Question about Sony Bravia KDL-40V4100 40 in. LCD HDTV
Tv solarizes if menu button not pressed
The tv solarizes if the Menu button on the remote is not pressed. If it is pressed and the menu is showing, then the picture is ok. How to fix ?
SOURCE:
HDTV GURU
  • 261 Answers
SOURCE: Sony KDFE50A10 Just shows snow, buttons do not repond
Do you have the correct remote? That would be my first question. But most sony remotes will change channels and turn set on and off. Do you have the owners manual? If i'm not mistaken, that thing has a memory stick input doesn't it? Try that and let me know what happens. Thank you and good luck. Jay
Posted on Feb 01, 2008
  • 140 Answers
SOURCE: sony Tv PFM-42 V1 doesn't show any picture or tv menu
This is a common problem with plasma tvs You did not mention whether you could generate any sound like through your dvd player or something like that. Whether you have audio or not makes a difference on which board may be causing you the problem. Just because it does not have a picture for tv viewing does not mean it won't produce some type of sound through your av1 input. Try it and I'll try to be more specific.
Posted on Jan 06, 2009
  • 8457 Answers
SOURCE: Power on - Screen Black non responsive
U might get the tv working again,by unpluging it,replug an hour later let the tv reset it self.Not,Than the Tuner board,it the board u should looking into replacing.Not the power supply board is good,because u getting a solid power LED indicator light.
Posted on Apr 26, 2010
  • 114 Answers
SOURCE: my wife thought it was hooked to a cable box for
Hello
have you tried pushing 003 on the remote or the AV buttons?
All I can think of is that you must the get tv BACK ON the right channel or AV Input.
Hope you have a better day
Posted on Nov 25, 2010
freetek
  • 5569 Answers
SOURCE: We have a KDL-26U2000, the
Checking your remote can be done with any digital camera since they can 'see' the infrared light from them but I suspect the remote is working; generally, if they are emitting anything, it will be sending correct correct pulse trains.
Having the camera 'live' you will be able to see that the remote is working by aiming the remote at the camera's lens and pressing any button while watching the camera's LCD display. The output of the remote will appear as white or near white blinking lights.
> I've tried to reset to factory settings but when I've got into the service menu I can't input anything?
Often the service settings require entering some code (password) sequence to access factory settings and it may not be possible to enter the code if one or the other end of the IR system isn't functioning.
Summary; I think the remote transmitter is OK but the receiver in the set is not decoding the received signal despite it indicating that something was received.
I think the set itself is a fault and you will need a tech on site on in the shop to search for the right board to replace since the IR receiver may be part of the main board (expensive) or a separate assembly (somewhat less expensive).
Posted on Jan 01, 2011
How can I open the service menu?
Press the helpful button and check link below for various models
First power off your TV using the remote, then press following buttons quickly on your TV remote:
Display (or i+) + 5 + Volume Up + Power
It'll show the hidden service menu on your TV screen.
Once you enter into service menu, you can press Menu (or Options) button again on your remote to switch between various service modes such as Digital, Chassis and VPC.
To navigate between available options press 1 or 4 buttons. To change or modify their values press 3 or 6 buttons.
To save your changes, just press Mute + 0 (or Enter) buttons on the remote.
To restore settings to factory defaults, press 8 + 0 (or Enter) buttons.
PS: For some new models the above mentioned method might not work. You can try following key sequence to access service menu in those new models:
While TV is on, press Left + Right + Mute + Center button + Mute + Menu buttons.
Hidden Secret Service Menu Codes for Sony Samsung LG and Philips TV
TV Service Menus Hidden features you didn know about
Jan 31, 2016 | Televison & Video
Tip
Service menu codes phillips magnavox
I provide this information for those that are qualified and trained to do TV repair work. Entering or making changes in service mode by untrained persons can cause significant and permanent damage to your television. If you are not qualified to service your television, please DO NOT ENTER these service menu codes
# Press {0} {6} {2} {5} {9} {7} {INFO+} on the remote.
or
# Press {0} {6} {2} {5} {9} {7} {STATUS} on the remote.
or
# Press {0} {6} {2} {5} {9} {7} {MENU} on the remote.
# Turn the TV off to exit the Service Menu
* Press {0} {6} {2} {5} {9} {6} {INFO+} on the remote.
or
* Press {0} {6} {2} {5} {9} {6} {STATUS} on the remote.
or
* Press {0} {6} {2} {5} {9} {6} {MENU} on the remote.
* Turn the TV off to exit the Service Menu.
* Press {0} {6} {1} {5} {9} {6} {MENU} on the remote.
or
* Press {0} {6} {1} {5} {9} {7} {MENU} on the remote.
* Turn the TV Off to exit the Service Menu.
