Question about Apple iPad 2 Wifi 16GB
My ipad said disable mode after my last updrade
After I up grade yesterday said my ipad is in a sisable mode connect to Itunes
SOURCE:
  • 53 Answers
SOURCE: iPad USB problems
http://www.iskysoft.com/apple-ipad/connect-ipad-to-itunes.html
this is so workfu!!!
tablette pc
lecteur ebook
Posted on Feb 23, 2012
  • 53 Answers
SOURCE: Windows iTunes sometimes won't recognize my iPad when connected via USB
http://www.ehow.com/how_4661194_program-hyundai-keyless-remote.html
this may help you!
netbook 10 pouces
tablette pc
  • 6705 Answers
SOURCE: I can unlock my iPad its disabled in it say to
Apple can help you to reset your login, when you enter the correct password that belongs to your Apple ID. It will be partially on the screen. If you really messed up, setting up security, and lost unlock code and your Apple ID password. Only Apple can help. For that you have to take iPhone, invoice and prove of your identity (Passport) to the Apple store and hope they will unlock your iPhone. With iOS7 Apple made a very good security system. And while setting up the iPhone and the security, you are warned several times what to do to make sure you and only you could enter the system. Whatever you is told there is no bypass for the Apple security system.Be aware if Apple does reset your iPad, all data now on the iPad will be lost.
Perhaps you even could try this? How to Reset Forgotten Password for an iOS Device
Posted on Jul 21, 2014
  • 6 Answers
SOURCE: how can i get my ipad 2 out of recovery mode
I assume you did reboot. After that I would try to update again.
:) Hope this works for you.
Posted on Oct 01, 2014
  • 35 Answers
SOURCE: How to fix MY Ipad which says IPAD IS DISABLED CONNCT TO ITUNES I still do not know what to do next
will need to put the iPad into recovery mode : http://support.apple.com/kb/HT1212
Posted on Nov 04, 2014
Ipad is disabled connect to iTunes. how do I fix it.
Hi Judith.
this is all i could find if this does not work go to the link at the bottom of this page.
The first thing you should try to unlock your disableddevice is a simple iTunes backup. Connect your iOS device to your computer via USB and open iTunes. Select the device in the upper right-hand corner to display its properties in the main screen. Click on the "Back Up Now" button to start a sync.11 Feb 2014
How to fix an iPad that's been disabled after entering the wrong ...
https://www.engadget.com/.../how-to-fix-an-ipad-thats-been-disabled-after-entering-the-...
Ipad is disabled connect to iTunes Google Search
Nov 04, 2017 | Tablets & eReaders
How can i transter pictures from my disabled ipad to the laptop?
If the pad doesn't work then there is no way to transfer the pictures that I know of.
Sep 21, 2016 | Apple iPad (16 GB) WiFi Tablet PC
Ipad is disable
If your iPad has been disabled, it is completely locked down. The only way you'll be able to use it again is by restoring it using iTunes or iCloud. If you have a backup, you'll be able to recover your data, but this process will delete everything that is stored on the iPad. Except for the following methods, there is no other way to unlock a disabled iPad.
  • Using iTunes
  • Using iCloud Find My iPhone
  • via Recovery Mode
  • via DFU Mode
How to Unlock Disabled iPhone with without iTunes
Sep 05, 2016 | Tablets & eReaders
My iPad is disabled and i don't know what to do i've gone on iTunes but nothing seemed to work,what should i do please help me.do you think that you can help me
disabled how if icloud locked we or itunes cant help you --if battery or screen problem bring to a repair shop or sony store
Aug 30, 2016 | Apple iPad Mini
My ipad is disabled and it won't connect to itunes
So it sounds like you have entered the password wrong enough times to where it is now in disabled mode?
Oct 24, 2015 | Apple ipad 2 wifi 16gb white
Ipad A1396 is disabled its sayes to connect to itunes but itune
The intent is to connect your iPad to a computer that is running iTunes.
You must have a current version of iTunes that knows about iPads and an operating system that can run the current iTunes. If your need to upgrade, be sure to install the OS first before your install the iTunes.
Apr 03, 2015 | Apple iPad 2 Wifi 16GB
How do I unlock a disabled ipad 2?
First try to reset the iPad, by pressing both the home button and the on / off button, till the apple logo comes on the screen. Then try again. You should have a password for you Apple account, because that will be asked. If you don't have an account name for the device not worth trying, because it will be blocked anyway.
If this does not work, why not try one in this link?
Aug 02, 2014 | Apple iPad 2 Wifi 16GB
I can't connect to ITunes
connect the pad to your computer and open iTunes, turn off the ipad, then hold both the lock and the home button for 10 seconds, then release the lock button while continuing to hold the home button until iTunes recognizes the iPad.
iOS Device not recognized in iTunes for OS
Jun 18, 2014 | Apple iPad Tablets & eReaders
I need a number that can help me un disable my ipad
If you cannot remember the pass code you will need to restore iPad through iTunes. You must put the iPad in dfu mode to restore, there are several videos on YouTube on how to put your device in dfu mode. After it is I dfu mode, simply plug device into iTunes. iTunes will detect that the device is in recovery mode and give you the option to restore..
Mar 24, 2014 | Apple iPad Tablets & eReaders
Ipad A1396 is disabled it says to connect itunes but itunes does not connect or recognise it
This is a job for an Apple Genius. You will have to make an appointment online with a local Apple store.
Jan 28, 2014 | Apple iPad 16 GB 3G Tablet PC
Apple iPad 2 Wifi 16GB Logo
44 people viewed this question
Top Apple Tablets & eReaders Experts
john smith
 Mike M
Mike M
Ian_C
Level 1 Expert
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
