to highlight CONFIGURE DEVICE.
3. Press to select CONFIGURE DEVICE.
4. Press to highlight PRINT QUALITY.
5. Press to select PRINT QUALITY.
6. Press to highlight FULL CALIBRATE NOW.
7. Press to select FULL CALIBRATE NOW. Wait for the printer to calibrate.
Jul 15, 2011 | HP Color LaserJet CP4005dn Network Printer
Very Light Printer on HP Color LaserJet 3500
Table 7-33. Causes for distortion or blurring
Cause Solution
Transfer unit is defective. Replace the transfer unit. Calibrate the printer
after replacing the transfer unit. See Calibrate
Now, later in this chapter.
Defective secondary transfer roller If it does not rotate smoothly or it is deformed,
replace the secondary transfer roller.
DC controller PCB is defective. Replace the DC controller PCB. Calibrate the
printer after replacing the DC controller. See
Calibrate Now, later in this chapter.
Calibrate Now
the formatter, the color misregistration sensor (PS12), the transfer unit, or the laser/scanner.
1. Press to enter the MENUS.
2. Press to highlight configure device.
3. Press to select configure device.
4. Press to highlight PRINT quality.
5. Press to select PRINT quality.
6. Press to highlight CALIBRATE NOW.
7. Press to select CALIBRATE NOW.
8. Wait for the printer to calibrate.
hope this helps
pdouglasss
Dec 17, 2008 | HP Color LaserJet 3500 Printer
I changed the trasfer kit on my HP Color LaserJet 3500 and now the print is very light. I used and OEM transfer kit and followed the instructions provided by HP. Help
Calibrating the printer
Calibration is a printer function that optimizes print quality. If you experience any print quality
problems, calibrate the printer.
1. Press MENU to enter the MENUS.
Hope this works for you
pdouglasss
My HP laser jet 3500 color printer documents look horrible
Hi marsha_smith:
Run this program and let me know if this work for you ok.
pdouglasss
Calibrate Now
Dec 03, 2008 | HP Color LaserJet 3500 Printer
HP COLOR LASERJET 3500
Hi!
If you could possibly manage to access the machine status menu and have it print to check the drum's life, fuser life, developer, etc.. pls refer. Kindly replace the toner cartridge accordingly use the menu settings when replacing any color if needed. Please print solid image or block in each color Cyan, Magenta, Yellow and Balck. Well see if what color causing the problem. Please let me know the print result it may be; washed out or too light, too bright or black, double image, or not clean. Don't hesistate to contact me again about the result.
Best regards,
Rosener Guyano
Jan 31, 2008 | HP Color LaserJet 3500 Printer
ImageRunner c3200 Color Registraton
With my experience, it's not the registration nor calibration problem, it's either transfer belt is bad or inside the transfer belt is dirty or dusty as well as transfer rollers. here is what I do first
take the transfer belt unit out of the machine, take transfer belt out from the unit, clean inside of transfer belt with damp cloth and rubbing alch. clean all rollers and reinstall.
What it is if the transfer belt and transfer rollers are dirty and dusty, it slips and make it like it's not align. I think most of time it fix the problem with my exp. if not replace new transfer belt
Jan 15, 2008 | Canon imageRUNNER C3200 Copier
Toshiba E-Studio 3511 Color Copier Logo
59 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
digivisionm
Level 1 Expert
amir hamza
amir hamza
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