* Press {1} {6} {2} {5} {9} {6} {MENU} on the remote.
or
* Press {1} {6} {2} {5} {9} {6} {STATUS} on the remote.
* With the TV off:
Models 15MF605T/17, 20MF605T/17, 15MF500T/37:
To Factory Mode:
Step 1 : Select the source "PC" and then turn off LCD-TV.
Step 2 : [Push "power " button and then push the "VOL- " and "VOL+" buttons at the same time immediately and hold it] about five seconds then release all buttons.
Press "menu"button and bring up factory mode indication
on Apr 29, 2015 | Magnavox Televison & Video
Tip
Television factory resets
Factory Resets / modes
For all listed procedures, start with TV on, in TV mode, unless otherwise instructed. After procedure is complete, unplug set and re-plug in to finish reset.
If more than one procedure is listed for a given manufacturer, try the different ones until you see which one works for your set.
Coby:****************************************-
Enter menu, hi-lite "audio" then enter 8893
mode/source 2580 select "other setting",select "shipment" then yes, after it exits service menu you need to power set off.
Dynex ****************************************-
source/input 2580
hold vol down on tv and hold #1 button on remote, vol will jump to halfway and set shuts off. Turn back on have 1st time setup screen.
source/input 2580
menu 1999 (tv is on)
Element ****************************************
menu 0000
menu 1147
Haier ******************************************
pull up menu, hi-lite "audio" then enter 8893
Hisense *****************************************
In customer menu go to"Parental" enter 0000 then select"Clean All" then power the set off and back on and first time setup menu will be there.
For some models, same as above model except in menu it is labeled "Lock"
Insignia *****************************************-
input 2580 (tv is on)
Mitsubishi ****************************************
Menu 123 or menu 2470 (tv is on)
Panasonic
Hold vol- on TV, press and hold menu button on remote
Philips ******************************************
Push menu, select"Features"then select"current software info" push 062596-info on remote then push info again then red"initialize appears and changes color then complete. Push power button to exit
TV is on,push 062596-info on remote,then push info again, red"initialized"appears it turns green when completed, then push power button to exit
Polariod *****************************************-
Hold vol- and chan- or hold vol+ and chan+ (tv is on)
Proscan ******************************************
In customer menu go to setup,select parental control menu, enter 0000 then select "clear channel list".
RCA *******************************************-
Menu 1147
Sanyo *******************************************
hold vol down on TV, press and hold #1 button on remote, vol will jump to halfway and set shuts off. Turn back on have 1st time setup screen.
Samsung *****************************************-
Mute 182 power (tv is off)
(On some models, Factory Reset is on this menu, on some, you must go into the "Options" submenu
Seiki ********************************************-
Menu 0000
Sharp ********************************************
(Note - On Sharp models, you will need to look through the menus to find the reset option)
menu 1999
menu, 3481
menu 1147
while holding vol- & input buttons on tv plug in set when "k" appears push vol- & chan-
Sony *********************************************
Hold "arrow up" on remote and push power button on tv (tv is on)
Symphony *****************************************-
Source/input 2580
Toshiba ******************************************-
on Menu, select "Installation", then "System Information" press the right arrow button, ("System Information" will change to "Factory Reset" or something similar) follow on-screen instructions
Vision Quest ***************************************-
Source/input 2580
Vizio ********************************************
In customer menu under "Help" tab is Factory Default enter 0000
Vestel (most):
Menu 4725 then select "RESET"
Samsung (European):
Power off, Info - Menu - Mute - Power, then find factory reset and execute option.
LG/Zenith:
Hold MENU on TV and MENU on remote for 5~10 seconds, then select reset option.
NEC:
While powering on hold "MENU" or "INPUT" on TV, depending on model. (Only disables error lock out/buffer and puts TV in temporary service mode.)
To reset to factory, on remote, Off Timer - Menu - Exit - Off Timer, then select reset option.
Vizio Service Menu Method 1
1.Turn The TV off.
2.Press and hold the {CH +} & {CH -} buttons on the TV.
3.Then press and release the {POWER} button on the TV.
4.Release the {CH +} & {CH -} buttons.
5.Now press the {MENU} button on the remote.
6.You should get your regular menu up, but with a "F" in the bottom right corner of the menu (This is for factory).
7.Press and hold the {MENU} button for few seconds.
8.The Service Menu will be displayed.
Vizio Service Menu Method 2
1.Turn The TV off.
3.Then press and hold the {POWER} button on the TV.
4.Keep all three buttons pressed for few seconds.
Vizio Service Menu Method 3
1.Press and hold the {EXIT} button on the remote for 3 seconds then release it.
2.Then press the {1} {2} {3} buttons on the remote.
3.To exit, press the {EXIT} button.
