Question about Singer Sewing Machines
I have a singer fashion maker rotomatic sewing machine..its bobbin case is broken..i have purchased it but don't know how to install it
    New Friend:
  • 4 Answers
I believe that is top loading Apollo bobbin case if so, facing the front of the machine underneath bobbin cover/door there should be a bracket on the left (holds bobbin case) move it back, set case in with the cut out pointing to the back of the machine, you may have to wiggle it a bit until you feel it is seated the move the bracket back over the bobbin case
Posted on Nov 24, 2015
SOURCE:
SOURCE: Bobbin Case
I'm having a similar problem today. I took out the bobbin case and when I went to put it back in, the whole system locks up. I've tired cleaning, changing needle taking the metal plate and piece that holds bobbin case out and put it all back in after cleaning. Nothing. My symptom is I can't get a complete stitch, the needle goes down, the whole deal acts like it will work and as soon as the arm of the bobbin case gets to 8 o' clock on the gears, It jams and won't hardly move. I cannot pull the bobbin case out easily after this. Perhaps there is someone out there that can help us!
Posted on Jun 23, 2008
  • 87 Answers
SOURCE: bobbin case retainer popping out on Singer Touch & Sew 625
Take the bobbin case out. Then when you go to put it in, realize there are 2 ways to get it. You have found one way. The other way is first look in the the slot with a flashlight before you insert it. There is a flat piece of metal the bracket needs to be slid under as it is inserted. This acts like a spring making it tight
Posted on Mar 18, 2009
  • 980 Answers
SOURCE: APOLLO Bobbin Case - replacement/installation
The silver plate should be on top.
Posted on Jan 01, 2010
Testimonial: "Thank you very much for your advice, I had initially placed it on top and it seemed to work but I wasn't 100% sure, now I am, thank you once again."
  • 18 Answers
SOURCE: How to replace the bobbin case in a singer sewing
If you go here and search for 9005, you can find a free downloadable instruction manual.
http://www.singerco.com/accessories/manuals.html
Posted on Jul 22, 2010
SOURCE: Singer 4562 t bobbin case won't fit properly, what am I doing wro
Make sure the bobbin case sets sort of on top and not under the ridge of the metal ring. There is a small latch on the upper left of the bobbin case. It is metal. rotate the latch to cover the bobbin case and this should stabilize the case without making it immobile
Posted on Aug 01, 2010
Cn I gt do live demo. For singer fashion. Maker rotomatic. H to. Use
Try Youtube!
Cheers,
Kelly
Embroidery Services
San Diego, CA
Nov 14, 2014 | Sewing Machines
Singer 9420 bobbin case diagram
Could you check to see if that is the correct model number? I cannot find anything on a Singer 9420.
Dec 22, 2013 | Singer Sewing Machines
I need a manual and a bobbin case for a new home model 764
http://www.sew4less.com/index.php
I don't know if the link will work for the bobbin case, if it doesn't
go to sew4less.com
Bobbin Case # 52237 NB, Click for model info.
p_4754_1148578825.jpg Product #: 4754
Price: $ 19.95
Bobbin Case # 52237 NB, No backlash type.
A bobbin case, also known as a bobbin holder or bobbin shuttle, holds the bobbin that is filled with thread.
Each machine has a specific bobbin case. # 52237NB
Brother 755 Brother B714 Brother B735 Brother DDL-227 Brother DDL-555 Brother DL-5550 Consew 103 Consew 104 Consew 210 Consew 230 Consew 231 Consew 7360R Consew 99 Consew CN 223OR Janome / New Home 764 Juki DDL-227-L Juki DDL-5530 Juki TL98E Kenquilt 622 Singer 1300 Class Singer 1400W Singer 188K Singer 191U Singer 195K Singer 196K Singer 241 Singer 245 Singer 251 Singer 281 Singer 291U and more!
here are is a site that have manual
http://www.sewingpartsonline.com/
Jun 09, 2012 | White Sewing Sewing Machines
Does the Singer Fashion Mate 252 use a bobbin case?
yes, it does. if you don't have a bobbin case or need a replacement
check with these sites
sew4less.com
if you need a manual check with singer
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example 252) & click search
May 29, 2012 | Sewing Machines
I have replaced the plastic bobbin case on the HD110 twice since I purchased the machine two years ago. I sew for a bit and then the case cracks at the edge; this catches the thread and causes tangling....
Yes, if I remember right, it uses a #15 bobbin which is available in metal, but I think that your timing or needle are not right. It may need a good old fashioned tuneup because that is not normal to be breaking a bobbin. Tuneups are usually is not a lot of money and well worth it.
Sep 25, 2010 | Singer HD-110 Mechanical Sewing Machine
Singer Sewing Machine model 9224. Bobbin thread
If you turn the handwheel, can you see a metal ring rotating around the outer edge of the bobbin case? If not rotating, broken gear or timing belt off.
If that ring is turning, remove the needle plate and bobbin case. As this ring now rotates, you will a finger on the ring that will pass behind the needle from right to left and it should catch the thread from the eye of the needle. If this finger, the "hook" passes above the eye, you have a timing problem.
Let me know.
Feb 16, 2010 | Singer Sewing Machines
Jan 27, 2010 | Singer 7442 Mechanical Sewing Machine
Was given an old model Singer 237 Fashion Mate with no manual. cannot get the bobbin to thread properly.
We'll here is a picture of what I need help on I need to know how to put the needle back along with the needle clamp screw
Jul 09, 2009 | Singer Sewing Machines
How do I fix a timing problem with my singer sewing machine? The needle thread will not pick up my bobbin thread.
Here's how you set the timing od the Machine alright:
1. Take the side plate off, take the needle plate off.
2. Take the presser foot off, and put a new needle in the machine. 3. Make sure that the needle is in the lowest position and look at the needle bar for the two timing lines. Locate the top line.
4. Then, turn the handwheel toward you until the top line is where the bottom line was.
At this point, the tip of the hook should be directly in the scarf of the needle.
This should set the timing of the machine perfect....
May 03, 2008 | Singer 5050 Mechanical Sewing Machine
Sewing Machines Logo
100 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Kelley Buchanan
Kelley Buchanan
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