GV42L FHDTV10A / JV50 / SV42 / SV320XVT / SV370XVT / SV420M / SV470M / SV420XVT1A / SV470XVT1A /
VECO320L1A / VO22L / VO32 / VO37 / VO47L / VOJ320 / VOJ370 / VP322 / VP42 HDTV20A / VP422 / VS420LF1A /
VU42 / VW32 / VW37 / VW42 / VX20 / VX32 / VX37 HDTV10A /VX42
Push "Menu" on remote and then push "Vol-" and "Input" on keypad
GV46 / P50HDM / P50HDTV10A
Press "Ch-" and "Ch+" buttons together once on keypad
GV42 / L42 / VP42HDTV10A / VP50 / VX37
Press and release "Menu" on keypad. Hold "Ch-" and "Ch+" buttons on keypad, then hold "Menu" on remote.
P42
Hold "Ch+" and "Ch-" along with "Power" on keypad. OSD will show "F" on right bottom portion of OSD.
VM60P
Press "Info" on remote, then press "Right Arrow," "Down Arrow," "Left Arrow," "Up Arrow," "Right Arrow."
The TV will show "Enter Factory Mode." Press "Menu" after message disappears and go do to "Setup."
GV47
Press "Menu" then press the following combination: "Info," "8," "2," "0," "6."
SV420M / SV470M / VF550M / VF550XVT1A / VF551XVT / VL260M / VL320M / VL420M / VL470M / VO320E /
VO320EP8 / VO370M / VO420E / VP504 / VP505
Press "Menu," and then press "2," "4," "8," "9."
VA19 / VA22LF / VA220E / VA26
Press "Menu" and then press the following combination: "0," "6," "2," "5," "9," "6"
VA320E / VA320M / VA370M / VT420M / VT470M
Press "Menu" and then press the following combination: "1," "9," "9," "1"
VW22 / VS370E
Press "Mute" once OR "-" twice (the dash next to the "0") and then press the following combination: "9," "8," "7," "6"
Main Page
on Apr 23, 2015 | Televison & Video
How do I adjust color on my Sony tv with Shaw universal remote?
Take your Shaw remote control, and follow the instructions on the back. If that does not work, telephone Shaw, and ask for technical support for TV.
Once it is setup, press the TV button on the Shaw remote control, and press the MENU button. That should show the TV's "setup" menu.
Jan 22, 2013 | Logitech Harmony One Advanced Universal...
How do i get the language back to english?
Hello
Press the Menu Button on the remote to show on-screen menu.
Press Cursor Up or Down button to scroll through the on screen menu until the word Install is hilighted.
Press Cursor Right button to display the Install menu features.
Press Cursor Up Or Down button to scroll the install features until the word Language is hilighted.
Press Cursor Right button repeteadely to select English or Spanish [Espanol]
When finished press the Status/Exit button to remove the menu from the TV screen.
[The language control only makes the TVs on-screen menu items appear in English or Spanish. It does not change the other on-screen text features such as Closed Caption [CC] TV shows.]
Ok.
Nov 11, 2010 | Philips Magnavox 27MS343S 27" TV
How to unlock the MENU button on my TEAC RC-1058 remote control
Yes I know press timer and it will take u into the menu........
Jul 31, 2010 | Teac USB2 TV TUNER (USB2TVTUNER) Video...
My lglf7700 has the passcode enabled and i have forgotten it how do i do a factory reset please.
Try this...
The following functions are going to vary depending on the LG model that you have, as manufacturer updates are made without consumer notice.
Turn on the TV, press and hold the menu button on the remote and on the TV simultaneously until a menu shows on the screen. That *MAY* be the service menu.
On the bottom of that menu there will be a selection that reads "load defaults." Toggle down to it with the remote, press enter and then exit the menu by pressing the menu button on the remote.
Or try this...
Turn on the TV. Press and hold the menu button on the remote until a 4 digit passcode prompt comes on the screen...should take about 5 seconds. Enter 8741. Another menu *MAY* come on the screen with a selection for loading factory defaults. Toggle down to it with the remote, press enter and then exit the menu by pressing the menu button again.
Jul 04, 2010 | Televison & Video
Can the service menu for the LG 52sz8d dlp tv be accessed from the orig remote not the service remote just installed new lamp and tv was working fine for 1 week now the lamp indicator light comes on and...
One possible solution to access the service menu on LG tv's is as follows with steps 1 - 4:
1. With the TV on, press and hold the MENU button on the TV front panel.
2. While holding that button, press and hold the MENU button on your remote.
3. Hold both buttons for ~5 seconds until the service menu comes up on the TV.
4. Release the remote MENU button first, then the TV MENU button.
If you are looking to reset the lamp indicator then continue with the following steps 5 - 11:
5. Press and hold the ENTER (or OK) button on the TV front panel.
6. While holding that button, press and hold the MUTE button on the remote.
7. Hold both buttons until the Lamp Life Hours show up on your TV screen.
8. Release the MUTE button first, then the ENTER button on the TV front panel.
9. Make a note of the lamp hours if you want.
10. To reset the lamp hours, press the SELECT button (the one between the four arrow keys with two concentric circles on it) on your remote.
11. It will ask you to confirm the reset--press SELECT again to confirm.
To verify you've reset the hours, you can repeat steps 1-9 above and then just press the EXIT button on your remote.
Hope this helps. Regards, James.
Apr 22, 2010 | LG 52SX4D 52" HDTV
How do i access the service menu of hitachi television. thanks!!!
F59 SERIES
* Press and hold the {MENU} button on the TV.
* Then press the {MENU} {8} {SELECT} buttons on the remote.
* To exit, press the {MENU} button on the TV or
the {EXIT} button on the remote control.
DCAM Mode:
* Using the remote control:
* Hold down the {TV} button.
* Press the {MENU} button.
* Press the {INFO} button.
* Release the {TV} button.
* Remote Control Key Functions When In DCAM Mode:
{INPUT} ............. Blue (13x9 adjust)
{ASPECT} ............ ROM Write
{DAY/NIGHT} ......... ROM Read
{MENU} .............. Remove Color
{EXIT} .............. Cross Hatch/Video Mode
{INFO} .............. Green
{GUIDE} ............. Calculation
{2} ................. Cursor UP
{5} ................. Cursor DOWN
{6} ................. Cursor RIGHT
{4} ................. Cursor LEFT
{0} ................. RED (7x5 Adjust)
{STOP} .............. Initialize
{PLAY} .............. Raster Position
{FAST FORWARD} ...... Phase
To Exit The DCAM Mode:
* Press and hold the {TV} button.
* Press the {0} button.
* Press the {1} button.
Oct 25, 2009 | Beko 142746 TV
I signed on last night, asked a couple of questions, but the info sent to my e-mail didn't have anything to do with the questions I asked. Noticing in the forum, several people has the same problem:...
Howdy Mike-d. here, mikedee4@gmail.com
Hi CindyCee,
I have tried to post solutions, but they seem to be too long, so I will have to post more than once to get the info to you.
First part- the "Line-In" Video Source thing many people are having fun with. Try these options from the Samsung FAQs website.:
How Do You Switch Video Sources? spacer.gif Depending on the model TV you have, there are up to four ways to change the video source:
  • Through the on-screen menu controlled by your remote
  • Through the on-screen menu accessed through the Menu button on your TV's front panel
  • Through the TV/Video, TV/Component, or Source button on your remote
  • Through the TV/Video or Source button on the front panel of your TV
Your TV could provide any combination of these methods. Instructions for all the methods are below
Changing the Source Using the On-Screen Menu Controlled By Your Remote To use the on-screen menu of your TV controlled by your remote to change video sources, follow these steps:
  1. Turn on your TV.
  2. Press the Menu button on your remote. The Main Menu appears.
  3. Select Input, and then press the Enter button. The Input menu appears.
  4. Select Source List, and then press the Enter button.
  5. Press the Up or Down arrow button on your remote to select the signal source, and then press the Enter button on your remote.
  6. Press the Exit button on your remote to exit.
Changing the Source Using the On-Screen Menu Accessed Through the Menu Button On The Front Of Your TV To use the on-screen menu of your TV accessed through the Menu button on the front of your TV to change video sources, follow these steps:
  1. Turn on your TV.
  2. Press the Menu button on the front of your TV. The Main Menu appears.
  3. Use the Up or Down Ch button on the TV to select Input, and then press the - or + Vol button. The Input menu appears.
  4. Use the Up or Down Ch button on the TV to select Source List, and then press the - or + Vol button.
  5. Press the Up or Down Ch button on your TV to select the signal source, and then press the - or + Vol button.
  6. Press the Menu button to exit.
Changing the Source Using the TV/Video or Source Button On Your Remote To use your remote to change the video source, follow these steps:
  1. Turn on your TV.
  2. Press the TV/Video or Source button. The current source appears on the TV screen.
  3. Press the TV/Video or Source button repeatedly to cycle through the available sources. Stop when you reach the source you want.
Changing the Source Using the TV/Video or Source Button On The Front Of Your TV To use the TV/Video or Source button on the front panel of your TV to change the video source, follow these steps:
  1. Turn on your TV.
  2. Press the TV/Video or Source button on the front of your TV. The current source appears on the TV screen.
Part 2 -next
Jan 20, 2009 | Televison & Video
Open Questions:
See all Sony Bravia KDL-40V4100 40 in. LCD HDTV Questions
Sony Bravia KDL-40V4100 40 in. LCD HDTV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
